Like Tree2Likes
Old 12-04-2006, 04:19 PM   #5851
Tim K's Avatar
Hi Big Rigg,
The lasers are in the mail
Tires are RD Logics transparent blue ... I think they are made from silicon so don't think they would work too well.
Tim K is offline   Reply With Quote
Old 12-05-2006, 12:27 AM   #5852
shift's Avatar
Hi there guys,
Ive come across a problem with my ta05. At my local track at the end of the straight is a sweeper and when i enter the sweeper the car seems to spin out. It also happens when the car gets up to speed and i enter a corner. I thought maybe i need a bigger wing on the rear? because the one on it at the moment is quite small. Do you think this would help? or is there something wrong with my current set-up. Also this is for modified racing
Cheers, Liam
shift is offline   Reply With Quote
Old 12-05-2006, 12:43 AM   #5853
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Shift - you can certainly look at another body style or wing for handling issues, provided that your suspension setup is basically sound. Some years ago I was having the exact same problem coming into a sweeper. Switched body styles and presto the car was glued. (too bad my driving was and is still bleh )
minicooper is offline   Reply With Quote
Old 12-05-2006, 12:50 AM   #5854
shift's Avatar
I dont think its the body as most people at the track seem to use it. ill use a bigger wing and see how that goes.
Thanks for the help
Old 12-05-2006, 05:31 AM   #5855
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I'd say double check your droop settings....you probably have too much in the rear or it's uneven side to side.
Originally Posted by shift
Hi there guys,
Cheers, Liam
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-05-2006, 08:44 AM   #5856
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
If you're wiping out on-speed in corners your rear tires aren't getting enough grip compared to the front.. you need to either soften or take out the rear sway bar (if you have any), or soften the rear springs. Your rear droop should be 2mm or so, not too much or else all that weight will transfer forward to the front tires, making you spin out as soon as you slow down to take the corner.
Lastly, if that doesn't fix it, stiffen the front springs. What spring combination are you using now?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 12-05-2006, 10:00 AM   #5857
I wouldn't be overly concerned about the wing size. I NEVER tune with the body. I would say go back to the box stock setup double checking droop, camber etc...and you should be golden. Are you running oneways??
Hi there guys,
Cheers, Liam
Old 12-05-2006, 01:27 PM   #5858
shift's Avatar
Thanks guys. At the moment im running yellow springs front and rear. yellow swaybar up front and red on the rear. also i am running a front one way. Would maybe a spool be the way to go? ill check droop settings and set it to 2mm.
Old 12-05-2006, 01:30 PM   #5859
Liam, does it happen when you were slowing down? or when you were still full throttle?
yellow15 is offline   Reply With Quote
Old 12-05-2006, 01:33 PM   #5860
Once again check your droop...especially with a oneway...they tend to amplify suspension problems... I would say add some front droop too.
Old 12-05-2006, 01:34 PM   #5861
shift's Avatar
It happens when im slowing down.
Old 12-05-2006, 01:45 PM   #5862
If the car handles ok everywhere else. then it probably means too much weight transfer to the front when you are slowing down.
I know Stephen will tell you the opposite, but less droop (less down travel) at the back will help as it'll make the rear end not lift up as much when decelerating
Keeping everything else the same and try this alone first.
Old 12-05-2006, 02:24 PM   #5863
shift's Avatar
Thanks for that richard. Ill try it next time im at the track.
Old 12-06-2006, 03:09 AM   #5864
whats a good setup to start off with as a base for some stock racing on a typical track? The car is stock..
thanks
raidvs is offline   Reply With Quote
Old 12-06-2006, 08:58 AM   #5865
Jam-ehz's Avatar
The front one-way certainly cause a spin-out when off-throttle.. rear tires lock while the front keep going.. try the spool or diff if the track is tight enough to need brakes that much.. beyond that, stiffen up the front springs (blue/whites), keep the yellows in the rear, and take off the rear swaybar, see how that goes.. and keep the droop at the rear to only a few mm's.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
