Like Tree2Likes
Old 04-10-2007, 07:29 AM   #7006
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Here it is ... post #4549 Is there any aftermarket mod that's available that serves the same purpose.
http://www.rctech.net/forum/showthre...70#post2489974
Originally Posted by ttso
I have mod FK04 belt tensioner (#303070) into TA05. It works quite well. Those who have belt problem might like to give it a try.
The belt tensioner mount is TA05 servo mount, secured on top bulkhead.
Pro4, TA05R, Cyclone TC, 3PK2.4, NGLLRME, TA04R
grizzle is offline   Reply With Quote
Old 04-10-2007, 08:03 AM   #7007
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
bradir, try searching the Tech Racing site i'm not so sure if they are the one who have the belt tensioner for the TA-05 but i know that i've already seen one in the net and the mounting is not on the bulkheads but on the center plate
buboy28 is offline   Reply With Quote
Old 04-11-2007, 06:25 PM   #7008
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Originally Posted by Hebiki
two Lims dont make a right! i heard nospoom is coming down for reedy. you gonna join us? i might be running this car.
Bro...I wish I could be there in time...but timing is not right. I be there a week before the event on a family vacation. I'll look you up. PM me your contact.
CHRIS LIM
OVERGEARED RACING
chrisman is offline   Reply With Quote
Old 04-11-2007, 06:29 PM   #7009
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Hey guys
Changing the sweep of my front arms on 05R and installed a front 1D suspension mount and while installing the rear 1B suspension mount I noticed the mounts 3mm spacer will not flush with the chassis when snugging the 3x10mm screws down. What is the solution so as not increase or decrease the front kick up.
Thanks in advance
Burned up
JoeRacer Graphix
Wanna Bee Racing
rctouringracer is offline   Reply With Quote
Old 04-11-2007, 06:33 PM   #7010
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rctouringracer
Hey guys
Thanks in advance
you have a couple of solutions:
1. dremel a flat spot on your 1B block to accomodate the spacer.
2. change the blocks you are using from 1D-1B to 1C-1A. (use the bridge block or the stock plastic).
chrislim: ygpm
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-11-2007, 06:35 PM   #7011
TRF415boy's Avatar
Hey guys
Thanks in advance
If you're using a 1-B suspension block, and in general, a flipped block that is not of the X-series, then it's not 3mm that you need to put under it, but 5mm of spacers, in order to get back to the original hinge pin height.
Also I agree with Hebiki, dremel a flat spot on the two spacers so that they sit flush.
TRF415boy is offline   Reply With Quote
Old 04-11-2007, 06:37 PM   #7012
nexxus's Avatar
Trader Rating: 302 (100%+)
My understanding of the TA05 is you have to use the bridge mounts, you can't mount a normal suspension mount upside down and then add spacers like on a 415MSX
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 04-11-2007, 06:40 PM   #7013
Hebiki's Avatar
see the post above yours. but basically, any 1X series has a flat spot (1X, 1XA, 1XB, 1XC, 1XD). then there's the regular 1A block (no flat spot) and the 1A bridge block.
the stock plastic/graphite reinforced pieces are the same width as the "A" block.
a DREMEL works wonders!
Hebiki Design Works
Old 04-11-2007, 06:52 PM   #7014
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Originally Posted by tamiyarcracer
we ran the TA05 in a 24 hour enduro. We used the Aramid belts. we ran a Novak GTB with an 8.5 motor. We went through 4 belts. The first 3 in about 68 hours time. the last one went the rest of the 24 hours. What we found is tightening the rear belt so it had no deflextion allowed it to work for a longer period of time. (about 3 or 4 click tighter than we would normally set it)
How do you get 68 hours time in 24 hours
Royal Rumble Racing
minicooper is offline   Reply With Quote
Old 04-11-2007, 07:40 PM   #7015
nexxus's Avatar
meh, I always ran the 1A bridge mounts and did my changes on the other side, didn't feel the need to swap it out, and it always worked well.
Old 04-11-2007, 08:37 PM   #7016
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Exactly...in almost 2 years running this car I never felt the need to change the roll centers via the suspension mounts. I have also just changed the outer suspension mount to suit my liking as far as toe and sweep are concerned.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-11-2007, 09:31 PM   #7017
Trader Rating: 37 (100%+)
So what blocks fit and/or are people generally using with their TA05? I'm looking at picking one up and want to grab the pivot blocks.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-11-2007, 09:42 PM   #7018
nexxus's Avatar
I ran 1A's all round with standard suspension, and 1A's front, 1A / 1D rear when running lightweight suspension.
Old 04-12-2007, 02:29 AM   #7019
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Hi, have u guys tried tamiya B3 tires on Ta05r?it wear out so damm fast n skid a lot. I just install front 1way drive. Its a lot faster but skid easily. Any tips?
I removed the front roll bar but use the thinnest on the rear. I am using RZ super stock 23T
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 04-12-2007, 03:03 AM   #7020
nexxus's Avatar
Unless it's a really warm day outside, I'd use type A's!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
