Like Tree2Likes
Old 12-11-2006, 08:06 AM   #5896
proceed5's Avatar
Originally Posted by DA_cookie_monst
The car just don't seem stable mid corner, always wanting to slide out on the rear or hook up on the front.
Hi,
IMO, the following may assist you, try it out and see if it works (assuming the rest are good already:-
A): Car pushes mid-corner while on power = try soften front springs one notch and/or stiffening rear springs one notch ;
B): Car too loose mid-corner while on power = try stiffening front springs one notch and/or softening rear springs one notch.
Just my 2cents, cheers.
proceed5 is offline   Reply With Quote
Old 12-11-2006, 09:06 AM   #5897
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by CarKing
Does it matter what suspension mounts are used to acheive the degree of toe? For example for your front toe is 2 degrees. Would it matter if I used 1B and 1XB, 1A and 1XC, or 1X and 1XD since they all acheive the same toe angle?
yes, the different blocks have different lengths, so it will affect the width of the car. you can gain it back at thehub, but it has a different effect then if you widen it at the mount.
tamiyarcracer is offline   Reply With Quote
Old 12-11-2006, 09:12 AM   #5898
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
That works. I had that same problem and I did both. Altough I traction roll now if I go too hard into a corner.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-11-2006, 09:25 AM   #5899
I dunno, I tried that, and it just didn't help, I dunno, I think it is the front tyres rolling onto the sidewall, so I don't think it is a 'subtle' tuning it needs, I was considering adding 1' toe-out to the front suspension hinge pins, to act as an anti-dive.
DA_cookie_monst is offline   Reply With Quote
Old 12-11-2006, 03:48 PM   #5900
Super Moderator
Grizzbob's Avatar
Originally Posted by CIVIC91
Well...the TA05 once again proved it's worth taking home 2nd and 4th (brushless foam class) against some fearce competition at one of our biggest races of the year! If anyone has questions as to whether this car can compete on carpet with foams...don't worry...it can
Similar story here. Though I haven't tried anything stronger than stock rubber yet(thinking about that after the Novak race), it picked up a win over the weekend here(driven by yours truly), & that was against cars of all makes, even the new XRay 007(& some older T2's). Seems the more I drive it, the closer to finding the right line to get those magic laps I get(still have only made the smallest of changes since I got it)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-11-2006, 05:13 PM   #5901
Juan Valdez's Avatar
Toeing-out your front hinge pins (adding arm sweep) will actually make the car want to dump over the front end MORE. The arm sweep seems to increase the amount of weight transfer to the front end in the corner, and will make the car want to hook more than if the hinge pins are parallel. If you want to add anti-dive, do it by putting spacers under the front end's rear suspension block. Or if you're having traction rolling issues, maybe try raising your inner camber links (at the bulkhead)? I believe that will help the car corner flatter. Just some ideas. Good luck!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 12-11-2006, 06:24 PM   #5902
juanfinesse's Avatar
Hey guys, its me again with another question, im getting new aramid drive belts and i was wondering, how tight should they be for maximum performance?
And Juan Valdez, are you from Colombia???
Thanks,
Juan
juanfinesse is offline   Reply With Quote
Old 12-11-2006, 11:00 PM   #5903
proceed5's Avatar
True.
On bigger tracks with sweeping corners, i add 0.5mm to 1.0mm spacers the Front-front sus-blocks as kick-up and where needed 0.5mm spacers to the Rear-front sus-blocks as anti-dive.
Do you guys use the same method as well?
Old 12-11-2006, 11:04 PM   #5904
proceed5's Avatar
Thanks,
Juan
Hi
Would like to share that with my blue color belts, i set it loose enough so that without pinion attached with a push from finger, all 4 wheels rotate smoothly and gives good roll distance on ground.
Just my 2cents, Cheers.
Old 12-12-2006, 05:10 AM   #5905
first post on this site and would just like to say its a great site nicley set up, ok im getting a ta05 for xmas and im getting quite a few hopups with is just wondering if u guys can gime sum warnings if iv puchased crap parts and things i should get in the future. the car will be used for drifting mostly, my ft tc3 is gettign a bit old thats all. im no noob to drifting either one couple of comps and participated in demos, so i no alot of the parts im getting are a bit of overkill but owell they look kool lol haha
cheers
hers wat iv orderd.
Tamiya RC ARTA NSX TA05 W/O ESC
Team Orion 15X2 SV2 Method R Motor
Yokomo SCR6712 Electric Speed Controller
TOPCAD Universal Joint/(Light Weight) For TA05
Yeah Racing Alloy Bearing C-Hub For TA05,TB02
Yeah Racing Alloy Front Knuckle Arm (BU) For TA05
Yeah Racing Alloy Rear Knuckle Arm (2Deg)(BU) For
Yeah Racing Alloy Turnbuckle Set For TA05
3Racing Graphite Front Shock Tower For Tamiya TA05
3Racing Graphite Rear Shock Tower For Tamiya TA05
3Racing Aluminium Steering Saver For Tamiya TA05
3Racing Graphite Chassis Conversion Kit For Tamiya TA
3Racing Alum Front And Rear Damper Set For Tamiya
Tamiya TRF415/TA05 Suspension Mount (A)
Tamiya TRF415/TA05 Suspension Mount (C)
Tamiya TA05 Stabilizer Set (F & R)
USD$404.10
Mr.Roboto is offline   Reply With Quote
Old 12-12-2006, 05:28 AM   #5906
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I believe I set mine 1 dot looser than the stock manual setting. They seemed to be a little more tight than the stock belts.
Thanks,
Juan
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-12-2006, 08:13 AM   #5907
waOscar's Avatar
cheers
hers wat iv orderd.
USD$404.10
wow, all that money spent on bling, gotta agree it's gonna look a beauty, but, buy some TRF dampers! They look cool and will actually do something to help the handling of your car.
have fun.
waOscar is offline   Reply With Quote
Old 12-12-2006, 12:11 PM   #5908
Viat's Avatar
Trader Rating: 24 (100%+)
Can somebody tell me in detail what are the advantages of the Tamiya Reversible LW suspension kit for TA05 compare to the stock (besides the general that it is LW and there are more possibilities of adjustments).
I really would like to know (mostly from those who is using this Hop-Up) how much of an improvement could be experienced by using it on an asphalt high traction track (I race at the Hobby Town USA in Frederick C).
Lat say I got it and replace the original. What set up would you recommend for such track like the C?
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
Old 12-12-2006, 02:46 PM   #5909
shift's Avatar
Yep definatly get the TRF dampers there are much better. also i would stay away from 3racing carbon fibre it isnt the best of quality but the rest of there stuff is great. if you want carbon fibre shock towers get the tamiya ones.
shift is offline   Reply With Quote
Old 12-12-2006, 04:35 PM   #5910
yer i was giong to get the tamiya ones with the black cf chassis but the rc mart discontinued it the morning i was gunna buy it. so i changed al my cf parts to silver cf. thanks for the help with the dampers
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
