Like Tree2Likes
Old 09-29-2006, 10:27 PM   #5401
Slotmachine's Avatar
Send a message via MSN to Slotmachine
There seems to be a lot of talk about the center diff coming out. Are you guys sure they are not talking about the center Slipper Clutch that was just released?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-30-2006, 03:05 AM   #5402
As it is a comemorative car, that celebrates it's first RC car, which had three diffs, then more than likely, it will be some sort of diff in the middle.
DA_cookie_monst is offline   Reply With Quote
Old 09-30-2006, 07:26 AM   #5403
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Heh.. I didn't notice at first that it does say ball diffs front and rear, and "gear differential in the center" ..could be a slipper clutch... not sure how practical it would be unless they're making a TA05-B buggy or something off-road.. it could be related to that crazy expensive looking TRF-buggy they had at the trade show...
It's just the cantilever description of the center shaft that leads me to believe it's a cut-out mount with the arms to hold the shaft suspended from one side..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 09-30-2006, 07:02 PM   #5404
racenut's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jam-ehz
You can probably wait on the center oneway, as your front oneway will be doing exactly that function.. then again, it's a nice blue...
Perhaps front universals would be good as well, but that's really it..
how about cf shoxtower??? its stiffer than the stock.
racenut is offline   Reply With Quote
Old 09-30-2006, 09:46 PM   #5405
Jam-ehz's Avatar
I guess it all depends if you run carpet or asphalt whether you want a stiffer tower..
Old 09-30-2006, 11:56 PM   #5406
BlackKat's Avatar
Hey guys,
I'm looking into running either my TA05 or my Evo IV up at Stockton Raceway (high grip carpet with RP30's) this winter. I'm wondering what I need to do to make this car carpet ready. I have the sway bars and a good assortment of springs. My main concern about the TA05 is chassis flex. I don't think it'd work very well on high grip carpet. Is this a valid concern?
Next, do I want to run the standard suspension on the car, or I should I rob the lightweight set off my Evo?
Or should I just run the Evo?
-Dan
BlackKat is offline   Reply With Quote
Old 09-30-2006, 11:59 PM   #5407
shift's Avatar
just give the ta05 a run first and see what its like if theres to much flex you could buy the tamiya graphite tub which is stiffer and lighter by about 10g
shift is offline   Reply With Quote
Old 10-01-2006, 02:14 AM   #5408
BlackKat's Avatar
Sound advice, but I'm probably only going to get a chance to race about once a month this winter (depends on how often my ride to the track would like to race) I prefer to show up prepared as opposed to having to find something that works
-Dan
Old 10-01-2006, 04:56 AM   #5409
westerdude42's Avatar
Originally Posted by BlackKat
Hey guys,
-Dan
Swap for the lightweight. It improves the feel and steerability of the car tenfold.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 10-01-2006, 06:21 AM   #5410
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
With rubber tires the stock chassis does not have too much flex. If you decide to go to foams, then yes, get the Tamiya graphite tub.
Hey guys,
-Dan
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-01-2006, 09:38 AM   #5411
BlackKat's Avatar
Alright guys, Stock TA05 with the lightweight suspension? Any votes for the standard suspension? Should I go for the front one-way? (anyone try the 3Racing one, it's a good bit cheaper than the Tamiya unit)
-Dan
Old 10-01-2006, 09:49 AM   #5412
big al's Avatar
Black kat, The traction of the Norcal track and Ripon is similar to carpet(assuming you run the rubber class). I would give the ever popular yellow springs with yellow sway bars set-up a try first at stockton, then tune from there. I belive the popular tire set-up for stockton was sorex 28's (front) and sorex 24's (rear). I know a lot of guys use the RP's up there, I would ask around on the rcracing site. Personally, I don't see the need for any other tires as long as sorex is still in business,but what the hell do i know. Hope this helps and good luck--Al
p.s. The stock suspension should be fine and a oneway would definitely help your corner speed. Don't use less than 1.5 deg. of camber. I use that combo and my TA05 hurts a lot of egos.
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 10-01-2006, 10:00 AM   #5413
Jam-ehz's Avatar
Well, I got my order for the LWS and a few extra 4-deg caster blocks.. however, they sent me 2-degree blocks instead..
How much of a difference will this make, and should I bother to try to get them swapped for 4-deg ones instead?
I've never used the LWS before, but I've seen on most setup sheets that 4-deg blocks are used..
Old 10-01-2006, 12:26 PM   #5414
-Dan
I run on Carpet, with rubber tyres/additive, 3Racing chassis and a 3Racing front one-way (thinking of putting the Tamiya unit in there only to allow me to use the MRE pulleys with the wide pitch).
-2' camber all round, raise the inner rear ball stub buy 2mm, stock suspension, 3hol pistons all round (TRF shocks), KIT silver springs on front, yellows on rear. Yellow roll bar up front, Red on rear. Handles ace.
Old 10-01-2006, 01:50 PM   #5415
I've run the stock suspension on my car for a year now. I have raced it heavily from carpet foam/rubber to asphalt rubber...with anyhting between a silver can to brushless setup. Unless the LWS can shave 1/2 a second off my lap times (it won't) I am sticking with the stock suspension. It is an absolute tank (the LWS is not!) and handles awesome. I had a 415 with the LWS and was not overly impressed. Plus if you ever want to use foams you need HPI parts to get them to fit with the LWS. They fit the stock suspension with no extra parts. I'm not bagging on the LWS. I'm sure it has it's place, but I get tired of people saying it's an absolute "must have"...because it's not!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
