Like Tree2Likes
Old 05-01-2007, 07:29 PM   #7411
Regional Moderator
Darkseid's Avatar
Originally Posted by SuperEk4
Do u guys race or play BL on Ta05? I m running mamba max 7700 on my ta05r stripped 2 front uprights & 2 bearings in one practice session. In order to run mamba max properly I have to change to kawada 112 spur gear & 22t pinion. I set my TX to 60% EPA.
Its just too fast. I m practicing to race mod class, but seems that most of the guys use 415. Any experts out there willing to share?
I do not want to try aftermath chassis as I may race TAC. I ordered tech racing upper deck to avoid chassis warp.
Btw I m running front spool in my Ta05r & rear ball diff.
Both I and Core Creations race BL with our TA05. But its sensible BL racing. We run 13.5, 10.5, and 5800 at most!
We've seen plenty of people go over the top with the power of BL and end up with nothing but stripped gears, broken belts, and broken parts. If your trying to practice for mod racing, then the 415 or any add ons aren't your answer. The answer is a more reasonable motor. I don't know how Mamba's 7700 compares to novaks series of motors, but I wouldn't go anything stronger than a Novak 5.5 or whatever is comparible in the Mamba line, without first doing some serious drivetrain reinforcing. Like alloy outdrive, high quality spurs and pinions, etc...
Remember that just because we can go that fast doesn't mean we should.
TLR 22...Tamiya F104...
Old 05-01-2007, 08:21 PM   #7412
dodo's Avatar
Send a message via Yahoo to dodo
if you want to win a race, faster motor is not necessarily the solution.
dodo is offline   Reply With Quote
Old 05-01-2007, 11:15 PM   #7413
maxepower's Avatar
Talking 60% EPA, not good for BL!
If you go to the Novak brushless thread they say not to turn down your transmitter to slow the car down. The voltage has to go somewhere and it sends it to the heat sink. This causes overheating problems. So I would keep a close eye on the temp after running it at 60%.
They say the best thing is to learn to squeeeeeeze the trigger, not pull it!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 05-01-2007, 11:28 PM   #7414
HI_808's Avatar
I like the 13.5 in my TA05. I run on small parking lot tracks and find that the Novak provides noticeably more power than your average 27 turn brushed motor. When a lot of my friends decided to make the jump to brushless, they went with Novak 4.5Rs. I am sure they regret it now as many of them are moving to the 10.5 or 13.5 seeking faster lap times due to more controllability around corners.
I also have a 5.5R Novak motor and it runs pretty well in the TA05, but I don't see a need for that power most of the time. I run a one-way with my 13.5, but I set up my TA05 with two diffs and the belt tensioner one click tighter than stock for the 5.5R. Maybe with that Mamba setup on your TA05 diffs will allow some play more so than a spool and be more forgiving on your front suspension parts?
HI_808 is offline   Reply With Quote
Old 05-02-2007, 02:44 AM   #7415
sosidge's Avatar
Fundamentally, the Mamba Max 7700 is too fast for any racing application. It's only for the top-speed run show-offs.
Pick up one of the 5700 motors and you should be much closer to a usable race car.
Old 05-02-2007, 05:41 AM   #7416
Tamiya New Release:
http://google.com/translate?u=http%3...&hl=en&ie=UTF8
I wonder if you can use the 18T center pulley and the 37T Ball Diff pulley on the TA05.
Note they did not use the words "isometric belt" for TA05MS.
trf_racer is offline   Reply With Quote
Old 05-02-2007, 07:02 AM   #7417
hey guys,
what would be the best suitable cheap good quality brushless motor thats not too fast that you cant control but fast enough to impress and have fun!
andy147 is offline   Reply With Quote
Old 05-02-2007, 07:18 AM   #7418
Aluma's Avatar
another question... are the front sway bar endlinks supposed to touch the universal? Should the links be straight up or leaned back? Usually the instructions say to move the ball end into the swaybar until about 2mm stick out. This manual says nothing. Same with the rear links... I set them vertical by moving the ball end out as far as possible without falling off the bar.
Aluma is offline   Reply With Quote
Old 05-02-2007, 07:33 AM   #7419
sosidge's Avatar
No, keep them clear of the driveshafts. I noticed the same thing with the TA05-R build. Angle doesn't matter much when you are talking about an offset of 1mm, so long as they don't bind.
Old 05-02-2007, 08:37 AM   #7420
OscarF1's Avatar
Originally Posted by rampal
in other hand, how much your chassis weight with 5 cell?? close to 1400?? Im strugling to reach 1400gr, but seems quite a challenge with aluminium bulkheads....
cheers,
al
Weight becomes an issue ,
now it is 1525 gr with 6 cell ( Intellect WC )
this is the epoxy glass version.( incl transponder stabilizers and slick tires )
And all the schrews are inox.
OscarF1 is offline   Reply With Quote
Old 05-02-2007, 08:53 AM   #7421
Trader Rating: 37 (100%+)
Originally Posted by andy147
hey guys,
I would run this... $179.99
http://www2.towerhobbies.com/cgi-bin...?&I=LXRST7&P=7
I personally will be using a Novak 4.5R system in my TA05R. Just like any other hot wind brushed motor you just have to take it easy on the throttle. I never dial out any throttle on my transmitter.
On a large open track the 4.5R is perfect. If you run on a smaller outdoor course it might be overkill.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-02-2007, 09:36 AM   #7422
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Do u mean diff is better than spool? I tried diff its harder to drive, spool is better. btw I read 7700 is like a 4T motor, I have to lower the EPA & gear ratio. Wat u suggest?
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 05-02-2007, 09:48 AM   #7423
Just finishing my 05R and saw this in the manual...
You use a buttonhead screw to mount the servo from the bottom??!!
Old 05-02-2007, 10:08 AM   #7424
sosidge's Avatar
It's a special low profile head. Quite why they didn't make the molding for a conventional countersunk screw I don't know...
Old 05-02-2007, 10:24 AM   #7425
Tsquare's Avatar
Originally Posted by trf_racer
Tamiya New Release:
Not only did they not mention isometric belts, but the translation actually said "almost center" when referring to motor position. This car is starting to sound more like a cross between a TRF415 and a TA05 - maybe this is going to be the TRF415 replacement?
Tsquare is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
