Like Tree2Likes
Old 07-14-2005, 08:22 AM   #676
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Update on order. What do you guys think about the Tech-Racing option parts? Will the upper deck improve the chassis and its overall performance? I also think the Tech-Racing CF towers look alot more different. I also think they have their own shocks that you can buy for teh TA05...
vi3tishduy is offline   Reply With Quote
Old 07-14-2005, 08:43 AM   #677
Ballsie's Avatar
Here are the said Tech Racing TA05 parts ...
TTA010 Front shock stay
TTA020 Rear shock stay
TTA030 Low mounted upper deck
TTA040 Battery plate Discount price
TTA050 Steering plate Discount price
TTA060 Aluminum turnbuckle set (lightblue)
TTA070 Oil shock set (lightblue/4pcs)
TTA080 M3 Hex screw set
Ballsie is offline   Reply With Quote
Old 07-14-2005, 09:27 AM   #678
ttso's Avatar
Default [MOD] TRF415 steering arm on TA05
TRF415 steering arm is in same 2D layout with TA05 steering arm, but 2mm higher than TA05. When I first realize I can't put my TRF415 steering arm on TA05, I thought "God it's so TAMIYA" FEAR NOT! I got the modification done and now you can use TRF415 steering arm on TA05. PLUS even lower CG
DISCLAIMER: MOD ON YOUR OWN RISK!!!
1. You need to remove all the plastic column on chassis. Sand it all the way down to where steering column sit.
2. On front brace, remove all the plastic column. Sand it all the way down the elevation.
3. Put 5x3x0.7mm shim (#9805645) first, than secure the steering column on
4. Add 7.5x5x0.1mm shim on steering column
5. Put TRF415 steering arm on (of course, you need to mount the TA05 plastic steering plate on TRF415 steering arm first)
6. Add 6.7x5x2mm shim on steering column (#9804153)
7. Put everything back on.
8. You might need to adjust the shim based on how you sand the column. Try/Error cycle to find best shim.
9. Done
Beside you can now using TRF415 steering arm on TA05, save the money of buying new hopup. Once you finished, entire steering rack sit almost 2mm lower than stock or TA05 hopup. Who need TA05 hopup steering arm now?
Tamiya TA05 Touring Sedan-dscn4798.jpg   Tamiya TA05 Touring Sedan-dscn4799.jpg   Tamiya TA05 Touring Sedan-dscn4800.jpg   Tamiya TA05 Touring Sedan-dscn4801.jpg   Tamiya TA05 Touring Sedan-dscn4802.jpg
ttso is offline   Reply With Quote
Old 07-14-2005, 10:05 AM   #679
ttso's Avatar
I already email asked if http://www.pro-s-futaba.co.jp/ will carry 10~50, they said they will in stock on next Monday (didn't ask 60~80 since I don't need them). Already pre-order them...
Old 07-14-2005, 10:17 AM   #680
Ballsie's Avatar
I think they are also in stock at RC Champ - see their thread on this forum.
Old 07-14-2005, 03:25 PM   #681
vi3tishduy's Avatar
What does the upper deck do for the chassis? Make it stiffer? I'm guessing its only good for carpet racing? And, the Tech Racing Oil Shock Set, anyone have a pic of em or are they like teh Tamiya Shocks? Also, the titanium screw kit for the TA05, are they shaped like + or are they hexed? I have associated tools and I'd rather get the hexed ones, does anyone know the part number for the tamiya hexed Ta05 screws? Or will the Tech Racing ones work?
Old 07-14-2005, 05:14 PM   #682
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
The Ti and Aluminum screws are all hex, but they're metric 2.5mm. Associated are by the inch, so they're not a perfect fit. You'll be bound to strip your screwdriver and/or screws pretty fast, unless they do have metric ones too...
Otherwise, I advise you to get an actual 2.5mm hex screwdriver for the standard screws, as well as a 2.0mm for the smaller set screws, like droop, sway bar setting, and pinion gear. It's much easier to adjust those with the screwdriver.
I use a nice shiny aluminum handled set.. Gold for 2.0, Magenta for 2.5, and Blue for 3.5 (for my nitro). Hardened steel, has never skipped on me once.
Just don't use the associated ones.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 07-14-2005, 07:45 PM   #683
vi3tishduy's Avatar
Thanks Jamz. So, dont use the associated ones.. So all the screws on the TA05 are metric shaped like +.
Old 07-14-2005, 08:03 PM   #684
vi3tishduy's Avatar
Wait nvm i get it, the stock screws that come with the TA05 are + and the ti ones are hex.. Thanks! So all I'd need for the TA05 is the 2.0mm and 2.5mm?
Old 07-14-2005, 11:10 PM   #685
All the screws in most top Tamiya kits are 2.0 mm for most of the screws, and 1.5 mm for all the droop screws, set screws and pinions.
2.5mm is oly generally used for motor screws in electric kits.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 07-15-2005, 09:35 AM   #686
Jam-ehz's Avatar
Yup, thanks for the correction, my bad.. I thought I was off when I posted it, but I looked at the screwdrivers themselves, they are printed as 2.0, 2.5 and 3 respectively, but I just measured them right now, and indeed that's the case.. heh..
Yeah, the 2.5mm I've just used for the motor, and my nitro engine (manifold and shaft screw), not much else, really, but still handy. But i'll still need that 4-1/2" allen key they include with the TA05 kit, as mine isn't nearly long enough.
Old 07-15-2005, 03:36 PM   #687
vi3tishduy's Avatar
So thats all I need, 1.5, 2.0, and 2.5mm for the TA05 kit?
Old 07-15-2005, 03:38 PM   #688
Ballsie's Avatar
I don't think you will need the 2.5 ...
I'm sure the 1.5 and 2.0 will be enough - I only use these sizes on my TRF 415 / 415MS / Evo IV.
Old 07-15-2005, 05:51 PM   #689
vi3tishduy's Avatar
Well you guys with the TA05... How is it?
Old 07-15-2005, 06:41 PM   #690
Ghostfit's Avatar
Originally Posted by fire929
How many and what size spacers are you using for the diffs?
2 pcs, 0.3 x 10mm for each diff, one on each side between the bearing and the diff.
Ghostfit is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
