Like Tree2Likes
Old 03-21-2007, 01:36 PM   #6856
Super Moderator
Grizzbob's Avatar
Originally Posted by Italian racer
I have found that if you build a diff properly you will be able to tighten the diff almost all the way and still have great diff action. When putting the diff together I like to use AE diff lube and I use a lot of it. Generously apply to each diff ring and then fill each hold on the spur gear before inserting the balls. I will then tighten the diff till the plates touch the diff balls and then tighten it a half turn at a time there after. In between tightening it, rotate the diff back and forth for roughly 10-20 seconds at a time. Normally this takes 6-7 times of tightening and rotating and it allows the lube to get into the diff completly and to tighten it fully. I have never had to re-tighten my diff after it is built.
That is how I do it and I hope it helps!!
Same here, started building my diffs that way when I was running offroad only, & Losi's manuals were saying to do it just like that, tightening a bit at a time till it's where you want, & I've hardly EVER had a diff loosen itself on me, in whatever car I've had.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-21-2007, 07:48 PM   #6857
Default Got my TA05R!
Just got my TA05R. I already have a very hopped up TA05 but I really couldn't resist. Some high points--cheap--about $260US in my hands, lightweight suspension, alloy suspension blocks, aluminum turnbuckles, blue threaded shocks and many carbon reinforced parts trees, 5mm blue hex hubs, universals front and rear, 36T wide pitch diff gears, sway bars---pretty much all the 'go-fast' parts.
The lows: Basic plastic chassis, grey steel phillips screws, crappy grey motor mount but does come with a cool blue top trim, no rear aluminum uprights (I guess what can you expect at this price), no aluminum steering rack or steering bearings.
All in all, a great value. You could easily still spend another $200 on hop ups including the chassis, motor mount, front and center oneways, aluminum uprights, carbon fibre shock towers, battery brace etc. etc. but you've got the main parts.
Fazal
Xray T3 '12
Xray T4' 14
FKhanro is offline   Reply With Quote
Old 03-21-2007, 07:52 PM   #6858
nexxus's Avatar
Trader Rating: 302 (100%+)
Fazal
Which means the local distributor MAY import it into Australia by the end of NEXT year!
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 03-21-2007, 08:41 PM   #6859
Super Moderator
Grizzbob's Avatar
Fazal
Sounds pretty sweet, but one thing I'd SERIOUSLY consider is changing out those aluminum turnbuckles to steel or titanium. I had those same aluminum ones on my 415 MSX & they were FAR too weak to take any real hits, would either bend easily or snap completely. If you wanna maintain the '05's rep as an ubertough car then I'd switch those out pretty quick....
Bob Seay
Go Pokes!!!
Old 03-21-2007, 08:55 PM   #6860
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Fazal
Brought another Tamiya again wow lol......
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-21-2007, 11:25 PM   #6861
Default Ti
Absolutely right about the turnbuckles. Blue is pretty but at the least you need Ti on the steering. Ova: Can't resist the blue!
Fazal
Xray T3 '12
Xray T4' 14
Old 03-22-2007, 05:52 AM   #6862
OVA
OVA's Avatar
Fazal
Did you ever put the Porsche together?
Old 03-22-2007, 09:25 AM   #6863
TA05ers's Avatar
Originally Posted by muahdib4
Ok, how about this..
http://www.tamiyausa.com/product/ite...oduct-id=49400
A Type 934 based on a TA05 with a double-deck carbon-fibre chassis???
Almost fell off the chair when I saw this. It is like a dream come true. I am new to R/C and got the TA05 about 5 months ago. Still brushing up my driving skills right now and gain more experience by taking part in as many races as possible.
Anyway... back to this fantastic chassis. The TA05 is at least a few tenths of a second slower than an MSX per lap. I have always wonder if Tamiya comes out with a double deck carbon fiber chassis version of the TA05, will it ever match the MSX?? Anyone has any comment on this?
However, a little confuse here. The Tamiya USA web shows this "Item #49400 (DISCONTINUED) (COMING SOON)" So, is this chassis on its way or discontinued?
TA05ers is offline   Reply With Quote
Old 03-22-2007, 09:54 AM   #6864
This chassis was a VERY limited run.... you can still get one, but they fetch a hefty price tag on ebay. Most that bought this kit, bought it for show purposes - or investment purposes only. If somone actually put this car on the track, they have too much $$$ IMO -
duckman996 is offline   Reply With Quote
Old 03-22-2007, 09:56 AM   #6865
Fazal
FAZAL - YOU HAVE A PROBLEM!!!!!
Old 03-22-2007, 10:21 AM   #6866
Default TA05
I will be entering a re-hab program shortly. Damn blue virus!
Fazal
Xray T3 '12
Xray T4' 14
Old 03-22-2007, 10:49 AM   #6867
peejay's Avatar
It isn't really a CF double deck version of the TA05 because it has a short wheelbase - about 1 inch shorter than a regular touring car chassis - to suit the Porsche body. Previous Tamiya short wheelbase chassis (TA02SW, TA03(F/R)S, TA04SS) used reversed suspension arms and other tricks on a standard chassis to achieve the desired result but not so with this beauty.
The original production was rumoured to be only 1,000 units, and nobody really seems to know if there will be any more.
peejay is offline   Reply With Quote
Old 03-22-2007, 12:45 PM   #6868
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
In club races, where competition isn't as high as a major race, it does quite well against the 'Pro' chassis types, T2, 415, etc.. but the bottom line is that its extra weight simply can't give it the same corner speed as the MSX (talked to Mr. Crisp Tuesday night about the whole Lipo/4-cell/car weight thing as well as the RC-chemical issue, very insightful!). Of course it may only be noticeable in the hands of a more advanced racer with consistent laps, but it's still a factor. Martin recalled a driver who just raced 4-cell mod overseas, their speeds down the straight were almost 9 mph slower, but overall the saved weight from 2 cells gave them better laptimes than 6-cell would, as they could race the lighter car around corners that much faster. Same case for 1/12th scale, half the weight of a 1/10th, thus can be faster in the turns.
On the other hand, more things can go wrong with a 415 than a TA05.. tweak, parts breakage (LW susp vs. TA04 susp.), and a higher sensitivity to setup changes. The tub TA05 is way more forgiveable both in terms of durability and setup, and that's why I love it. I can focus more on driving and less on tinkering with the car. I even find the TA05 Xenon chassis, though lighter, can be harder to get a decent setup to race.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 03-22-2007, 03:23 PM   #6869
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
Got my TA05 almost ready now. Picked it up as a roller that needed some TLC for $20
So far I have added:
3 racing shocks
3 racing front one-way
3 racing aluminum diff cups for the rear (not installed yet)
LRP Quantum Pro ESC
Trinity CO27 Pro motor
KO Propo PDS-2343 Servo
Spektrum
CS 27's
Also would like to ask what would be a good starting point for shock oil. I will be racing on a parking lot track at my local Hobby Town.
Blacktiger355 is offline   Reply With Quote
Old 03-22-2007, 03:27 PM   #6870
Hebiki's Avatar
Trader Rating: 26 (100%+)
Tamiya yellow (40wt) - 3 hole pistons.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
