Like Tree2Likes
Old 01-08-2007, 10:43 AM   #6211
Originally Posted by proceed5
Titanum Lightweight Screws Set for TA05 = 49360
Super lightweight Blue Aluminum screws (sold in package of 5):
Round 3x8 = OP766 #53766
Round 3x10 = OP767 #53767
Countersunk 3x8 = OP772 #53772
Countersunk 3x10 = OP773 #53773
Countersunk 3x12 = OP774 #53774
thanks proceed5..
i feel right at home in this thread..
any thoughts with the 3racing chassis? the normal black one..
feedbacks:
http://rctech.net/forum/showthread.php?t=152727&highlight=pacific17
http://rctech.net/forum/showthread.php?t=154954&highlight=pacific17
pacific17 is offline   Reply With Quote
Old 01-08-2007, 10:46 AM   #6212
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by pacific17
what do you mean upgrade the rear diff? replace the outdrives? upgrade the turnbuckles? with what?
diff outdrives, can be upgraded to the precision plastic, or to aluminum.. Turn buckles, can be a better steel unit, Titanium, or aluminum. The reason I don't like the kit units, is they are very hard to adjust you have to use pliers, with the Ti ot alum tamiya makes a turnbuckle wrench.
tamiyarcracer is offline   Reply With Quote
Old 01-08-2007, 10:48 AM   #6213
Talking
Originally Posted by nexxus
Guys I am throwing my FK05 at a wall and returning to my Humble TA05...
What arms are direct replacements for the ones in the lightweight suspension set (ie in case hack me breaks one)
Also any suggested gearing on a Novak SS13.5 Stock Brushless on the standard spur?
Suggested hop ups? Have settled on Lightweight Suspension set, have the TRF Dampers and Lightweight Screw Set and Aramid Belts, and am looking towards a front one way and alloy outdrives for the rear. Anything else going to help me?
have you tried a 21 pinion with the stock 70 spur.. or 20? i think that would be okay.. 70/21 is 7.5 and 70/20 is 7.8.. just my opinion..
feedbacks:
Old 01-08-2007, 03:33 PM   #6214
FreqETag's Avatar
Talking
Like to see what people have in the way of carpet foam setups? As has been stated here, not much out there to look at!
We're running 4300 Brushless/LiPo/Foam Touring here. Two guys running them and fast but both are slightly different setups. Just like to see what others are doing.
Maybe someone has a setup from the Novak Race??
Thanks Much!
FreqETag is offline   Reply With Quote
Old 01-08-2007, 10:57 PM   #6215
proceed5's Avatar
thanks proceed5..
No idea how the 3Racing chassis would be like, but I have long time ago upgraded my TA05 chassis to the Tamiya Lightweight Carbon Reinforced Chassis and it is good in my opinion (apart from the Car's overall weight being right at the limits). The Chassis provides a sharper overall response to my TA05. I particularly liked the TA05 for its good weight transfers.
Had I earlier bought an aftermarket Graphite Chassis (Xenon / Kawada) for my TA05, I would not have bought a 415MRE.
proceed5 is offline   Reply With Quote
Old 01-08-2007, 11:36 PM   #6216
Super Moderator
Grizzbob's Avatar
Originally Posted by tc3team
Yup, & a few others too(who helped me get mine running strong).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-09-2007, 09:04 AM   #6217
Thanks Much!
i have a foam carpet set up for my ta05.. im still playing with it.. but its decent enough.. i dont know about the novak..
feedbacks:
Old 01-09-2007, 09:06 AM   #6218
lol.. i like the ta05 because of how balanced the chassis is.. and you know.. prove to people that the ta05 can kick ass.. lol..
feedbacks:
Old 01-09-2007, 05:30 PM   #6219
Anyone know where to get blue aluminum 46mm swing shafts? I checked all over Tamiya's website, all they had were black and/or 48mm swing shafts. Also, are the Tamiya universals (53847) made out of steel? I recall one of you folks saying to run aluminum cvds in the rear and steel in the front.
gerok is offline   Reply With Quote
Old 01-09-2007, 05:47 PM   #6220
53724 is the 46mm LW (blue aluminum) swing shaft
51094 is the 46mm (steel) swing shaft
53836 is the 48mm (steel) swing shaft
53871 is the 48mm LW (blue aluminum) swing shaft
for the axle, 51094 is steel, 53718 is Titanium, and 53939 is Aluminum.
What people are saying is they run aluminum swing shafts in the rear, and steel up front.
53847 is made of all steel componants. (51094 [steel], 53500, and 51092 [steel])
hope that answers those questions.
if you want a lightweight axle you need to build it with parts, pick a axle, pick a swing shaft, and use 53500 cross joints.
Old 01-09-2007, 08:42 PM   #6221
ttso's Avatar
Alum diff roll much more freely, even more freely than high prec plastic one. I got instant laptime reduced after install Alum diff. I would say it's a must for racing...
Alum swing on rear and stell swing on front is for safty as crash kill alum swing. So if you don't crash, go full Alum front/rear is fine. Ti axle is for weight saving, and it save a LOT of weight from TA05, also make the roll freely as less weight to roll, but costy.
ttso is offline   Reply With Quote
Old 01-10-2007, 01:33 PM   #6222
Regional Moderator
Darkseid's Avatar
Originally Posted by DA_cookie_monst
The stock outdrives lasted 18 months, till I sheared a kingpin, so wearing them out that quick!!!! you must be doing something
Same here...
And I'm still using mine. They've spread a little, but amazingly enough, the universals(and dog bones before those) have grooved them very, very little. To the point where you hardly even notice.
TLR 22...Tamiya F104...
Old 01-10-2007, 09:00 PM   #6223
Have any of you folks ordered from fastener-express.com? I couldn't find any reviews for the site but I do need a few screws for the TA05.
Old 01-10-2007, 09:06 PM   #6224
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I've ordered from them once...no problems
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-10-2007, 09:11 PM   #6225
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Yep, I've used them lots of times, although if your looking for a "Tamiya" blue...they are a little dark.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
