Like Tree2Likes
Old 07-07-2005, 10:53 PM   #526
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Well, here is the list of things i'm buying!
TA05 - Ferrari Kit
Tamiya 53833 TA05 Front one-way
Tamiya 53841 TA05 Center one-way
Tamiya 53842 TA05 Stabilizer set (F&R)
Tamiya 53843 TA05 Aramid drive belt 2x
Tamiya 53844 TA05 Aluminum transponder stay
Tamiya 53847 Assembly universal shaft 46mm *2 in front steel, 2 in rear aluminum, would anybody happen to know the part number for it?*
Tamiya 53848 Aluminum racing steer Standard
Tamiya 53849 High-precision diff. joint Standard price 2x
Tamiya 53851 46mm Titanium coated suspension shaft 2x
Tamiya 53845 Carbon damper stay (front) Standard
Tamiya 53846 Carbon damper stay (rear) Standard
Novak GTX
Ti Screws
TRF415 Suspension blocks A *A ------ *A C
Spare Arms
If you guys have any other suggestions post em!
Finally after 3 years of waiting... I finally get a new car, Bye bye TC3 hehe...
I'm ordering on July 15th so hopefully other option parts come out by then.
vi3tishduy is offline   Reply With Quote
Old 07-07-2005, 10:57 PM   #527
over gear's Avatar
Trader Rating: 15 (100%+)
Ghostfit: how stiff is the chassis?? does it flex like the F201?
over gear is offline   Reply With Quote
Old 07-07-2005, 11:21 PM   #528
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I think you got everything except:
#53570 / Clamp Type Alum. Wheel Hub 4mm Thick / 1575
and the graphite top thingy that holds the foam bumper, I think the one from the EVO 4 is the same and also get the motor heat sink and that should be complete.
Tamiya Japan is now sold out and won't have them until end of this month.
Attached pic is the TECH RACING options:
f & R shock tower
Battery holder
Top deck
QUOTE=vi3tishduy]Well, here is the list of things i'm buying!
TA05 - Ferrari Kit
Novak GTX
Ti Screws
Spare Arms
I'm ordering on July 15th so hopefully other option parts come out by then.[/QUOTE]
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-08-2005, 02:15 AM   #529
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Car was surprisingly stiff even without any top decks! The chassis have very good designed channels(cutouts and stiffenners)... even the battery cutouts was well thought of! Really, I think air ducts were designed under there... I love it! The whole thing reminds me of how good the Yok CGM looked when it first came out.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 07-08-2005, 05:26 AM   #530
ttso's Avatar
Glad I ordered 48mm swing shaft... I run D-D B-D combination all the time..
Originally Posted by Ghostfit
Yes, Chris ....the 48mm is not needed (unless you run D or E Susp blocks)
No ! the stock 04/05 arms are fine ! I'm running the LW arms because I'm more used to them ! ...My TA04 and TB02R are aredi thus equipped
Thanks Dude ! ....I need all the help I can get from those who aredi got da car (and knows Tamiya products) otherwise I'll be too busy answering queries to post anymore Pics
ttso is offline   Reply With Quote
Old 07-08-2005, 05:32 AM   #531
ttso's Avatar
Black steel 46mm swing shaft is #51092
Old 07-08-2005, 06:06 AM   #532
Registered User
46mm Lightweight Rear Swing Shaft #53724
shevchenko2000 is offline   Reply With Quote
Old 07-08-2005, 07:29 AM   #533
vi3tishduy's Avatar
whats the part number for the aluminum turnbuckles on ghost fits TA05?
Old 07-08-2005, 07:46 AM   #534
ttso's Avatar
Well.. I use AE blue Ti turnbuckles. Much stronger than Aluminum. I suggest you use Ti turnbuckles too. If you don't like the silver color, go for AE blue...
Old 07-08-2005, 07:58 AM   #535
ttso's Avatar
Originally Posted by Hebiki
yah i have a ton of extra shocks. dont need another set and no one runs 23T here. so might as well sell it!
I'm sure the shipping will cost more than shock itself...
Old 07-08-2005, 09:30 AM   #536
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Interesting that on the box in a couple places it says "This car may be used in Official Tamiya Races".
My LHS says that the matte-grey aluminum mount dissipates heat better than the smooth shiny kind, prolly why they made it that way. I would have like to see a nice blue, but oh well...
A few people have mentioned it looks Losi-like with the centered gear and the tension system..
Is there a part to replace the green-plastic center pulley gears with aluminum?
I can't seem to take off the front diff without loosening the sway bar first.. seems to get in the way of the dogbones when I pull the diff out. No problem with the rear, though, as it seems to give enough clearance. And, lengthening the wheelbase by the front seems to be a problem too, with the sway bar holders rather close to the dogbone...
My LRP F1 Pro and Runner won't fit flat into the ESC space.. just a few mm's short in one direction. . I'll have to mount it on one end instead.
Any other observations?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 07-08-2005, 10:02 AM   #537
ttso's Avatar
It's true that dark color, rough surface is better heat sinking than light color, shiny surface. But since I running brushless, the motor heat is not really the problem, ESC is...
Old 07-08-2005, 10:17 AM   #538
ttso's Avatar
Anyone already got manual, please check for me what's the parts # of suspension arm pin. I saw one on TamiyaUSA but it's 3x49.7mm, never been used else where. Is that the one (#9808010)?
415 using 48.5mm, now TA05 using 49.7mm? I guess that means wider wheel base range than 415, not to mention if using LW suspension. Anyone can confirm that?
Old 07-08-2005, 10:34 AM   #539
Jam-ehz's Avatar
Yup, 9808010.. 3x49.7mm shaft, that's the one..
Old 07-08-2005, 12:19 PM   #540
eeyan's Avatar
I was tempted to put "E" clips on the center shaft instead of the darn small "C" clips, but found out the "E" would hit the center bulkhead assembly. Oh well, back to the "C". Nothing wrong really, I'm just afraid to lose it, specially when rebuilding on the track... This is the first time I saw a Tamiya with those kind of "C" clips... interesting...
(Can anybody tell I got nothing to do at work? Man, can't wait to hit the Tamiya track tomorrow... Chris, what's the plan?)
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
