Like Tree2Likes
Old 12-30-2006, 08:52 PM   #6106
proceed5's Avatar
Originally Posted by juanfinesse
wat are the dimensions for the stock ball bearings in the hubs?
Standard TA05 arms: 1150
Reversible arms system: 950
proceed5 is offline   Reply With Quote
Old 12-30-2006, 10:24 PM   #6107
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Rogier
NICE RIDE!! But do I see Xray dishes on your ride?
Thanks,
... X-Ray may be my next ride ...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-30-2006, 11:01 PM   #6108
JayBee's Avatar
Thumbs up A big thumbs up!!!
I was at the track (SIR- Seattle Indoor Raceway) today so here's a brief report on my plastic TA05....
SiR BTW is a high-bite asphalt track...
Using the same set-up on the car that one of our locals (a former TCS Champion & present TCS past chump) found at TCS Natl's this year, the car is freakin' money. I didn't notice the bumpsteer in the car before so I had to remedy that but a slight tweak that I needed was to go from 2-degree of camber in the front with a 1mm spacer under the front inner camber link to 1-degree of camber with no spacer. Initial turn in was phenominal. And on this particular layout- major turn in is necessary. I know one-ways are sometimes faster but I love the thrashin' I can give the car witha spool in it, so that's what I run with primarily even with a Silver can
I started off with a Checkpoint 19t geared around 6.8FDR, but it couldn't touch my Komodo geared at around a 7.7FDR. I have to play around with that Checkpoint some more The Checkpoint was coming off the track @ about 170degrees but the Komodo... let's just say after 3 packs thrown at it with 8-10min runs, a rest period of 30min in-between & no cuttin', the brush shunts were discoloured
Needless to say, the car 'feels' better to me than the lighter graphite stuff but more importantly- I left the track in high spirits ...
Old 12-30-2006, 11:06 PM   #6109
moshmike's Avatar
Originally Posted by Geppetto
As I mentioned previously, I got my hands on a used TA05. It's in great shape, but I do need a few parts to get it rolling.
Today I disassembled the chassis, cleaned it up, then reassembled it. To get it race ready, I still need:
  • complete front diff
  • front universals
  • front and rear belts
I downloaded and printed out the TA05 instruction manual from the Tamiya website, but the part numbers are not listed. It would be nice if the manufacturers listed the part numbers next to the part in the instruction manual.
I need help getting all of the parts required for the diff. The instruction manual doesn't list universals at all. I've seen the blue belts listed online, but I'd prefer to get the standard black belts.
If anyone knows of a complete parts list that would be nice to have.
Last question... are all of the TA05 parts specific to the TA05, or does it share parts with other Tamiya kits?
Any help would be greatly appreciated.
Thanks!
I suggest to get the aramid belts right away and also the aluminum diff halves. They are so smooth when they are built! Chack Tamiya's website for parts.
BTW, If you have the entire manual like it was original, the parts pictures at the end always have the stock part # by them.
ALSO Thanks to all for the help to my earlier ?'s!!!
Mike
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 12-31-2006, 08:23 AM   #6110
juanfinesse's Avatar
are those dimensions in millimiters? LOL sorry.
Juan
juanfinesse is offline   Reply With Quote
Old 12-31-2006, 09:57 AM   #6111
Trader Rating: 35 (100%+)
Originally Posted by proceed5
Hi Geppetto,
Complete front diff:
(1) One Ball diff pulley #51212
(2) One set Ball diff plate #50880
(3) Two pieces 850 bearings - any brand
(4) One 620 Thrust bearing - (#49300)
(5) Ball diff spring - #49299
(6) One pack of 2x25 Cap screw & 2mm lock nut Set - #49350
(7) Diff Balls 3.0mm - any brands (or try #53379)
(8) Diff joints - (standard parts tree #9115157) or (#53849)
(9) Plastic locknut holder (A parts #51208) or (A parts 53894)
(10) Two pieces 1510 bearings - any brand.
Drive belts - standard 51210
Universal driveshafts standard 46mm Set #53847
Thanks Proceed. Using the numbers you provided, I'm going to try to price
all of the individual parts. Hopefully, I can find a single source.
Geppetto is offline   Reply With Quote
Old 12-31-2006, 10:02 AM   #6112
Mike
moshmike: Thanks for the suggestions. I really feel stupid!!! You're right, the manual that I downloaded does in fact have a parts listing in the back.
Old 12-31-2006, 10:10 AM   #6113
I just went back from the lw suspension kit to the stock setup. I kep the CVD's though cus there the only ones i have, i dont got the stock ones. And when i tried putting the CVD's into the hub, the whole from the stub axle pin that goes in the Wheel hex doesnt come out all the way. Do i have to go back to the stock dogbones as well?!?!
Thanks,
Juan
Old 12-31-2006, 11:02 AM   #6114
RCpurplecow's Avatar
ask people at your track, they should help. the kid who u pit next to can help you too
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 12-31-2006, 11:24 AM   #6115
Hi Geppetto,
OUCH!!!
Using the Horizon Hobby website, I was able to place in my shopping cart all of the parts you listed except the bearings, and cap screw and the total is $99.45 before shipping!
I think that at this point it makes more sense for me to buy a complete kit!
Old 12-31-2006, 11:25 AM   #6116
lbckevin's Avatar
Trader Rating: 91 (99%+)
Try dinball (rcmart.com) or Champ RC on this forum...you email him the list and they send you the info on the items and its cheap.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 12-31-2006, 01:21 PM   #6117
Super Moderator
Grizzbob's Avatar
Thanks,
Juan
It may be that you need the 46mm axles for going back to the original suspension, as the LW one needs the 48mm ones(& I don't know if they'd work with the original suspension, likely banging into the outdrives too much), but you won't have to buy complete Universals, just some 46mm stub axles(they can be bought seperately)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-31-2006, 01:42 PM   #6118
POOKYT's Avatar
Grizz--Are you bringing the TA-05 to Memphis this year? I picked up one just for the TCS race here. Later man!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-31-2006, 01:56 PM   #6119
I do have the 46 mm shafts, its just the hole for the pin in the hex doenst go all the way through the bearings to put the pins in. But thanks.
Juan
Old 12-31-2006, 05:01 PM   #6120
guinnes.s's Avatar
HAPPY NEW YEAR TO ALL THE TA05 LOVERS.
guinnes.s is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
