Like Tree2Likes
Old 04-06-2007, 11:21 AM   #6961
Try some o-rings between the straps and the clip. Combined w/ the foam padding, as previously suggested, on the underside of the strap you can achive a really tight fit. Think it should be legal!
Dtech is offline   Reply With Quote
Old 04-06-2007, 11:45 AM   #6962
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Thx guys, I'll give it a try.... Still haven't figured out how to post a photo?
If someone has a minute to explain it, that would be great! PM me if you don't mind....
Burned up
JoeRacer Graphix
Wanna Bee Racing
rctouringracer is offline   Reply With Quote
Old 04-06-2007, 11:58 AM   #6963
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Does anybody know where I can get cheap tires and wheels for TCS?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 04-06-2007, 12:03 PM   #6964
Cheap TCS tires and wheels exist in the same place the Easter Bunny exists.
Speedtechrc.com sells them though
DOTMAN is offline   Reply With Quote
Old 04-06-2007, 12:46 PM   #6965
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
WWW.RC-CHAMP.CO.JP
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-06-2007, 01:34 PM   #6966
I usually just attach a JPEG when posting. Just go down to where it says manage attachments, then browse for your pic, then attach.
Old 04-06-2007, 04:02 PM   #6967
Testing!
Now you can see what I was talking about with the whole battery post thing! Thats a pretty big gap!
Thanks Core Creations....
Burned up
JoeRacer Graphix
Wanna Bee Racing
Old 04-06-2007, 04:05 PM   #6968
Default brace
Part of your situation is that you are running the old 3000 packs where the cells are a little smaller. Definately you're going to have to fill that space with the foam and o-rings.
Xray T3 '12
Xray T4' 14
FKhanro is offline   Reply With Quote
Old 04-06-2007, 04:07 PM   #6969
I have 4200's just the 3000's were on the table at the time! I really doesn't raise it up that much higher with the other cells in...
Burned up
JoeRacer Graphix
Wanna Bee Racing
Old 04-06-2007, 04:16 PM   #6970
Regional Moderator
Darkseid's Avatar
Testing!
Theres 3 ways to fix that, but only 2 are TCS legal.
1. After putting on your strap, place O-rings over the post then secure everything with the clips like you normally would.(downside-you'll have to pull off the O-rings everytime you swap packs. You could cut this task in half by only releasing the front of the strap when changing packs. But still this is a pain)
2. Put cusion foam strips on the bottom of your strap to raise it up, but still keep the pack nice and secure. Losi makes some nice foam strips for the JRX-S that would work nicely. (downside-nobody really likes to have to put this foam on the bottom of the strap. It makes it look weird and takes away from the 'factory' look of a carbon strap. But you do what ya gotta do to make stuff fit!)
3. Cut down the the two mounts where the post screw into. Make SURE you pre-tap the holes again as you will be going lower into the chassis than you would have if you hadn't lowered the post mounts. This step is a MUST, as the aluminum strap post WILL break if you try to thread them in without pre-tapping the hole again. Ask me how I know! (downside-TCS rules look down upon any cutting of anything on the chassis. So this is likely not TCS legal)
TLR 22...Tamiya F104...
Old 04-06-2007, 04:53 PM   #6971
mkdut's Avatar
Trader Rating: 19 (100%+)
As a subnote to Darkseid's suggestion, I use a Tamiya foam time insert (#53295?). This allows you to accomadate a variety of batteries with out cutting down the chassis, but as Darkseid noted it takes away from the 'factory' look.
mkdut is offline   Reply With Quote
Old 04-06-2007, 06:18 PM   #6972
Double Quattro's Avatar
OK, my TA05R is due next week and I keep getting other things (except my new car) delivered which is getting me even more psyched. I mentioned I've been away for a few years so there have been many changes to standard racing electronics since the hay-day of my YR4 and NI-CAD 2000's.
Just a few questions if I may ask:
*** I ordered a few new packs - Intellect 3800's. But I thought I'd stick with my old ESC for now - Novak Cyclone TC. Will today's higher capacity NIMH's play nice with my older Novak or will I see smoke? I am running Stock and/or 19T.
*** Are the on-car fans more for mod motors / classes? What are the benefits to the electronics versus the added weight/balance issues to the car?
*** What's the deal with the personal transponders? Are they so people can avoid a last minute addition (regular borrowed transponder) to the car set-up? Do the work immediately with standard track lap counters?
Thanks for any info!!
Double Quattro is offline   Reply With Quote
Old 04-06-2007, 06:40 PM   #6973
Your Novak Cyclone will be 100% fine. No problems with the new cells.
You can run a motor fan, but it's overkill in my opinion unless you run mod or in the desert.
Personal transponders are awesome. It's a hassle to get house transponders every round and it is easier to find a place on the car to ballance it than a standard AMB transponder. The software needs to be AMB-RC edition to read a personal.
Old 04-06-2007, 07:17 PM   #6974
Thanks for the info!
Old 04-06-2007, 11:04 PM   #6975
westerdude42's Avatar
I run a Cyclone in my 05 and have never had a problem. I run 4200's and have run everything from silver can to 10 turn double. Great speedo even if it isn't that small.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
