Like Tree2Likes
Old 11-18-2006, 12:03 AM   #5791
POOKYT's Avatar
Guy one quick question!
If your running 19 turn ( asphalt or carpet), is it better to run the carbon chassis for stiffness or is it better to run the stock chassis for the flex to hook up better? Opinions?
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-18-2006, 02:26 PM   #5792
Brant
Hey pookyt I ran 19 turn asphalt with the stock chassis up at the XRCC race about two weeks ago and it did great especially when it was right on the back bumper of yokomo.
Garrett W
Team High Velocity Racing
WWW.HIGHVELOCITYRACING.COM
Team Associated
Gman Graphics
performance26 is offline   Reply With Quote
Old 11-18-2006, 03:04 PM   #5793
volracer's Avatar
Send a message via ICQ to volracer
Default Lightweight Reversible Suspension Sysytem
I am thinking of building a TCS legal TA-05. I have seen the lightweight reversible suspension system is a hop up listed on the Tamiya USA site. What is the advantages and disadvantages of the lightweight reversible suspension set?
Also, since the lightweight reversible suspension system is listed as a hop up for the TA-05, then are the 53939 RC Lightweight Wheel Axle - For Reversible Suspension a TCS legal hop up for the TA-05?
Apprently there is a different bearing for the reversible lightweight suspension system, what is the difference? Where is a good source for ceramic bearings for the TA-05?
volracer is offline   Reply With Quote
Old 11-18-2006, 04:41 PM   #5794
POOKYT's Avatar
Garrett W
Hey Garrett!!! Let me guess..........that Yokomo was running a brushless mod too?? LMAO! They'll never learn!!!
Brant
Old 11-18-2006, 07:36 PM   #5795
Talking
yeah it was lol!! needless to say everyone was looking at my car wondering how a cheap car could keep up with a 400 dollar car
Team Associated
Gman Graphics
Old 11-18-2006, 07:54 PM   #5796
POOKYT's Avatar
LMAO!!!! Good job man!!!! Are you running a front diff. or a spool?
Brant
Old 11-18-2006, 09:23 PM   #5797
sportpak's Avatar
Trader Rating: 26 (100%+)
Cool man. I've surprised a few people with my Ta05. It goes to show what driving style, setup, and practice can do. Wheel it.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-18-2006, 10:28 PM   #5798
shift's Avatar
Can someone tell what part this is going from the rear bulk head to the motor mount ive never seen it before. the guy selling it says its a hop up and is meant to stiffen the chassis but wouldnt having it on the left hand side stiffen it more on that side and affect the handling in a bad way? oh and im not interested in buying this im just curious
shift is offline   Reply With Quote
Old 11-19-2006, 12:28 AM   #5799
Trader Rating: 31 (100%+)
I'd say that your right... just there to stop the chassis flexing in the back, maybe get a little more rear traction. It is still running over the top of the chassis' "spine" so I don't know how much left/right balance would be affected. It'd be easy enough to make one yourself, a couple of ball studs and cups and a long turnbuckle.
$$$... is offline   Reply With Quote
Old 11-19-2006, 12:35 AM   #5800
Super Moderator
Grizzbob's Avatar
It shouldn't have any effect on transitional handling(left-right grip), but it might affect straight line grip, should just stiffen the chassis longitudinally(which has been done before on older cars, quite a few years ago). But with the molded carbon chassis, I don't see any need for it.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-19-2006, 05:21 AM   #5801
volracer's Avatar
I have seen this on other belt drive cars and the explaination was it kept tension on the rear belt.
Old 11-19-2006, 08:04 AM   #5802
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Tech Racing makes them....
http://www.precisionrc.com/nv/car/pr...oduct_id=27631
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-19-2006, 08:16 AM   #5803
juanfinesse's Avatar
Hi all i just received a TA-05 and i have one question:
How do i fit the servo into the car? i have a futaba S3003, will this work?
juanfinesse is offline   Reply With Quote
Old 11-19-2006, 08:21 AM   #5804
It shows you in the manual, you have to cut one of the screw lugs off.
DA_cookie_monst is offline   Reply With Quote
Old 11-19-2006, 03:37 PM   #5805
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
As per the name, it's lighter weight than the regular suspension, has more options to connect your shocks and camber links, and generally helps make the car quicker in transtions. Unfortunately it's more brittle and can't take as many hits. The bearings are smaller (5x9mm vs. 5x11mm) and aren't as durable on impacts.
Yes, the LW axles will be compatible and legal for the TCS, although I'm sure they're less durable than the steel axles, not sure if they're worth the weight loss unless you can keep off of the boards (and other cars).
On a side note, for non-TCS foam racing the front LW suspension won't fit them without modification with non-tamiya parts (HPI/XRay).. better off keeping the front as standard to take the impacts and fit the foams, and the rear as LW for the tuning abilities..
Rubber tires fit the system no problems.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
