Like Tree2Likes
Old 02-05-2007, 08:24 AM   #6511
tc3team's Avatar
Originally Posted by or8ital
I put a different spur gear on and it got lots better. I think I assumed the spur was 48P but it isnt (at least not the same 48p).
the stock spur gear is 0.6 pitch,which looks a little like 48dp but isnt.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-05-2007, 08:26 AM   #6512
tc3team's Avatar
I managed to put the layshaft assembly in the wrong way round, so youre not the only one to have made a mistake building one
I got the 3racing chassis that im building it to, and wondered why I couldnt fit the top deck on wasted so much time,lol
Old 02-05-2007, 08:49 AM   #6513
Regional Moderator
Darkseid's Avatar
Originally Posted by Hebiki
and Darkseid is right... not everyone is lucky enough to race at the Tamiya track like some of us
Just keep rubbing it in why don't ya!
TLR 22...Tamiya F104...
Old 02-05-2007, 09:33 AM   #6514
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by agp
hi guys, tinking of changing my TA05 some of my parts to evo5 parts.
1. front and rear suspension arm
2. rear hub
3. front C-hub
4. front steering knuckle...
will it fit ta05?
Yes, but there is much more you will need.
Check out the contents of 53899 with that kit you will need to get swingshafts. (your's might work) the EVO 5 susp uses a different axle and bearing, there is alot that comes in the kit.
tamiyarcracer is offline   Reply With Quote
Old 02-05-2007, 10:18 AM   #6515
diha's Avatar
HI Guys,
Has anyone tried the 3racing center pulley for TA05?
It come in a pack of 3 for 16Teeth, 17T & 18T.
It will change the internal ratio from 2.25 to 2.18 to 2 respectively.
What's the effect of doing so???
Thanks.
diha is offline   Reply With Quote
Old 02-05-2007, 03:57 PM   #6516
quantum's Avatar
Originally Posted by Geppetto
What exactly is the LWS, and what is it supposed to do to improve the handling characteristics of the TA05 chassis?
I'm not looking to put more $$$ into my TA05 other than universals and alloy shocks, but all the discussion has made me curious?
Any photos of the LWS?
a lighter suspension system means lower unsprung weight, which will provide better response (ie. Hebiki's comments about precision). but the question is, will you notice a difference, and is it worth the cost?
if you are new to the hobby/novice racer, or running roar 27t stock motor, or tamiya black can/silver can motors, then you probably won't notice as much of a difference. i have both suspension sets and the weight difference is significant. some people say the LWS is more fragile than the standard, which it is, but i have not had any issues.
if you have to choose between alloy shocks and universals vs. the LW suspension, get the shocks/universals for sure. but don't mistake that to mean the LWS is useless, because it certainly isn't!
quantum is offline   Reply With Quote
Old 02-05-2007, 05:10 PM   #6517
m3ndo5a's Avatar
Originally Posted by diha
HI Guys,
Thanks.
The closer your car drivetrain is to 1:1 ratio the faster your car will reach its top speed. Less Rotation.....
m3ndo5a is offline   Reply With Quote
Old 02-05-2007, 06:28 PM   #6518
guinnes.s's Avatar
hello guys,what is the difference beetween this two insert???can you elaborate please,thank you
guinnes.s is offline   Reply With Quote
Old 02-05-2007, 09:43 PM   #6519
P956LH's Avatar
By the looks of it the grey ones are the kind of cheap inserts you'd get free with some tires (i.e HPI's scale rubber tires, like the Super Radial and X-Patterns). They aren't that great handling-wise, because they aren't stiff enough to support the tire's carcass (you'd end up with the sidewalls flexing and the car being generally unresponsive...well that's what happened to me anyways). Having said that, they're much lighter (and cheaper) so they're better for bashing around with.
The yellow ones are (I think) the "molded round" HPI inserts, where the foam used is much denser and stiffer than the grey ones. They provide much better support for the tires (less sidewall flexing) and generally provide more responsive handling. I prefer this set (I use the X-patterns with the "soft" version of this insert for parking lot racing).
Just my 2cents...
TL-01, TB-02R, RS4 Pro 3, TA05R, Desert Truck.
P956LH is offline   Reply With Quote
Old 02-06-2007, 09:00 AM   #6520
proceed5's Avatar
Default Tamiya TA05-R
Source: http://www.tamiyausa.com/product/ite...oduct-id=49418
Tamiya have released some details about their upcoming electric chassis, the TAO5-R. Based on the TAO5, the new R version is a specially-tuned race version kit loaded with option parts for the circuit, and it is packed full of options a list of which you can see below.
- All-new aluminum center plate, blue anodized aluminum spur gear holder, and carbon fiber damper stays reinforce the chassis while reducing weight.
- Impressive list of included option and spare parts:
51000 High Torque Servo Saver (Black)
51065 TRF415 Suspension Mount (A)
51068 TRF415 Suspension Mount (D)
53539 5.5mm Aluminum Spacer Set
53640 5mm Aluminum Bolt Nut (Blue)
53642 5mm Aluminum Ball Connector (Blue)
53644 Aluminum Stabilizer End (Blue)
53685 TRF415 Front Bridge Suspension Mount (A)
53823 Clamp Type Aluminum Wheel Hub (5mm thick)
53836 48mm Swing Shafts for Assembly Universal Shaft Set
53849 TA05 High Precision Diff Joint
53857 04 GP Spur Gear 105T (TA05)
53869 5mm Aluminum Short Ball Nut (Blue)
53871 48mm Lightweight Rear Swing Shafts (Blue)
53874 TA05 High Precision Center Pulley Bushing
53894 TA05 Carbon Reinforced A Parts
53895 TA05 Carbon Reinforced K Parts
53897 TA05 Aramid Drive Belt (Blue)
53899 Reversible Lightweight Suspension Set
53918 TRF Damper Low-Friction V Parts
53935 TA05 Wide Pitch Diff Pulley
- TRF Dampers (Blue), Damper Springs (White), Front/Rear Stabilizers, and Aluminum Turnbuckle Shaft (Blue) are also included in this assembly kit.
- R/C system, ESC, battery, body, motor, tires, and pinion gears are sold separately.
proceed5 is offline   Reply With Quote
Old 02-06-2007, 09:32 AM   #6521
Aluma's Avatar
Is the 05R designed for parking lot racing or for carpet?
I wouldnt mind getting one if it was for asphalt...hopefully faster than my 02R too.
Aluma is offline   Reply With Quote
Old 02-06-2007, 09:36 AM   #6522
muahdib4's Avatar
Send a message via Yahoo to muahdib4
The TA05 and the R version work great on carpet or asphalt. Setup involved is a little different but it works great both places and with the plastic tub you don't have to freak out if you scratch it a little on the asphalt.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 02-06-2007, 10:45 AM   #6523
TEM
TEM's Avatar
Whats the weight difference in grams? (please specify if it's the arms, hubs and knuckles only or with all the hardware)
TEM is offline   Reply With Quote
Old 02-06-2007, 07:19 PM   #6524
quantum's Avatar
a local racer said his tb02 lost about 40 grams after switching to the lws...i'm skeptical its that much.
i don't have access to a scale at the moment, i'll try to weigh it the next time i'm at the track. but to give you an idea... the bearings are smaller (x8), and the axles are shorter (x4)...its much less metal, not to mention the lighter plastic/molded carbon parts.
Old 02-06-2007, 07:21 PM   #6525
quantum's Avatar
can anyone confirm that the nissan calsonic body 51184 fits the ta05 properly? its not listed as a compatible chassis on the parts page so wanted to check before buying
thanks
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
