Like Tree2Likes
Old 12-13-2006, 03:24 PM   #5926
Put the blue one in the back, but it would be best if you got one for the front aswell. Rember to reset the belt tension after and when the belts begin to strech.
savageguy is offline   Reply With Quote
Old 12-13-2006, 05:06 PM   #5927
juanfinesse's Avatar
allright thanks!
juanfinesse is offline   Reply With Quote
Old 12-13-2006, 07:47 PM   #5928
Super Moderator
Grizzbob's Avatar
Right, the ones I bought were both slightly different when brand new so I had a different tension settng on both ends(I think I moved the rear one more than the front, by 1 notch or so), & then after a half dozen runs or so I had to readjust them(went about 1 notch tighter both ends) & they seem to have settled since then....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-13-2006, 10:42 PM   #5929
Viat's Avatar
Trader Rating: 24 (100%+)
I just ran for the first time last week with the front and rear blue belts (with the 7.54:1 ratio) and I had to re adjust front one, 3 times in 9 battery packs that day and the rear one only 1 time.
I would say if replacing only one original belt, then replace front one first, because it looks like the front one breaks on this Chassis first. In other words front one receives more stress then the rear.
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
Old 12-14-2006, 07:05 AM   #5930
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I have about 200 runs on my blue belts and have yet to readjust them. They have stretched very little...and have never skipped.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-14-2006, 09:12 AM   #5931
My front Blue belt took a walk after about 30 runs....
DA_cookie_monst is offline   Reply With Quote
Old 12-14-2006, 10:38 AM   #5932
OscarF1's Avatar
It seems that the amount of stretch depends on de power you put in the car.
My son and I drive 19T stock and the belt stretched only after the first 5 accu's.
The belts are now after about 80 accus ( each ) still in top shape.
What engins did you use ?
Funny, on the belt it says " NO CRIMP "
well : WE KNOW !
OscarF1 is offline   Reply With Quote
Old 12-14-2006, 10:41 AM   #5933
Well, I've run anything between stock to brushless 4300...most of which, probably 99% was 19t and brushless...brushless foam I might add (which puts gobs of strain on the belts). And like I said before. I set mine 1 dot looser than the stock belts and have yet to have to readjust them...maybe I just got lucky???
Old 12-14-2006, 10:46 AM   #5934
OscarF1's Avatar
Maby some people tighten them too much,
the belt must flex a lot,
but just not slip over the center pulley.
Old 12-14-2006, 10:52 AM   #5935
Yeah, that would be my guess. I've always set my belts on any car to allow the drivetrain to be as free as possible without the belts bouncing or slapping the chassis. I also use the low friction alternated tooth pulleys and I still don't slip!
Old 12-14-2006, 12:03 PM   #5936
Default Spare Parts?
Hi,
Just wondering what kind of parts are you guys going through on the TA05. Anything common that is breaking? I just bought one so I was wondering what kind of spares I should have on hand? I am a pretty newbie driver although in the last 7 races I didn't break anything on my TC3.
Also a setup question. What kind of suspension blocks and springs are guys running on carpet, foams on carpet. The track I run at is about 60X36 and pretty much everyone runs pink/orange fronts with double pink rears. The car I bought has the TRF dampers on it all ready.
Thanks for any help you can give me.
cutwo is offline   Reply With Quote
Old 12-14-2006, 12:23 PM   #5937
OscarF1's Avatar
Originally Posted by cutwo
Hi,
The Tamiya diff balls are not strong enough,
try carbide or ceramic.
The standard plastic suspension blocks are also a weak part.
The servo saver is not precise enough.
Wheel hex ( dont use plastic ones )
Succes !
Old 12-14-2006, 01:17 PM   #5938
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I test mine by holding a belt in the middle with my thumb and forefinger, and with the other hand trying to turn the top of the spur gear towards the held point on the belt. If it slips a tooth with a decent bit of force, it's loose.. for mod racing, you'll want to make it a notch tighter just in case.. the motor's going to provide a lot more torque than your hands can, but it's a good indicator for stock and 19T..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 12-14-2006, 02:31 PM   #5939
In my Ta05 in the rear diff i have the Tamiya Aluminum Differential Joint Set and To me the diff feels quite crunchy i have used Team Much More Ball Diff Grease and it feels slightly smoother but i can still feel the chrunchyness, and i have tried loosening the diff but it doesnt help.
What can i do to make it smoother?
Old 12-14-2006, 06:15 PM   #5940
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Sounds like you need new diff balls and/or rings.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
