Like Tree2Likes
Old 10-19-2006, 08:21 AM   #5581
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
What's your price?
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 10-19-2006, 12:10 PM   #5582
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
id probably let it go for 70 shipped in the US, depending on where you are located... i can get ya pix later.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-19-2006, 03:30 PM   #5583
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by flying G.E.O.
Which is better between getting the front one way or the center one way?
Front one way
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 10-19-2006, 07:03 PM   #5584
flying G.E.O.'s Avatar
Front one way it is. I always thought you should buy both one ways all the time.
www.3dgallery.co.nr
flying G.E.O. is offline   Reply With Quote
Old 10-19-2006, 07:04 PM   #5585
secretsg's Avatar
Some more 934RSR shots. Just scroll past the 501X to see them.
http://www.pro-s-futaba.co.jp/hsphoto/prs-1.htm
http://www.hobby-one.co.jp/hobby/ta.html
secretsg is offline   Reply With Quote
Old 10-19-2006, 07:50 PM   #5586
quantum's Avatar
some will disagree but i think that centre and front one-ways complement each other, and you should get both for asphalt, less important on carpet.
the centre oneway give you off power steering while the front oneway gives more on-power steering. depending on setup and track conditions, the front oneway alone could do it all. the fact that many centre oneways tend to break (1way bearing locks up) makes it a point of failure anyway.
my two cents.
quantum is offline   Reply With Quote
Old 10-19-2006, 09:34 PM   #5587
AWK
AWK's Avatar
http://www.tamiya.com/japan/products...e934/index.htm
Updated pics of the Porsche on Tamiya's site. Wish they could have put some wide wheels out back as the narrow ones look wrong on the car.
AWK is offline   Reply With Quote
Old 10-20-2006, 05:34 AM   #5588
rccardr's Avatar
I'm likin' that Audi A4DT 2006 Veltins body a little farther down the page, too. Anybody know whether the wheels on the Porsche are metal or plastic?
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 10-20-2006, 10:42 AM   #5589
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Should be gold plastic with chrome plating on the rim.. 5mm offset too.. heh.. likely just for the porsche and its protruding wheels, making it look like it has wider treads.
They should have went to foams..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-20-2006, 10:56 AM   #5590
secretsg's Avatar
For the intended market foams would never fly.
Old 10-20-2006, 12:14 PM   #5591
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Are there a differences in springs weights and lengths between the trf springs, #53630-'33, and the tuned hard springs that are included in the set #53440.
rctouringracer is offline   Reply With Quote
Old 10-20-2006, 12:22 PM   #5592
Jam-ehz's Avatar
The TRF springs are much shorter, around 2/3 of the length.. I think the red and yellows are relatively the same force, but the blue and whites are stronger per inch than their on-road counterparts..
I use them a lot for my TA05 and Mini to reduce ride height.. sometimes those on-roads are a bit too long to get below 6mm..
Also don't forget 53635 and 36, Super and Ultra-hard..
Old 10-21-2006, 10:00 AM   #5593
sportpak's Avatar
Trader Rating: 26 (100%+)
[QUOTE=Darkseid]Well as you've seen discussed here, be sure to get the Kimbrough Mid-Size w/o Holes
QUOTE]
Thanks for the information. I just got mine put on and it looks great. I'll get her dialed in and see how it works Tuesday.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 10-21-2006, 09:22 PM   #5594
Send a message via AIM to A-Ko
This is how I would rank them.
If you change to the Graphite towers you will like using the short springs more.
53636 - Purple [Hardest]
53635 - Grey
53633 - Short White
53632 - Short Blue
53631 - Short Yellow
53440 - White
53440 - Blue
53440 - Yellow = 53630 - Short Red
53440 - Red [Softest]
Each spring is useful depending on track conditions.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 10-21-2006, 09:35 PM   #5595
Hi guys, I just got a TA-05 kit. I'm looking to run it on an indoor carpet track. I have a question about foam tires. I'm sure its posted somewhere, but I read through about 15 pages and didnt find what I was looking for.
Anyways, will 28mm tires fit this car, or will there be a rub issue? Thanks for any info.
dirtchambers is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
