Like Tree2Likes
Old 05-18-2007, 11:21 AM   #7561
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Originally Posted by sosidge
The red line marks the centre line of the 05 motor. The blue line marks the centre line of the 415 motor. As you can tell from the chassis cutout the centre line of the 05MS motor is right between them.
Sorry, looks like you will need to find a buyer for all those belts...
I guess the only way they could keep the same belts is increase the spur size to make up for the motor shift, but I'm not sure if it'll be the case..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 05-19-2007, 01:10 AM   #7562
Double Quattro's Avatar
Default TA05 Conversions
Is the Kawada conversion new? I thought they already had a double deck TA05 conversion kit:
http://www.redrc.net/2007/05/kawada-...-tamiya-ta-05/
From my count, that makes 4 companies that now have TA05 conversions on the market:
* 3Racing
* Kawada
* Penguin
* Tech Racing
Any others?
C'mon TRF !!! What's taking so long ? I wonder if the TA05MS will carry the TRF badge when it's finally released?
Double Quattro is offline   Reply With Quote
Old 05-19-2007, 11:41 AM   #7563
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
Has any have any blank setup sheets for the TA-05 like the associated or Xray setup sheets. Where can I download them?
Thanks for the assist.
http://www.countdowntovegas.blogspot.com
Ridge_Racer is offline   Reply With Quote
Old 05-19-2007, 11:46 AM   #7564
sosidge's Avatar
Setup sheet here - http://www.tamiyausa.com/product/trf_page.php - not sure if it covers the many, many possible TA05 parts though.
Old 05-19-2007, 11:59 AM   #7565
Thank you thank you. Its nice to know I am not the only one who spends my Saturday reading rc forums
Old 05-19-2007, 02:09 PM   #7566
rampal's Avatar
Send a message via MSN to rampal
* 3Racing
* Kawada
* Penguin
* Tech Racing
Any others?
you forgot Xenon.....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-19-2007, 10:06 PM   #7567
rcdougie's Avatar
Im thinking of getting a TA05R and was wondering how big of a pinion you can use. I plan on using the Novak 13.5ss motor and they like a bigger gear. Will there be enough room?
rcdougie is offline   Reply With Quote
Old 05-19-2007, 10:54 PM   #7568
bukil's Avatar
Trader Rating: 39 (100%+)
Has anyone tried these ceramic bearings from speedtechrc? If so, are they for the reversible lightweight suspension or for the stock one?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 05-19-2007, 11:13 PM   #7569
Regional Moderator
Darkseid's Avatar
Myself and Core Creations both run the TA05 around here with the 13.5pro.
This is what we are running for gearing.
90t 64p spur/41t 64p pinion= 4.94 final
Thats with rubber tires. Thats leaving us with plenty of speed but motor temps in the 125~130 range while racing in 85+ heat outside, and motor temps in the 115~120 range while racing rubber tire indoors on carpet.
With this setup, you have plenty of room to move the motor back and definitely go bigger on the pinion(the motor is almost pushed all the way forward with this gearing). But since you'll already be at 4.9 on the final, I'm not sure how much bigger you'd want to go.
TLR 22...Tamiya F104...
Old 05-20-2007, 12:27 AM   #7570
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
He assembles the kits himself, so I'm 100% sure he can do a kit for you however you want.
Turbo Joe is offline   Reply With Quote
Old 05-20-2007, 12:49 AM   #7571
Looks like im gonna be ordering a TA-05R in the next couple of weeks. Gonna be running stock rubber on low to med ozite.
Anyone have a set up sheet close to this or a list of something that would get me close.
Also, the store Im gonna be ordering this from is the racetrack I race (want to support my lhs)they dont really stock Tamiya parts, what are the "must have" parts I should order in case something breaks. I would like to order these along with my kit.
wcalaker is offline   Reply With Quote
Old 05-20-2007, 08:45 AM   #7572
Regional Moderator
Darkseid's Avatar
Originally Posted by wcalaker
...what are the "must have" parts I should order in case something breaks. I would like to order these along with my kit.
Just the basics.
Arms...
C-Hubs...
Knuckles...
Thats about it for 'must have' breakage items. Not many things break on the car, especially at stock motor speeds.
Old 05-20-2007, 09:48 AM   #7573
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
Metal suspenison mounting parts. That's all that I've ever broken on my stock 05. Then I upgraded the front and rear and 3racing chassis and to this date no broken anything........yet. And I'm a bad driver. I try to take out the wall for getting in my way.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 05-20-2007, 11:37 AM   #7574
Dan the Man's Avatar
Trader Rating: 40 (100%+)
I'm running the Tamiya carbon tub chassis on my 05 at the moment, wondering if there is a weight reduction if you use one of the 3Racing/Penguin/Xenon carbon chassis instead?
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 05-20-2007, 12:39 PM   #7575
rcdougie's Avatar
Thanks Darkseid, what brushless esc are you using? I have a sphere comp and looks like it might be a tight fit behind the motor. Will it fit?? I also have a mamba max but that is even bigger.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
