Tamiya TA05 Touring Sedan
#7501
Anyone know when this version is going to become available? It says July 2007, but anyone know for sure??? (maybe Steve Wang from Speedtech)
http://www.rczone.net/modules.php?na...rticle&sid=812
Thanks in advance.
Thanks in advance.
#7502
Originally Posted by LogiK
Hi,
Looking at purchasing one of these and running in 540 stock here in australia..
Questions..
1. Is there any required hop-ups to race?
2. Do most people run foam or rubber with this chassis, I will be running on netball court track.
3. What batteries should I look for to run silver cans for like 15 minutes-20 minutes?
Questions..
2) I would stick to rubber tyres so you dont have to worry about roll out and coning.
3) Unless your club rules state there is a restriction on what cells you can use, get the best you can afford, as the 540's are a bit of a slouch in power and need some oomph behind them to get them going. If you are on a tight budget though, go for 3300mah or higher
hth
#7503
Originally Posted by 13Zulu
DA Cookie Monster said
"Since the picture, I have ditched the Aramid belts, to much like hard work on a low maintenance car, lol"
Now I am new to this and have just built my TA05 and have driven it on the track a couple of times and yet to race, but seems I read a lot of posts about the need to put Aramid belts on your TA 05.... I am a bit confused or am I missing something here? or is there a problem with Aramid belts?
But they are prone to flipping over easier
#7504
correction here, the aramid belts are the same lenght, width and tooth pitch, the difference is, they are a lot more flexible, so you don't get the resistance to bend that you get with the stock belts.
On the downside, they need a lot more caring for and are not as robust.
#7505
oops, my bad
#7506
Raced my TA05R with foams (nitro foams, 38R/35F) with 2 diffs...no option except the standard "R" bling bling.....car was great. just as good as all the high end brand (RDX, 007 , Mi2EC....etc) Definitely fast enough to hang with team drivers.........I don't have the time to setup/fine tune the car to make it a little bit more steering. Nor I don't have extra springs or parts to adjust that...so I ran it box stock without sway bar....
I think I will try adding the rear sway bar to gain some steering....also, 4.5 is totally USELESS there......way too fast and the top cars are running like 10.5/19T motor.........that I will have to install next time.
4.5 brushless with lipo....probably is good for 1/8th on road track. This is my 1st time running 4.5 and very impress about the speed but it is no match to the 10.5 for the infield speed.
Overall....very impressed with the $200 plastic car.........
#7508
#7509
what are the differences of ta05MS from ta05/r?
#7514
This may be a newbie question, but here it goes anyway.
I see a lot of hop ups made by Tobee, Yeah Racing, 3Racing. Are they as good as Tamiya? Is any one of them better than others?
I was looking at Universals, steering sets, titanium turnbuckles, and one ways.
Thanks for any help!
(and I have tried looking through this thread- but it's really long!)
tom
tom
