Like Tree2Likes
Old 10-16-2006, 06:56 PM   #5551
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by Darkseid
[b][SIZE=3]Thats just what the company had in mind when they made it. The Factory Team TC4 was designed to be such a car,
I would put a frog up against that car!!!!!!!!!!!!!!!!!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-16-2006, 07:57 PM   #5552
AWK
AWK's Avatar
Coming from a guy who went from the TA04R to the MSX...is there a reason to go out and buy a TA05?
To me, the MSX is amazing but I have nothing to compare it to. I am not looking to run Reedy, or anything like that. Honestly, I would like to run and win TCS.
AWK is offline   Reply With Quote
Old 10-16-2006, 09:16 PM   #5553
Super Moderator
Grizzbob's Avatar
Depends on the TCS class you'd want to run. There is GT1, GT2 & GT3, the GT3 class uses the silver can Johnson/Mabuchi motors only, & the GT2 class uses ROAR legal stocks, while GT1 uses ROAR legal 19 turn motors, & if you want to run GT2 or GT3, then you can't use the TRF 414's, 415's, etc, but the TA05, 04, TB02, TB01, etc.(the tub cars, in other words) are allowed in them(& if you really want, you can run basically ANY Tamiya onroad TC chassis in GT1)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-17-2006, 05:01 AM   #5554
rampal's Avatar
Send a message via MSN to rampal
Default suspension blocks
Hi:
Quick question: to keep standard toe either in front and back, which TRF suspension blocks I should use on th TA05??
I think this is Front:
1A block #51065
1A bridge block #53685
and back:
1A block #51068
Is that correct?? Thanks a lot,
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 10-17-2006, 05:30 AM   #5555
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
yep
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-17-2006, 07:43 PM   #5556
Big Rigg's Avatar
Smile Newb
I just got one of these beasts and am looking forward to running in some of the TCS races this year... I had a couple of questions to get me started:
where can I find a manual and an available parts list? (soft copies would rock)
also what are the must have hopups in terms of performance and durability... bling can come later... (opinions welcome )
thanks and I look forward to reading all the insites on this super mega thread
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 10-17-2006, 09:34 PM   #5557
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
http://www.tamiyausa.com/product/ite...oduct-id=58345 is the first place to go, not sure about printed copies though..
I'd grab Sway bars, normal 64p gears, front steel CVD's, maybe aramid belts, pretty well it... the front one-way/spool is your choice, depends on what you're running on..
I'd see about the Wide-pitch pulleys too.. the recessed covers keep the diff clean for so much longer, let alone the extra efficiency.
Welcome to Club TA05!
-Hugh Jorgan
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-17-2006, 10:29 PM   #5558
Trader Rating: 31 (100%+)
Hey Big Rigg,
Do you race at So Cal?
ittjv is offline   Reply With Quote
Old 10-17-2006, 10:39 PM   #5559
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
I've found out that the front and rear suspension blocks are weak and I've replaced mine with the 3 racing ones. They get rid of the tiny plastic spacers for your suspension arms. Looks good too all in blue.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 10-17-2006, 10:41 PM   #5560
Originally Posted by rampal
Hi:
1A block #51065
and back:
1A block #51068
al
If you run a 1A Bridge front with a 1C you will increase your corner speed.............
Old 10-17-2006, 10:42 PM   #5561
The little spacers you replaced took away your ability to adjust the wheelbase of the car..............
Old 10-18-2006, 06:32 AM   #5562
Regional Moderator
Darkseid's Avatar
With the recent addition of the wide pitch pulleys to my car, I think I can finally say that the drive train on my TA05 is equal to that of my MI2 that I used to have.
And anyone who has felt the drive trian on a MI2 knows that its quite an accomplishment for any belted car to get that smooth.
Only problem is, I think I'm running out of stuff that I wanted to put on my TA05!
TLR 22...Tamiya F104...
Old 10-18-2006, 07:55 AM   #5563
rampal's Avatar
Doing that I'm increasing front toe-out, right? In which sense I cannot accomplished the same results only with proper adjustment of the turnbuckles?
Or we're talking about back settings?
Thanks a lot,
Old 10-18-2006, 08:14 AM   #5564
It's actually inboard arm sweep...and in my experieince it smooths the car out and makes it easier to drive.
Old 10-18-2006, 08:51 AM   #5565
The kit comes with them built into the blocks like the 415's do. Not too sure if you could really tune the wheel base like that but the suspension on my car now sits better.
Joshua T
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
