Like Tree2Likes
Old 12-29-2006, 03:46 PM   #6091
Link don't work
DA_cookie_monst is offline   Reply With Quote
Old 12-29-2006, 03:53 PM   #6092
guinnes.s's Avatar
Originally Posted by DA_cookie_monst
Where can I get some Alloy front and rear bulkheads from chaps?
HERE
plus look what i just find
PRO MODULE
SORTED
guinnes.s is offline   Reply With Quote
Old 12-29-2006, 03:57 PM   #6093
Saz
Saz's Avatar
Hi guinnes.s
The steering knuckles and suspension arms are from the Lighweight Suspension set (#53899), this set also includes aluminium hex drives, wheel axels, bearings and polymer rear uprights. If you do get the set you will need 48mm or 46mm swing shafts for the front and rear (I went with steel 48mm front and alloy 48mm rear shafts). The length will depend on which suspension mounts you will use, if you are using the wider suspension mounts then use the 46mm swing shafts. The rear uprights are the aluminium Evo ones (1 degree, #53874), though the 0 degree upright can be used. The angle of the rear uprights will also depend on what selection of suspension mounts you will use.
The white sponge on the ball links is to reduce the dirt/gunge which can get onto the ball surface. This should keep the ball joints in better condition for a longer period. Those particular foam rings are Associated parts.
Saz is offline   Reply With Quote
Old 12-29-2006, 06:54 PM   #6094
juanfinesse's Avatar
UHH i have Evo 5 arms, knuckles and hubs. They break so easily, and i dont wanna buy the old TA-05 arms hubs and knucles cus then i have to get new bearings for the front cus the sizes r different.
juanfinesse is offline   Reply With Quote
Old 12-29-2006, 09:01 PM   #6095
JayBee's Avatar
Trader Rating: 31 (100%+)
Just for shnitz-n-giggles, I rebuilt my TA05 with all the plastic kit bits. Is anyone running their car like this? I haven't had a chance to try it out yet but it seems like it will have a bit more mechanical grip?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-29-2006, 09:40 PM   #6096
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
my all-stock TA05 likes to skip its front belt under acceleration while turning, other than that, I totally dig it
that one problem though has me thinkin about upgrading to the 3racing chassis
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 12-30-2006, 02:41 AM   #6097
Rogier's Avatar
NICE RIDE!! But do I see Xray dishes on your ride?
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 12-30-2006, 07:49 AM   #6098
guinnes.s's Avatar
Originally Posted by TAMIYAMANUK
Last day to go on the 05 and it isnt even got to half what i paid for it so somone is getting a true bargin indeed
[http://cgi.ebay.co.uk/Tamiya-TA05-TR...QQcmdZViewItem
Well look like i won it
btw,i just paid too
Old 12-30-2006, 10:52 AM   #6099
Youv'e got a good buy there guinnes.s Are you going to use another chassis with it or keep with the tub chassis?
Where are you going to race it?
Sazzle is offline   Reply With Quote
Old 12-30-2006, 12:37 PM   #6100
guinnes.s's Avatar
will keep the tub chassis as i would like to use it on tarmac out door,and keep my N.1 for indoor
Old 12-30-2006, 03:35 PM   #6101
Send a message via MSN to TAMIYAMANUK
cheers dude she already and wrapped up and should be with you sometime in the week and what a bargain you have got as well
TAMIYAMANUK is offline   Reply With Quote
Old 12-30-2006, 05:23 PM   #6102
Trader Rating: 35 (100%+)
Default I need help putting it all together!
As I mentioned previously, I got my hands on a used TA05. It's in great shape, but I do need a few parts to get it rolling.
Today I disassembled the chassis, cleaned it up, then reassembled it. To get it race ready, I still need:
  • complete front diff
  • front universals
  • front and rear belts
I downloaded and printed out the TA05 instruction manual from the Tamiya website, but the part numbers are not listed. It would be nice if the manufacturers listed the part numbers next to the part in the instruction manual.
I need help getting all of the parts required for the diff. The instruction manual doesn't list universals at all. I've seen the blue belts listed online, but I'd prefer to get the standard black belts.
If anyone knows of a complete parts list that would be nice to have.
Last question... are all of the TA05 parts specific to the TA05, or does it share parts with other Tamiya kits?
Any help would be greatly appreciated.
Thanks!
Geppetto is offline   Reply With Quote
Old 12-30-2006, 07:47 PM   #6103
the TA04 shares a few parts and about the parts list its isted on the back of the manual i think
Old 12-30-2006, 08:32 PM   #6104
proceed5's Avatar
Originally Posted by Geppetto
I still need:
  • front universals
Thanks!
Hi Geppetto,
Complete front diff:
(1) One Ball diff pulley #51212
(2) One set Ball diff plate #50880
(3) Two pieces 850 bearings - any brand
(4) One 620 Thrust bearing - (#49300)
(5) Ball diff spring - #49299
(6) One pack of 2x25 Cap screw & 2mm lock nut Set - #49350
(7) Diff Balls 3.0mm - any brands (or try #53379)
(8) Diff joints - (standard parts tree #9115157) or (#53849)
(9) Plastic locknut holder (A parts #51208) or (A parts 53894)
(10) Two pieces 1510 bearings - any brand.
Drive belts - standard 51210
Universal driveshafts standard 46mm Set #53847
proceed5 is offline   Reply With Quote
Old 12-30-2006, 08:46 PM   #6105
wat are the dimensions for the stock ball bearings in the hubs?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
