Like Tree2Likes
Old 05-08-2007, 03:56 AM   #7471
TA05ers's Avatar
Originally Posted by DA_cookie_monst
I won my clubs 19t rubber/additive/carpet winter series with a TA05, awesome beast.
Hi DA_cookie_monst,
Congratulations.. great to know the TA05 is winning races!!
What competitions were you up against?
Any settings to share? Pictures of your car and the track?
TA05ers is offline   Reply With Quote
Old 05-08-2007, 04:12 AM   #7472
sosidge's Avatar
Originally Posted by sosidge
Anyone ever tried using something like the 5mm ball nuts (e.g. #53640) to fit the TRF shocks? I'm finding that a) the shock ends have stretched quite quickly from removal and refitting (particularly the lower ends) and b) the aluminium balls are very prone to scratching when refitting with pliers (too tight to do by hand)
Something like these with a screw through...
Another thought - is anyone using these with the same purpose - the new steel balls with a socket head from the TRF501X (#53968)...
Old 05-08-2007, 04:33 AM   #7473
Benny Lai's Avatar
Originally Posted by halim6
mind sharing the setting? and the track condition you are racing?
thanks a lot.
Hey...you got yourself a TA05R??
Benny Lai is offline   Reply With Quote
Old 05-08-2007, 04:35 AM   #7474
I was racing against HB Cyclones, Xray 2007's, Mi2's
Since the picture, I have ditched the Aramid belts, to much like hard work on a low maintenance car, lol
Linky for the setup sheet http://i82.photobucket.com/albums/j2...ndoorsetup.jpg
DA_cookie_monst is offline   Reply With Quote
Old 05-08-2007, 04:38 AM   #7475
peejay's Avatar
Sosidge
Why are you using pliers? What is wrong with your trusty Tamiya box wrench? Just the job for installing ball connectors
The ball nuts are best installed using 3x12mm socket screws, same as the droop screws.
Those hex head ball connectors are fine.
Lastly, if you're worried about the plastic sockets, why not keep a spare set or two of Damper V Parts in your box? #53334.
HTH
peejay is offline   Reply With Quote
Old 05-08-2007, 04:48 AM   #7476
sosidge's Avatar
Originally Posted by peejay
Sosidge
HTH
Because years of working at a computer have made my poor hands WEAK!
I have a couple of low-friction V parts on the way, unfortunately it only occured to me to try some different balls today so I might wait a little longer for the conversion
Old 05-08-2007, 04:58 AM   #7477
halim6's Avatar
Send a message via MSN to halim6 Send a message via Yahoo to halim6
Yup, took me 3 nights to assemble them. This chassis is awesome, but have to wait a little longer for it to go to the tracks. Budget constrain on motor and ESC.
halim6 is offline   Reply With Quote
Old 05-08-2007, 07:30 AM   #7478
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
the low friction parts are harder material, the don't strech as much. I use the 53907 & 53908 where ever I can. I use the ball nuts on the shock towers. I take the bottom of the shock of leaving the ball in the shock, and then twist the top off the shock towers.
tamiyarcracer is offline   Reply With Quote
Old 05-08-2007, 07:38 AM   #7479
sosidge's Avatar
Good tip, hadn't spotted those parts (think you mean #53906 & 7 though, #53908 is Frog UJs!). Also good to hear that the #53918 low friction damper parts are harder too.
Think I may go for the new steel versions though - #53968 & 53969 - not too worried about the extra weight and would appreciate the (possible) extra durability.
Old 05-08-2007, 09:52 AM   #7480
waOscar's Avatar
I use the carbon shock towers mainly to make shock angle adjustments easier. As I find this is the most common adjustment I make to allow for changes in grip levels at my regular tracks.
Top of shock I use;
T53640 Aluminium Ball Nut Blue
T53539 5.5 Aluminium Spacers (there is blue and silver in set and are also usefull for making wheelbase and roll centre adjustments)
12mm screw (I use ti cap heads to keep the weight down)
I never remove the Ball Nut from the plastic connector when making adjustments.
Bottom of shock I use;
T53642 Aluminium Ball Connector Blue
Standard or Low friction plastic connector.
As I rarely make adjustments to the hole I'm using at the bottom, I only remove the shock from the bottom when due for a rebuild.
A word of warning, aluminium ball connector are not as impact resistant as steel ones and can shear off in heavy crashes. I only fitted these items to my daughters car after about 18 months of driving.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 05-08-2007, 10:27 AM   #7481
infokiz's Avatar
I asked this question before and diden't get a reply so I'm going to give it another shot.
Does any one have or know of where I can get a copy of the TA05R manual?
I did my first outdoor TCS race this weekend and with my curent setup in it the car felt horrible and pushed like a dump truck. I would like to try the set up from the 05R manual for the next TCS race. If anyone can help me find a copy that would be greatly appreciated.
infokiz is offline   Reply With Quote
Old 05-08-2007, 10:59 AM   #7482
waOscar's Avatar
I've checked out the usual spots for manuals and there has not been one posted yet.
There should be soon, check out the following from time to time;
http://www.tamiya.com/english/rc/manuals.htm
http://www.tamiyausa.com/product/ite...oduct-id=49418
http://www.tamiyausa.com/pdf/pl/index.php?page=1&dir=
(you will need to enter the kit number "49418" in the search function
http://www.tamiyaclub.com/manuals.asp
I don't know of anywhere else to look.
Untill one of the above is updated, you may need to hope someone who has a TA05-R can scan and email you the manual.
Old 05-08-2007, 11:24 AM   #7483
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note: the Penguin R/C TA05 Low Profile graphite conversion kits are now finally in stock.
More Info
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 05-08-2007, 12:20 PM   #7484
sosidge's Avatar
Nice work.
Good idea to move the cells weight forward a little, this interests me, although it only seems to be 10-15mm, it's limited by the TA05 steering design unless you were to make major changes.
The steering design also comprimises the top deck too, you have to have those big cutouts in it, but with the steering posts as a chassis support I suppose a lot of that flex will be taken care of.
Nice price too. Look forward to hearing from a few people who run it!
Old 05-08-2007, 12:42 PM   #7485
when I read that the cells been moved forward, I was like WHAT, if anything, from the kit chassis, the cells needed to go the other way, I have had to weight the rear of mine a little, just to keep it following the front, without it, the car would snap out of line as it generates enough steering as it is.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
