Like Tree2Likes
Old 04-29-2007, 08:51 PM   #7381
Double Quattro's Avatar
Default PENGUIN CHASSIS RELEASED !!!!
I've been waiting for this one. I will be converting my 05R after my TCS race (assuming I don't go to the finals)
I was waiting to see how this one compared to the others (Kawada, 3Racing, etc....) I know one of you guys mentioned you were testing this chassis, have any feedback?
http://www.penguinrc.com/products/tamiya/p2020.html
Double Quattro is offline   Reply With Quote
Old 04-29-2007, 09:00 PM   #7382
SuperEk4's Avatar
Trader Rating: 32 (100%+)
I was waiting to see how this one compared to the others (Kawanda, 3Racing, etc....) I know one of you guys mentioned you were testing this chassis, have any feedback?
Hi, why not wait for the Ta05ms its also with graphite chassis. Tamiya sells the chassis separate also. But I think its not out yet.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 04-30-2007, 12:43 AM   #7383
Very true indeed !!!
I would definetly go with the Tamiya MS chassis kit if and when it becomes available. However, it may end up costing as much as the MS kit seeing that the bulkheads and motor mount will not be compatable with the 05R parts.
But any CF upgrade kit they release for the TA05 will be better than any aftermarket stuff. Then I can race GT1 next year!
Old 04-30-2007, 03:01 AM   #7384
Tucker101's Avatar
Send a message via MSN to Tucker101
Hey i am thinking of buying the TA-05R but i live in australia and i cant seem to find the price does any one know the price of this car? i am also thinking of buying th T2R but i have to choose which car. any help on both of these topics would be great
Tucker101 is offline   Reply With Quote
Old 04-30-2007, 05:00 AM   #7385
sosidge's Avatar
Bit annoyed today...
I have always used blue threadlock on the metal-to-metal fittings on my cars, I have always found that hand tightening alone isn't enough to keep them from working loose - and for the first time I have ended up with jammed parts and stripped screw heads!
Not sure what it is about the TA-05 that has caused this - I think it might have something to do with the aftermarket stainless steel screws I have fitted, rather than the black steel kit screws I have always had in other cars.
Anyway, I now have a car that you cannot change the suspension blocks on (kit ones are working OK so not such a big problem right now, but it means that the 1E block and roll centre shims I was going to experiment with will stay in their packs for now!). Unfortunately when I need to change some parts I will be looking at the following scenarios...
At best: New screws after slotting/soldering an allen key to them.
At middling: new chassis after hacking it away (at least the plastic tub is cheap)
At worst: New suspension blocks, new motor mount, and possibly a new spur adaptor as well if that is jammed too!
Bugger.
Old 04-30-2007, 07:19 AM   #7386
Aluma's Avatar
Hi everyone, I am now officially an 05R owner! I'm halfway through the build.
Does anyone have any tips? I'm going to setup like the manual says. I hope thats a good starting point for outdoor asphalt.
Aluma is offline   Reply With Quote
Old 04-30-2007, 07:53 AM   #7387
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
The manual setting is pretty close...the only thing I mess with is droop and arm spacing to start off.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-30-2007, 08:14 AM   #7388
sosidge's Avatar
Bugger.
Quick update on this. Took the Dremel to the car this afternoon. Three screws slotted, couple of small cuts on the chassis (which I will replace to be safe), otherwise no other damage.
Looking at the screws I had put far too much threadlock on and they had glued themselves to the plastic chassis.
Silly mistake, thankfully it will only cost about a tenner to set right.
Old 04-30-2007, 08:19 AM   #7389
Regional Moderator
Darkseid's Avatar
I also use thread lock in certain spots on my TA05. But what I do is: just barely wet the screws with just a "dot" of thread lock. Then after that, I turn the screws between my fingers. So by the time I get done, you can barely tell that there is any thread lock on the screws. They just appear to be slightly wet.
This serves two purposes. 1. it makes sure that I don't over do it on the thread lock. 2. it helps the thread lock dry faster.
I use this method all the time, even on my nitro car's screws, including the engine mount screws. So I figure if that little bit of thread lock is enough to hold a nitro together, its definitely enough for an electric car.
TLR 22...Tamiya F104...
Old 04-30-2007, 09:38 AM   #7390
sosidge's Avatar
Good tip Darkseid, I'll do that from now on.
Old 04-30-2007, 10:02 AM   #7391
secretsg's Avatar
Put a small amount of ceramic grease on the screw will also help with the issue of screw binding to chassis. Especially if you're using it on carbon fiber.
secretsg is offline   Reply With Quote
Old 04-30-2007, 04:42 PM   #7392
BLUE 2's Avatar
Trader Rating: 23 (100%+)
HI All
Has anyone got a price for the TA05MS yet ?
I just found it on rainbowten's site & it said price was going to be 69800 Yen ( about $734.00 AUD ).
Is this true ?
See ya
BLUE 2
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 04-30-2007, 04:57 PM   #7393
SuperEk4's Avatar
Yes u r rite the bulkhead & motor mount may not fit. Have u heard of 3racing? They make good GF conversion too
Old 04-30-2007, 05:12 PM   #7394
Originally Posted by BLUE 2
HI All
Is this true ?
See ya
BLUE 2
Yes, that's right!
trf_racer is offline   Reply With Quote
Old 05-01-2007, 01:04 AM   #7395
R10 will generally sell at the RRP price. RC-Champ should have a significantly better pricing on the TA05MS.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
