Tamiya TA05 Touring Sedan
#5986
Regional Moderator
Originally Posted by Mr.Roboto
hey fellas a ss5800 is cumming into my possesion next wek and just wondering can i run it on the standard pinion and spur(22tp,70ts)??if not wat would u reccomend im looking for a bit mor accelleration over top speed.
The ss5800 performs pretty much like a mild machine wound mod motor. So with the stock gearing giving you a 7.16 final ratio, you should be safe with that gearing. Now if your looking for more acceleration over top end, then just go down a tooth on the pinion. Like down to a 21 tooth pinion. Which would leave you at a final ratio of 7.5. That should be perfect for what your looking for.
Hope this helps.
#5987
Regional Moderator
Originally Posted by sportpak
Has anybody seen this yet on eBay? Holy smokes. $50 shipping. I figured it'd be salty, but it's crazy what these first batch of cars are going to sell for.
http://cgi.ebay.com/Tamiya-49400-Por...QQcmdZViewItem
Thats just nuts!
I don't care if they're only making 2 of the things, no way I'm dumping that much cash on a car that I probably wouldn't even run.
#5988
The thing is they are like $500 new so it isn't that much of a markup. Even the guys at Tamiya USA weren't able to get their hands on one and don't know how many are being made.
What do you guys do to your TA05s after practice and races as far as rebuilding and such? What about in between runs?
#5989
hi guys,
im running 48mm universal shaft on the from on this babe. but realised that the shaft is hitting the diff screw. any disadvantage on this?
any advise guys? should i change to 46mm shaft?
#5990
Originally Posted by agp
hi guys,
Are you running the LW suspension or the normal suspension? I think the 48mm shafts are for the LW suspension.
#5991
#5992
Regional Moderator
#5993
Regional Moderator
me using the normal suspension arm. so i guess i should change to 46mm..
In addition, the shafts being too long can limit suspension travel.
Lastly, if you happen to take a hard hit to the wheel, something will have to give. And since the shafts are already at the diff, this likely will mean a bent universal shaft.
So grab a pair of the 46mm shafts and save the 48mm shafts for if you ever decide to try the LW reversible suspension.
#5994
Originally Posted by Darkseid
Definitely change to the shorter shafts. When the shafts hit the diff, it pushes the diff to the other side. When this happens, it pushes against the other universal shaft and creates drag and hinders diff action.
thx dude for the advise. guess i will have to drop by a hobby shop later to grab mysself a new 46mm shaft.
#5995
After a run and after each race, I discharge my cells on an integy discharger. As for my car, I take a small acid brush and try to brush out most of the left over lint and rocks. Now that I have the 3 racing chassis, more carpet should flow out since it opened the diffs more. I also retighten screws as needed. That might be the most important thing I do.
#5996
Well since no body else answered, guess I'll take a shot at it.
Hope this helps.
Hope this helps.
#5997
any1 know if TA05 urethane bumper are same with TB02 or any other tamiya's car? I have difficulty finding the ta05 urethane bumper. all out of stock.
TB02's urethane bumpers seem alike. can they be use on TA05?
#5998
yes....
they are the same, so you can use the tb02 urethane bumper for the TA05.....
#6000
You can also use EVO4 bumper.
