Like Tree2Likes
Old 07-10-2005, 10:17 AM   #586
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Originally Posted by Jam-ehz
The pitch is 48-metric, and it has 70 teeth. The new one they'll release for it will be 105T at the smaller .6 module for a much larger range of ratios.
It comes with a 22 tooth pinion, and it's fine for most stock racing, silver can or sport-tuned, i believe. Anything like 19 Turn and less will need maybe 20T and smaller, though I don't know how small it will allow...
If you've had a Tamiya kit before, you'll probably have a 19T pinion somewhere...
Hope this helps
vi3tishduy is offline   Reply With Quote
Old 07-10-2005, 10:32 AM   #587
vi3tishduy's Avatar
ttso heh, i'm glad for you! Can't wait to see wait it looks like, and to see if the ae ti buckles fit
Old 07-10-2005, 01:50 PM   #588
Ghostfit's Avatar
Originally Posted by A-Ko
What kit did you use to hopup your TA04? Was it the 415/evoIV conversion?
Jeff
I started off with the TA04-TRF and add the TA04/TB02 LW reversible arms set.
Oh yes, also changed to the super conductive LW graphic reinforce Tub chassis version 3. as I hate to scrape the lovely SSG chassis on tarmac.
Ghostfit is offline   Reply With Quote
Old 07-10-2005, 02:06 PM   #589
Registered User
Originally Posted by over gear
Does TA05 use the same steering bellcrank as the trf415 ??
I do has one but not fit on TA05 because TA05 steering bellcrank is smaller than TRF415's.
shevchenko2000 is offline   Reply With Quote
Old 07-10-2005, 02:10 PM   #590
Ghostfit's Avatar
Hiya all ! ....I'mmmmm backakk !
I have to apologise to all for not being able to proceed with the test drive review and can only offer these 4 lame excuses:
Excuse #1
My tool's too short ! and I dun believe in using non-hardened tools ! .....As you can see from the pic below there is a good 1" gap between the tool's tip and the motor mounting screw hole. The kit does however supply the longest 2.5mm L shaped allen key I've ever seen. Oh well, I just have to go hunt for a longer hex driver. Can't run the car If I can't mount the motor
Excuse #2
I got a Nosram Evo ESC laying around and was thinking of using it
but the Red casing kinda clashes with the rest of the car so like a True Blue Tamiya fan (No pun intended) decided to go buy a LRP Q2.
However on the way to the LHS, an garbage dumpster went pass and something flew out and hit me on the head, When I took a look at the object, it was a box with some wordings like KO VFS-1 Pro and inside I found this ! .......(Yeah, Yeah ! right !)
Now the problem is that I do not know what settings this KO esc is at (Stock or Mod) pending the purchase of a handheld programmer/ PC interface or another Garbage truck passing by. Anyone familiar with this ESC ?
Chris ? ....I need to know what profile is the factory default setting good for.
Another related problem is that the stock TA05 gearing ratio is from 7.50:1 to 6.30:1 .....neither Stock nor Modified ?!?
Here a pic of the Electronics I'll be putting into the TA05.
Excuse #3
Checking the car I found that I've only got 1 degree of rear toe in with the LW arms and stock Susp blocks. dun think this will work at my local track, I guess I've got to wait for the 415 Susp blocks after all !
Excuse #4
Have been working (day job) 7 days a week without breaks for 2 weeks now, dead tired and sleepy.... sometimes .... starting to hallucinate things now !... ...I see garbage trucks full of R/C stuffs running around everwhere ! ...yawn ! .....goodnite all ! ...zzzzzzzzz
Old 07-10-2005, 03:39 PM   #591
Ballsie's Avatar
Hi All,
Could someone scan the instruction manual of this car for me please? I would like to review it before I get the cash out and buy one.
Many Thanks,
Alan
Ballsie is offline   Reply With Quote
Old 07-10-2005, 04:25 PM   #592
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
ghostfit,
Almost got me jeolous until I saw a Hitec servo Very nice looking car though.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-10-2005, 06:06 PM   #593
vi3tishduy's Avatar
Rich people these days... Geese.. by the way that norsam esc, i've never seen taht before is it european or asian esc?
Old 07-10-2005, 06:06 PM   #594
vi3tishduy's Avatar
I forgot to ask, how much was that motor and what is it? stock 540 27t motor?
Old 07-10-2005, 06:17 PM   #595
danjoy25's Avatar
Pretty sure the esc is rebadged Quantum/MC800 unit
Old 07-10-2005, 06:18 PM   #596
lem2's Avatar
Thanks 4 the reply!!!
NOSRAM is European, Its what hara uses before and (i think) they are the ones making the Twister ESC by HARA. The Functions are almost the same as the Quantums. I have a lower end version of NOSRAM ESC (Dominator) as my backup its only has an 11T limit, compared to the LRP Q ProSport which is cheaper and can handle 8T the LRP has more value for money.
lem2 is offline   Reply With Quote
Old 07-10-2005, 06:57 PM   #597
vi3tishduy's Avatar
what about the motor? phantom?
Old 07-10-2005, 07:59 PM   #598
danjoy25's Avatar
Motor is a Team orion Revolution V2, not sure what turn though
Old 07-10-2005, 08:46 PM   #599
fire929's Avatar
Default Hey Ghostfit
Do you have to take the A2 bearing holder out to adjust belt tension trying to adjust front and rear belts.?
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 07-10-2005, 08:53 PM   #600
fire929's Avatar
Default Gearing problem
Use another 64 pitch spur 70 tooth offers no options for any motor exp stock.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
