Like Tree2Likes
Old 07-11-2005, 11:31 PM   #646
Ghostfit's Avatar
Originally Posted by Jam-ehz
One question, how tense should the belts be? I put it at the default setting according to the manual (two marks from the dot) with the aramid belts, but it seemed tight. Should I be able to push the belt down to touch, say, the servo turnbuckle, or the chassis braces?
And is it me, or does the rear diff "half-cover" coming from that rear brace make it harder to put that diff in? Or am I doing something wrong? I've already notched it a few times..
With the Aramid belts, tension is tighter. I've adjusted my rear tension to be on the dot and the front to one mark from the dot.
I reposition the rear diff by gently sliding it at an angle into position and then pushing it horizontally to fit into the slots, it's easy once you got it.
Ghostfit is offline   Reply With Quote
Old 07-11-2005, 11:36 PM   #647
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally Posted by vi3tishduy
Hello folks! Hebiki thanks again man! Ok about the TA05, is stifness better or worse for asphault or is flex better for asphault? Also, would you guys happen to know good esc fans and part numbers? Does Tamiya have any? Thanks!
I think the team associated heat sink with fan will look nice and is also blue in color.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-11-2005, 11:36 PM   #648
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Danjoy do you ahve the part number?
vi3tishduy is offline   Reply With Quote
Old 07-11-2005, 11:37 PM   #649
Ghostfit's Avatar
Originally Posted by ttso
Something very odd need to be noted:
The diff seems too narrow to fit in bulkhead. I see at least 1mm space from pushing diff all the way left and all the way right. Checked over and over and nothing is wrong, strange problem. Same problem happened on center pully, about 1mm space from pushing pully all the way left and all the way right. Seems it need lots shim on diff...
Tamiya sells 10mm shims and I've added a 0.3 to each side of the diff. likewise shimmed the centre pulley shaft. ...no problems !
Old 07-11-2005, 11:47 PM   #650
danjoy25's Avatar
my bad, its actually a Reedy 447 clip on heatsink with fan.
pics attached.
Old 07-11-2005, 11:49 PM   #651
vi3tishduy's Avatar
Wo! That baby is awesome haha! Whats more important, cooling of esc or the motor? also, whats the part number!!
Old 07-12-2005, 12:35 AM   #652
Ghostfit's Avatar
I'm ordering my TA05 tommorow. Is the chassis that "soft"?
Shame on you, vi3tishduy ! ...I can't believe you still haven't bought your TA05 yet !
Old 07-12-2005, 01:33 AM   #653
ttso's Avatar
Ok, so it's normal have a huge play on diff and center pully. I just afread I did something wrong causing the play.
ttso is offline   Reply With Quote
Old 07-12-2005, 06:36 AM   #654
rayman's Avatar
Originally Posted by Besercoe
Out of the box, with protoform body, sorex wheels, KO VFS speedie, HRS Receiver, Futaba 9550, Monster motor and IB3600's my car weighed 1540. So i wouldnt classify it as a pig.
That's too bad. I was hoping it had less plastic parts and lighter drivetrain than a tbo2. But I'll see how it accelerates even if its heavy it might pull better than a tbo2.
Anyone know the yen price? Its somewhere on the box. I cant believe this would be cheaper than a tbo2.
My 3D Gallery Website
rayman is offline   Reply With Quote
Old 07-12-2005, 06:40 AM   #655
rayman's Avatar
Finally, I got my SS ESC mounted on TA05. It need 8mm rubber under ESC to mount it higher for more space.
As for "soft", indeed after everything on, the chassis flex is ok, but still no good for my standard. However, damper tower is really way too soft and there is nothing to fix it except CF hopup. Seriously I suggest everyone going to race TA05 get CF damper tower as a must.
That esc is very close to the motor.
Old 07-12-2005, 06:51 AM   #656
vi3tishduy's Avatar
Hm... This car will definetly be faster than a TB02, its newer, better design. I believe, this car can be competitive with any car out today... Maybe we should start comparing it with like, the 415, BD, Xray lol RDX...
Old 07-12-2005, 09:32 AM   #657
ttso's Avatar
Black swing shaft is LW suspension wheel axis (48mm swing shaft)
Blue swing shaft is old suspension wheel axis (46mm swing shaft)
old suspension = TA04, 414, 415, TA05
new suspension = LW suspension = EVO4, 415MS, EVO4MS, TB02R
will photo the different of wheel axle after I get home tonight.
Old 07-12-2005, 09:41 AM   #658
ttso's Avatar
ttso those ae turn bucks fit?
just put suspension on, AE turnbuckle fit. Im using 6 28.5mm length AE blue titanium, 4 for upper camber link, 2 for steering link, all 28.5mm (sorry, i don't know parts number, it was from my old TC3).
Old 07-12-2005, 09:44 AM   #659
ttso's Avatar
Default Building completed
After 2 nights fighting, I got my TA05 ready Time to clean up my desktop and partial charge a battery to do functionality testing...
Old 07-12-2005, 09:57 AM   #660
lem2's Avatar
I just fit a 17T pinion from my Mini onto the TA05, and it looks like it has enough space on the mount for a 16T for sure...
Would be a good ratio for 19T and mod motors?
I guess they were just too lazy to put out the whole pinion chart on the sheet. They wanted to make the 105T option look that much more desirable. Sure, you get a great range of ratios, but they can strip out a lot easier if you don't mesh them right... plus they're more expensive than the regular AV pinions.
Pulleys: 36/16 = 2.25 IR
Spur: 70T
Pinion Spur/Pin Final Ratio
16 4.38 9.844
17 4.12 9.265
18 3.89 8.750
19 3.68 8.289
20 3.50 7.875
21 3.33 7.500
22 3.18 7.159
23 3.04 6.848
24 2.92 6.563
25 2.80 6.300
Does anyone sell 48-metric 26+ pinions? It sure looks like there's enough mount space to fit larger ones than 25. Although our TCS rules limit the max ratio to 5.7, it looks like we may never hit that mark with the TA05.
Theoretically, we could see 3 more with aftermarket pinions...
26 2.69 6.058
27 2.59 5.833
28 2.50 5.625
I know people were looking for larger ones for the TB-02 and the 52T Spur... any luck?
Tamiya Makes a 26 pinion(their largest). Thats the biggest when it comes to .6module sizes. Kawada and Tobee craft makes .6module pinions up to size 30t.
Would the TA04 83t spur fit the 05? The 70t spur will really be nice on my other kits, I have a complete set of pinions from 15-30 .6module. I find it quiter than the standard 48 pitch. You could get the pinions at R10.
And also will the 04 Aluminum diff gear fit the 05?
Peace!!!
Seeing you guys makes me want to get one when itreaches our shores!!!
lem2 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
