Like Tree2Likes
Old 05-21-2007, 03:07 PM   #7591
sorry. springs are the stock white springs that came with the R kit (along with the stock swaybars) I don't know exact droop settings (don't know how to measure them - guess I have to learn)- I don't know what the droop is with the kit setup but that's what it is now.
Thanks again
still learning. . .
tom
tsyrc is offline   Reply With Quote
Old 05-21-2007, 03:20 PM   #7592
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Droop has a major effect on handling.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 05-21-2007, 03:55 PM   #7593
Trader Rating: 16 (100%+)
Originally Posted by rcdougie
Im thinking of getting a TA05R and was wondering how big of a pinion you can use. I plan on using the Novak 13.5ss motor and they like a bigger gear. Will there be enough room?
Getting SMALLER spur for the TA05R is not a problem at all, so 100T or smaller on TA05R is not a problem (with hugh pinion..)
I had the opposite problem by using 4.5R motor...the biggest I can use is 108 and I have to use 22T pinion...but at the end, realized 4.5R is just too fast for local track...
Old 05-21-2007, 04:05 PM   #7594
Thanks again
still learning. . .
tom
Just some quick setup to get more steering...
(1) Laid down the front shock upper hole position 1 hole INWARD (to the center of the chassis...) - test the car.
(2) Stand up 1 hole outward @ the rear shock upper hole position, then test the car...
(3) add more droop...Front and rear
(4) Remove front sway bar.....test the car
(5) Add rear sway bar (if you don't have that before)test the car
(6) Harder spring @ rear
(7) Softer spring on front
There are TONS of things to do to get more steering...but try some of the above first...
Old 05-21-2007, 04:19 PM   #7595
If your using a decent tire like a CS27 or such the kit setup should not push. My car was about 90% there for both carpet and asphalt with the kit setup. Go through the car and make sure the droop is set per the instructions. If the rear has little or no droop the car will push like crazy.
The picture shows how droop is measured with a guage. The way I have learned to set droop is by checking the cars ride height, then lift one end of the car checking for when the tires just start to come off the surface...now recheck the ride height. Lets say the car was 5mm just sitting and now its 7mm with the tires just touching. Now you have a measurment. Your droop is 2mm over your ride height. This is also the time to make sure the droop is even side to side. I start about 1.5-2mm over ride height in the front and 2.5-3mm over in the rear. Repeat this for both the front and the back of the car. Make sure to have a very flat surface when doing this.
Old 05-21-2007, 04:26 PM   #7596
this is where I got so far indoors
It is realy dialed, but you got to use tyre additive.
DA_cookie_monst is offline   Reply With Quote
Old 05-21-2007, 07:02 PM   #7597
Goingfast's Avatar
Trader Rating: 29 (100%+)
What is the smallest Spur Gear will the TA05 can use??
or the largerest pinion?
Goingfast is offline   Reply With Quote
Old 05-21-2007, 07:16 PM   #7598
Regional Moderator
Darkseid's Avatar
or the largerest?
I would say that the 90t 64p spur that Core Creations and I are running right now is about as small as you'd want to go.
TLR 22...Tamiya F104...
Old 05-21-2007, 10:48 PM   #7599
Goingfast's Avatar
Well the deal is
I'll be running brushesless motor 13.5 soon and our track is 150X80 could be bigger and I need to get low or mid 4.00 final drive...
Old 05-21-2007, 11:00 PM   #7600
JimmyMac's Avatar
Our track is about that big and I run a 5.00 ratio with the 13.5pro. Is your's wide open? Or is it mixed open/technical? I used to gear 4.6 final. But I found 5.0 more consistent and faster over all for me.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-21-2007, 11:18 PM   #7601
Goingfast's Avatar
It's mixed ...what is your gearing set up....( spur and pinion size?)
Old 05-22-2007, 02:04 AM   #7602
Thanks for the help on setting up droop and the tips on setting the car up better!!!!
I guess I need to spend a lot more time making adjustments while I'm at the track!
Well, I think I need a droop gauge now too!
I'm running Sorex tires so they grip pretty well- I've been avoiding tire additive but I guess that's something else I need to look into also.
Thanks again!
tom
Old 05-22-2007, 05:07 AM   #7603
With a 13.5 and rubber tires right around 5.0 is where you want to be. Darkseid and I run the same gearing 90/41 and that's a final of 4.93. OUr track is about 125x80 and the car is still pulling at the end of the straight.
Old 05-22-2007, 06:28 AM   #7604
Anyone run the TA05 with mamba max 5700 BL system? What gear ratio should i use? 1st time using brushless system, so hope someone can give me a guide on the gear ratio.
Aegis is offline   Reply With Quote
Old 05-22-2007, 07:14 AM   #7605
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Dan the Man
I'm running the Tamiya carbon tub chassis on my 05 at the moment, wondering if there is a weight reduction if you use one of the 3Racing/Penguin/Xenon carbon chassis instead?
Anyone?
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
