Like Tree2Likes
Old 11-08-2006, 10:24 PM   #5731
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by crazy5
Nonsense poopy pants, my tao5 went through the 24 hour enduro and is still going strong. Haven't changed that setup since the nats and haven't found a surface yet it hasn't worked on. I'm gonna give carpet a try this week. I'll see if Garbers super setup works there too.
hehe cool! hit me up on email so this thread can get back to normal ([email protected]) if you see Garber.. tell him to call me up.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-08-2006, 11:18 PM   #5732
Trader Rating: 14 (100%+)
Crazy5:
Hi,
they are using the HPI steering hubs,bearings and stub axles. they work fine with no clearance problems. one problem is that the HPI hubs seem to break real easy. some guys are running the XRay T2 steering hubs,bearings, & stub axles also.
Hebiki:
Hi,
I'll try to get you a good rubber tire/carpet setup. I'll e mail the guys at the track we go to to race. they have alot of fast guys running rubber tires there.
glad to see your back!!!!!
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 11-08-2006, 11:35 PM   #5733
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by DOTMAN
B3 are good for 1 1/2 to 2 runs
I concur on the B3's
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-08-2006, 11:47 PM   #5734
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
And you have the B tires??
tamiyarcracer is offline   Reply With Quote
Old 11-09-2006, 12:02 AM   #5735
JayBee's Avatar
Nope, that's why I only spoke up on the B3's
Old 11-09-2006, 12:27 AM   #5736
JJaybee you ganna get the TRF415MSXX???
Old 11-09-2006, 06:12 AM   #5737
m3ndo5a's Avatar
Default Carpet
Has anyone here tried foam tires on the tao5 yet? I'm wondering if they fit or not. I found out they don't fit the mre so I was gonna try them on the mighty tao5.
Any of the Tamiya Chassis with LWS...... On carpet
You will need
6mm Wheel Hex/ 1mm Shim will clear the front/w Parma Foam.
True your tires Before making these adjustment
Set up
Front end
Damper 2nd hole form outside
middle hole Suspension arm
1mm down shock retainers (all around)
60wt AE oil
Purple Xray
1b front block
1a rear block
3mm Inner Camber Linkage (Roll Center)
2* Camber (Static)/Hudy Set up
1.5mm uptravel droop (Center Lift method) (Static)
4.5mm Ride height
Zero Toe out or 1* Toe out
Front Diff looser than rear, not much
Rear end
Damper 2nd hole from outside
Middle hole on suspension arm
40wt AE
White Xray
1a front block
1d rear block or 1e
2mm on inner camber link (I am going to try 1mm)
1mm on outter camber link Center Hole
1.5* Camber
2mm uptravel droop
5mm ride height
Parma
Cyan 58mm
Mag's 58mm (stop at 55.5)
Niftech
Corally jack gripper
Cos 27t
"Fan"
MC8000/LRP C2 Profile 5 "Punch"
Hpi Stratus Aero very aggressive
Parma Alfa seem to be pretty balance
My MRE is very close to this...with some mild changes
The car has been pretty Solid.
Rubber go with stock set up. You may want to add a oneway for faster steering.
Good Luck
m3ndo5a is offline   Reply With Quote
Old 11-09-2006, 06:44 AM   #5738
JayBee's Avatar
nahh... the 05 & MRE have been quite solid. No need to go out on a limb yet
Old 11-09-2006, 08:21 AM   #5739
Tsquare's Avatar
1 1/2 run tires sound like a reciepe for a good qualifing run and a bad qualifing run?
Tsquare is offline   Reply With Quote
Old 11-09-2006, 04:52 PM   #5740
Super Moderator
Grizzbob's Avatar
Ehhh, I think that'll depend on the conditions & surface you race them on. I've only tried B3's once, but it was in what I'd consider to be pretty extreme conditions(high-90'sF temps, VERY abrasive black pavement with the sun beating down, this was at Memphis' '05 TCS race) & the one set of B3's I used seemed to hold up very well all day(felt alot to me like TakeOff CS-27's), couldn't tell if they dropped off much if at all(but I'm not saying they didn't, just couldn't tell)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-09-2006, 06:55 PM   #5741
crazy5's Avatar
You will need
Set up
Front end
60wt AE oil
Purple Xray
1b front block
1a rear block
4.5mm Ride height
Rear end
40wt AE
White Xray
1a front block
1d rear block or 1e
1.5* Camber
2mm uptravel droop
5mm ride height
Parma
Cyan 58mm
Niftech
Cos 27t
"Fan"
Good Luck
Thatnks for the help.
YOU SUCK YOU STUPID CLOWN!
crazy5 is offline   Reply With Quote
Old 11-10-2006, 01:52 AM   #5742
Hebiki:
Hi,
You should have mail. if not please let me know.
Old 11-10-2006, 09:48 AM   #5743
Hebiki's Avatar
Originally Posted by TimXLB
Hebiki:
Hi,
thanks Tim.. curious.. is that set up for standard or LWS? my TA05 has never seen the standard. i put on the LWS the moment i bought it.
Hebiki Design Works
Old 11-10-2006, 10:18 AM   #5744
Hebiki:
Hi,
it's for the LWS. he has a TA05 with the stock suspension that he runs with a setup that's close to the one I sent you only with silver springs all the way around. and red sway-bars.
I'm in the process of putting the same setup on my 2nd TA05 for a race tomorrow. it'll be the first time I've ever run rubber tires on carpet in like 6 years........ it should be fun!!!!!!!!!!!
Old 11-10-2006, 03:35 PM   #5745
MrBlack's Avatar
I know many of the Eruo drivers when they run rubber on carpet actually run the standard suspension arms, just an FYI.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
