Like Tree2Likes
Old 10-12-2006, 08:35 PM   #5506
YAH
YAH's Avatar
Trader Rating: 77 (100%+)
Default Servo Saver
Has anyone used the TAMIYA Hi-Torque servo saver (50473) with a TA05? Does it work and clear the belts?
By the way, I am also in the process of changing over from A F/T TC4 to a TA05. Hope I can go faster too!!!
YAH is offline   Reply With Quote
Old 10-12-2006, 09:09 PM   #5507
trax4tw's Avatar
I use the kimborough (sp?) ones and they work just fine. They look exactly the same. I think the kimborough one have a spring inside instead of a metal ring tho. That is the only difference that I can see between them. But if you get the Kimborough ones you need to make sure you buy the right ones for your servo. Best of luck
trax4tw is offline   Reply With Quote
Old 10-12-2006, 11:09 PM   #5508
YAH
YAH's Avatar
Wink
Great thanks
Old 10-13-2006, 12:20 AM   #5509
Trader Rating: 31 (100%+)
I would go with the Tamiya servo saver or a horn. The kimbrough servo savers (medium size) are shorter than the tamiya ones so they tend to hit the chassis and the steering link hits when it comes back across it. I've tried using the kimbrough medium size in every orientation possible and it just wouldn't work right.
ittjv is offline   Reply With Quote
Old 10-13-2006, 07:10 AM   #5510
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
That's what I thought too...for a while. My Tamiya servo saver worked for a while, then got sloppy. I use a medium Kimbrough now with the side facing the chassis trimmed so it doesn't hit...works perfect.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-13-2006, 11:27 AM   #5511
vega_B's Avatar
guys,
i need some advice/tips on how to improve my steering. I want to get more turn in/corner entry. I've tried different shock locations, springs, and swaybars. Now im out of idea. Anyone keen to help?
cheers,
vega_B is offline   Reply With Quote
Old 10-13-2006, 12:04 PM   #5512
sportpak's Avatar
Trader Rating: 26 (100%+)
First thing I would do is make sure your linkages are the same length. Then check your end points and dual rate on your radio to make sure you are traveling lock to lock.
How are you running the car? foam/carpet, rubber/carpet, rubber/asphalt...ect.
Ben
sportpak is offline   Reply With Quote
Old 10-13-2006, 12:16 PM   #5513
I hear ya, I cut the tab also, but the servo saver hitting the chassis isn't the only problem. The medium servo saver is too short, and causes the link to "top out". That's why the Tamiya one is the better option and a horn is BEST option. See the diagram I drew up to understand what I'm talking about....
Old 10-13-2006, 12:17 PM   #5514
First thing I would try is more rear droop. It will allow more weight transfer to the front of the car. Droop makes a HUGE difference.
Old 10-13-2006, 12:20 PM   #5515
Huh, mine goes lock to lock with the Kimbrough??? Try using the forward holes on the steering knuckles.
Old 10-13-2006, 12:25 PM   #5516
Runin Ronin's Avatar
Default Toyota Supra TA05
Does anyone that has a TA05 kit with the Supra body have the manual handy? I need the Tamiya color code for the BLUE and WHITE paint.
RR
Runin Ronin is offline   Reply With Quote
Old 10-13-2006, 02:35 PM   #5517
loopedeloop's Avatar
RR
For the Esso Ultraflo supra they are
PS30-Brilliant blue
PS 1-White
Cool looking body , but not enough steering for me so I used my Ride Stratus body. Much better.
loopedeloop is offline   Reply With Quote
Old 10-13-2006, 03:15 PM   #5518
PS30-Brilliant blue
PS 1-White
Thank you very much!!!
It's a shelf queen body for me, I'm currently using the Protofrom DNA1 or Mazda 6 bodies. My buddy swears by RIDE... I'll try them one day
Old 10-14-2006, 01:47 AM   #5519
OscarF1's Avatar
I am stil searching for a better Carpet setup for the TA-05,
we found the main balance in the car,
but there is some more gripp to be found in the corners.
Til now the best tires for carpet we found are sorex 24 ,
with LRP grip fluid.
Has anyone found a good setup , or better tires, or better gripp fluid ?
OscarF1 is offline   Reply With Quote
Old 10-14-2006, 08:41 AM   #5520
Italian racer's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Italian racer Send a message via Yahoo to Italian racer
Default TA05 Setup for Carpet
Hello all,
I am going to be putting a TA05 together and I was hoping to get a good starting point for the car with the LW suspension. It will be on carpet and using Tamiya A's and also CS27's.
Thanks,
Italian Racer
Italian racer is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
