Like Tree2Likes
Old 05-31-2007, 10:37 PM   #7711
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by sosidge
Final version of my TA05 static strap...
This version now uses eyelets that are crimped and soldered in place. It is now very durable, easy to fit and remove, and the eyelets mean that the assembly has no affect whatsoever on tweak or the structural integrity of the chassis.
If anyone is interested I can put together a small kit of parts to fit one of these to your own car. It will include 1x wire strap with eyelets fitted (red, black or white wire available), 2x cone washers (please specify purple or dark blue), 2x round head stainless hex screws, and some installation instructions.
Price is 5 sterling shipped WORLDWIDE. If you would like one please send funds by Paypal to [email protected]
PS Please don't complain about the cost converted to dollars etc., it is not my fault the pound is very strong right now! I really can't do it for any less and I am not trying to "get rich quick"
Thanks,
Dave
If the static build up is in the bulkhead why would a wire discharge the static when the bulkhead is already attached to the chassis? Is Tamiyas solution really a fix? Just wondering...
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-01-2007, 12:53 AM   #7712
rampal's Avatar
Send a message via MSN to rampal
Originally Posted by guinnes.s
guys,can anyone tell what is the difference in price for the ta05ms?
http://sv09.wadax.ne.jp/~rc-champ-jp/cp-bin/oscommerce/catalog/default.php/cPath/162?osCsid=f69dc439d68864bdb5888c3c70cc66ab
and does mean that is out and in stock?anyone got it yet?
thank you
Salvo
They are different bundles, one with titanium screws, other with titanium +blue aluminium screws and so on....
cheers,
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 06-01-2007, 02:55 AM   #7713
sosidge's Avatar
This is a version of KO's fix. I think the intention is to give the static a discharge route that avoids the servo, as it is metal-gear servos that are being affected. So the static will run along the wire (least resistance) rather than trying to discharge through the servo.
Old 06-01-2007, 06:33 AM   #7714
I have never had any issue's running the car on carpet or tarmac with rubber tyres, never, and don't intend doing static straps, I don't even do that on the 3Racing chassis.
DA_cookie_monst is offline   Reply With Quote
Old 06-01-2007, 06:41 AM   #7715
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
I'm with Cookie, I just upgraded to the 3racing just because it looks good.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 06-01-2007, 06:50 AM   #7716
Trader Rating: 37 (100%+)
What spurs are people using when running the Novak 13.5 motor...rubber tires.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 06-01-2007, 06:54 AM   #7717
tc3team's Avatar
Likewise, I use the 3racing chassis and had not one glitch
Maybe it something to do with the electrics you install, or how they are installed?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-01-2007, 07:09 AM   #7718
sosidge's Avatar
I know a lot of you have had no problems and don't want to run a static strap.
But at the end of the day you shouldn't dismiss the need for one outright because...
1) Tamiya have released an official statement that static is an issue on the TA05-R.
2) I have personally experienced servo problems similar to what has been described in my TA05-R, and a couple of others on this thread have mentioned similar problems too.
So I'm running a static strap for peace of mind! I haven't just fitted it for a laugh!
Old 06-01-2007, 07:34 AM   #7719
The only thing I could see, that could cause the problem, is running the car with far to much roll, the chassis rubs the floor, static build up, but in ALL the years of racing, running static straps went out with the Bosscat (early to mid 90's)
Old 06-01-2007, 07:49 AM   #7720
quantum's Avatar
but why not just get the carbon tub? doesnt that solve the problem? its lighter and stiffer too!
quantum is offline   Reply With Quote
Old 06-01-2007, 09:45 AM   #7721
sosidge's Avatar
I suspect it is actually the belt/pulley material and the interface with the centre bulkhead and alloy top plate that is the problem.
Old 06-01-2007, 09:45 AM   #7722
sosidge's Avatar
Because the carbon tub costs a lot more than a static strap! And I race on super-low grip surfaces where the flex is a benefit!
Old 06-01-2007, 09:55 AM   #7723
Hebiki's Avatar
Trader Rating: 26 (100%+)
oh no. now people will bring up the problem with the carbon tub being tweaked again. here we go again!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-01-2007, 10:59 AM   #7724
Lets skip that part and tell me what spurs are the smallest you can run in the 05R...
Or atleast someone post what spur/pinion combos they are generally using when running a 13.5R Novak BL motor. I bought a big 108 to run my 4.5R Novak BL and now need to know what spur to order to run the 13.5R.
Thanks.
Old 06-01-2007, 11:21 AM   #7725
hmmm, now I have run the yukky aramid belts and the stock belts, in stock and hard graphite bulkheads, and in alloy bulkheads on both plastic and Carbon Fibre chassis setups and never had an issue, at all. If there was a problem, it would happen to all cars, and not intermittent.
Only times I have had glitching, it has been spurious and not in this car, and usualy is resolved aroung refitting the reciever.
The only real issue I can see on the 05R is the aerial wire going through an alloy top plate... if so, ditch it.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
