Like Tree2Likes
Old 01-07-2007, 03:38 AM   #6181
just a? do you have part numbers? thanks..
feedbacks:
http://rctech.net/forum/showthread.php?t=152727&highlight=pacific17
http://rctech.net/forum/showthread.php?t=154954&highlight=pacific17
pacific17 is offline   Reply With Quote
Old 01-07-2007, 05:12 AM   #6182
nexxus's Avatar
Trader Rating: 302 (100%+)
Guys I am throwing my FK05 at a wall and returning to my Humble TA05...
What arms are direct replacements for the ones in the lightweight suspension set (ie in case hack me breaks one)
Also any suggested gearing on a Novak SS13.5 Stock Brushless on the standard spur?
Suggested hop ups? Have settled on Lightweight Suspension set, have the TRF Dampers and Lightweight Screw Set and Aramid Belts, and am looking towards a front one way and alloy outdrives for the rear. Anything else going to help me?
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 01-07-2007, 05:46 AM   #6183
i could only suggest is the universals if you dont have it yet.. you could try the high precision diff outdrives(which ever you prefer).. just my 2 cents..
feedbacks:
Old 01-07-2007, 06:05 AM   #6184
ttso's Avatar
Forget about high precision diff outdrives, go Alu diff outdrive (http://www.tamiyausa.com/product/ite...oduct-id=53919) directly! It cost a little bit only, and much more "precision" than "precision diff".
ttso is offline   Reply With Quote
Old 01-07-2007, 06:18 AM   #6185
OllieRDX's Avatar
Send a message via MSN to OllieRDX
You need some carbon pieces and other stuff!
My TA05 is full option but i only drive it for tamiyacup here in Belgian.
Here some pics
| Team Corally | GM Racing | SpeedTech RC Germany | Toni Sport | MobGums | XXX Racing Shop | Black Art | Futaba | Loomans Distribution |
OllieRDX is offline   Reply With Quote
Old 01-07-2007, 06:44 AM   #6186
P956LH's Avatar
@pacific17:
TRF415 Bridge A: 53685
TRF415 A: 51065
Plus you need a set of pivot balls (that go on the end of the inner hingepins): 50994
Cheers...
TL-01, TB-02R, RS4 Pro 3, TA05R, Desert Truck.
P956LH is offline   Reply With Quote
Old 01-07-2007, 12:07 PM   #6187
Default Another Happy TA05 owner
Well I just had my TA05 out for the first club race yesterday! I'm in sportsman class and placed 2 out of 12 so I figure that's a pretty good day! I also had one of the club members drive it and he said he was impressed at how fast it turned! He drives an Xray T2-007 so I figure he knows what he's talking about!
Only broke a servo horn, but that's becuase its an integy servo and I have yet to find something that works nicely on it! Just had to share!
cutwo is offline   Reply With Quote
Old 01-07-2007, 12:15 PM   #6188
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
Well I just thru my 3 racing chassis together and put in some vital thread lock on some of the metal on metal parts that move. I'm so excited. I know it won't help me be a better driver but it sure does look sweet!!!!!!!!
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 01-07-2007, 12:46 PM   #6189
peejay's Avatar
Originally Posted by Jam-ehz
'A' blocks are the same size as the stock TA05 mounts.
They range from:
shortest - XD XC XB XA X A B C D E - longest
Every letter difference gives you a half-degree change.
<snip>
If there's a 1 in there (1A, etc.), I believe they sit 1mm higher than those than don't.
T'other way round 1X - 1E (for the TRF415) are 1 mm lower than the plain X - E mounts (for the TB Evo III, IV, and 5 chassis). The X-series mounts are the same height as the 1-series.
HTH
peejay is offline   Reply With Quote
Old 01-07-2007, 05:58 PM   #6190
Need some help on gearing a TA05 for a 19T checkpoint, does anyone have a spur/pinion combo recomendation?
Hungbrush is offline   Reply With Quote
Old 01-07-2007, 08:03 PM   #6191
Anyone have any experience with this car racing rubber tires on carpet? I would be running an Orion 4800 lipo and a 19t and probably a 4300 bl soon. Love the way the car looks. What would be the bare min upgrades needed or is this car best suited for asphalt racing ? Any info is appreciated. Thx.
wcalaker is offline   Reply With Quote
Old 01-07-2007, 08:39 PM   #6192
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
PLease read the last few pages. for needed hop-ups.
tamiyarcracer is offline   Reply With Quote
Old 01-07-2007, 09:36 PM   #6193
Originally Posted by P956LH
@pacific17:
TRF415 A: 51065
Cheers...
thanks.. =)
feedbacks:
Old 01-07-2007, 09:48 PM   #6194
Super Moderator
Grizzbob's Avatar
Agreed, I've been using the info from here in setting up my '05(as well as some help from the Milwaukee Tamiya gurus like Mike Lack & Nick Bartolone) & just ran it in the Novak US Touring Car Champs in the 13.5 brushless class, & it ran very well, placed it in the B main & finished 5th, little darlin' works VERY well with rubber tires on carpet....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-08-2007, 12:03 AM   #6195
I guess I was looking for more of a set up for rubber/carpet. I looked at the Tamiya website and only found a blank set up sheet and one other but it looked more like an asphalt set up. Basically whats on here are most standard upgrade parts. Was looking for somethign a bit more specific from someone who may run rubber tires on carpet with medium grip. Somewhat technical track but not too tough.
Only one issue I have with thinking about buying this car and that is there are no stores around here (Dallas area) that carry the kit or more importantly parts. Seems I have to purchase everything online which im not to crazy about because I want to support local hobby shops and its an inconvienance to have to order everything online.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
