Like Tree2Likes
Old 12-27-2006, 09:15 AM   #6061
juanfinesse's Avatar
yeah it was the bottom. how do you rebuild shocks? just take em apart and rebuild them, or is there a special process involved?
Thanks,
Juan
juanfinesse is offline   Reply With Quote
Old 12-27-2006, 09:59 AM   #6062
moshmike's Avatar
Originally Posted by moshmike
Hi! Wondering what the short EVO 5 arms do for the car compared to the regular LW arms. and also do you need to use shorter swingshafts with those?
Thanks! Mike
anyone???
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 12-27-2006, 10:10 AM   #6063
tc3team's Avatar
Thanks,
Juan
Most shocks have 1 or 2 O rings inside them that wear after time, you may not notice the wear just by looking at them, but it is a very small tolerance. They are pretty cheap to replace and would be the first thing to check
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 12-27-2006, 10:14 AM   #6064
Thanks! Mike
Hey Mike, put rc10gt arms and axles on it. Wider is better.
RCAmerica | Xray | Team Tekin | RC Paint By Sonny | P1 Brand
Monte Hess is offline   Reply With Quote
Old 12-27-2006, 10:19 AM   #6065
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks! Mike
mike, if you go with the evoV arms. you cant use the 48mm swing shafts. it'll bind from what i remember. 46mm works. not sure about 42? havent touched my TA05 since Nats.
set up wise.... it reacts quicker.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-27-2006, 10:21 AM   #6066
moshmike's Avatar
Thanks!!!
Monte!!! NO THANKS!!! See you soon?!
Old 12-27-2006, 10:24 AM   #6067
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
anyone???
Mike as for the swing shaft it all depends on what susp arm mounts you use.
If toy run D bridge blocks and toe in rear uprights you can get away with 48mm swing shafts.
as for the how it changes the car, I would say is is more like the stock sups, wich shouls be better for carpet. I ran the EVO 5 arms on MY TA05 at Tamiya worlds.
tamiyarcracer is offline   Reply With Quote
Old 12-27-2006, 10:31 AM   #6068
Thanks!!!
Just trying to help you out next week.
Old 12-27-2006, 10:40 AM   #6069
moshmike's Avatar
I have the A blocks up front with the LW arms. I am going to run it at the Novak race in Brushless. Last week it was very good but tire wear was high. I lowered the role center last night and it felt a bit more controlable.
Also getting it ready for the TCS at Trackside. Gotta try to beat Leester once more before he heads out west to Cali!
Old 12-27-2006, 10:40 AM   #6070
moshmike's Avatar
What classes you running?
Old 12-27-2006, 10:49 AM   #6071
If you slap the arms on your car they way it is now, you will need the 46mm swing shafts, and the track width will be narrower.
Old 12-27-2006, 12:27 PM   #6072
moshmike's Avatar
Is it better to run the D blocks and have the width wider or leave it narrow? I never played with the width much.
So D blocks+48mm shafts,ok
A blocks + 46mm shafts,ok
What width do you fast guys run?
Old 12-27-2006, 12:31 PM   #6073
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I believe a narrower car is more aggressive and wider is more stable.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-27-2006, 01:05 PM   #6074
proceed5's Avatar
IMO, if you are using the Short Reversible Arms, should use the A blocks.
proceed5 is offline   Reply With Quote
Old 12-28-2006, 09:06 AM   #6075
ooliganRC's Avatar
Send a message via MSN to ooliganRC
hey all, just bought a second hand ta05 and its pretty standard except for 3 racing chassis conversion and translucent blue diff/bulkhead things.
a couple of things.
1. is it worth buying my mates 415msx as spares?
2. where can i find decent set ups for it need one for rubber carpet and outdoor tarmac.
3. anything you guys recommending as maintenance/hop-ups
cheers in advance
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
