Like Tree2Likes
Old 09-09-2006, 10:05 AM   #5236
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by JayBee
I haven't measured the difference but I don't think it can be being that the rear 1D block widens the rear track width of the car by more than 1mm...
Jaybee, I think what he saw was the 6mm wheel hex on the front, and the 5mm wheel hex on the rear
tamiyarcracer is offline   Reply With Quote
Old 09-09-2006, 10:46 AM   #5237
maxepower's Avatar
Talking Spring pressures.
Originally Posted by wotcars
Ae spring do work out
I run gold up front with silver on the back with CS 27 on our local track no probs with grip
where did you get the spring guide for the tamiya ones?
I'm sure AE springs will work with the right set-up but if there are handling issues using these springs then going back to Tamiya springs could be and option!
An engineer friend took the time to measure spring pressure on all the Tamiya springs! It was posted way way back on this thread I believe.
So the numbers should be accurate.
He also happens to be a past TCS champion!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-09-2006, 11:07 AM   #5238
JayBee's Avatar
Trader Rating: 31 (100%+)
I know but 'width' is what he mentions which I assume is 'track width'?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-09-2006, 11:09 AM   #5239
when you coming by the track?
Old 09-09-2006, 11:19 AM   #5240
JayBee's Avatar
I want to come by today but not until later...when are you showing up?
Old 09-09-2006, 04:55 PM   #5241
been here all day
Old 09-09-2006, 10:36 PM   #5242
Trader Rating: 14 (100%+)
Hi everyome:
I have some Q's about he 3 Racing Shocks. I just got another TA-05 and it has these shocks on it. they feel very good but has any one run them on carpet????? how do they compare to the Flurine (sp??) shocks????. as of now they are on a Xenon chassis. with a few hopups. I'm planing on making this my Brushless mod car. (a little more space to mount everything).
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 09-10-2006, 01:27 AM   #5243
shift's Avatar
i had the 3 racing shocks but brought the trf ones as they are much higher qulity. also the 3 racing shocks can also only take short springs
shift is offline   Reply With Quote
Old 09-10-2006, 02:47 AM   #5244
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
I just swapped my TRF shocks for a set from a 415 MSX. I like the way they look better except for the plastic bottom part. Good trade?
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 09-10-2006, 04:20 AM   #5245
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by TimXLB
Hi everyome:
GO WITH THE TAMIYA TRF SHOCKS THEY ARE ONE OF THE BEST AND SMOOTHEST SHOCKS IN THE MARKET YOU WONT REGRET HAVING THEM IN YOUR CAR
buboy28 is offline   Reply With Quote
Old 09-10-2006, 12:47 PM   #5246
I just come back from a club day with my 3Racing chassised TA-05, one-way up front, car was DIALED, just got to get the motor running better now.
DA_cookie_monst is offline   Reply With Quote
Old 09-10-2006, 08:55 PM   #5247
Hi,
Thanks, I have a couple of set of TRF shocks somewhere in my basement. they were used on different cars in the past. I'll dig those up and run those instead. I have been running the short springs on one of my other cars so that should'nt be problem. I'll just use the 3Racing shocks on a project car. I two complete sets of them and two complete sets of Shuie springs as well. (off the old Shuie sedans).
had my TA-05 running well today on carpet/foams. just a slight mid corner push on the faster sweepers. nothing to bad.
I didn't get a chance to work on my other TA-05 as I was working on my 415 carpet setup.....(good so far. but it would help if I would remmember to bring my shock spring box with me to the track
Old 09-11-2006, 09:32 AM   #5248
quantum's Avatar
i was referring to the hexes, but forgot that the blocks would/could compensate
quantum is offline   Reply With Quote
Old 09-12-2006, 12:19 AM   #5249
Default Good night of racing last night
Well I didn't finish my main but I was doing very good. I moved my pinion up from the 22 to a 24. Nice flowing track with my new 4300 batts. Took 1st in the C qualifier, 1st again in the second which put me 4th in the B. I has 2nd place in the B until I screwed up. Was running in 4th then I hit the track and knocked my motor wire off. Man I was doing good.
Joshua T
Old 09-12-2006, 12:20 PM   #5250
I just got a Hudy set up board and Integy bits to adjust it all. I'm so happy now.
Joshua T
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
