Like Tree2Likes
Old 07-07-2005, 11:33 AM   #511
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally Posted by vi3tishduy
is the lw suspension needed or is it ok to use the TA04 arms?
That's up to you how you like your setup, if you like running the old ta04 then saty wih the stock if you had a 415 evo 4 and have tried the new suspension you might wanna jump the gun.
Izzy
izzyracer is offline   Reply With Quote
Old 07-07-2005, 11:39 AM   #512
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ttso
In case anyone wannna do TA05 upgrade. Here is some info I collected:
(note: the price might be vary, so please keep it as reference only)
Part# / Name / SRP w/VAT(yen)
#49355 / TRF damper special blue / 6000
#50994 / 5mm suspension balls / 630
#51064 / TRF415 front bridge suspension mount (D) / 945
#51065 / TRF415 suspension mount (A) / 840
#51066 / TRF415 suspension mount (B) / 840
#51067 / TRF415 suspension mount (C) / 840
#51068 / TRF415 suspension mount (D) / 840
#53685 / TRF415 front bridge suspension mount (A) / 945
#53833 / TA05 front one-way / 4200
#53841 / TA05 center one-way / 3150
#53842 / TA05 stabilizer set / 1260
#53843 / TA05 aramide drive belt / 630
#53845 / TA05 front damper tower / 1155
#53846 / TA05 rear damper tower / 1260
#53847 / 46mm assembly universal shaft / 2520
#53848 / TA05 aluminum steering set / 2520
#58345 / TA05 chassis F430 body / 17640
#53499 / TA04 wheel axle / 840
#53500 / Cross joint / 525
#51092 / 46mm swing shaft (black) / 1155
#53794 / TB02 & TA04 reversible LW suspension set / 8820
#53836 / 48mm swing shaft (black) / 1155
#53570 / Clamp Type Alum. Wheel Hub 4mm Thick / 1575
For my own car, I will get:
TA05
TRF damper
LW suspension
48mm swing shaft
Alum suspension mount (bridge-D, D, bridge-A, C)
Alum steering
Stabilizer set
4mm clamp wheel hub
Ti rod/screws
CF F/R tower
I didn't get any oneway since I used to play with spool, so it will be modify diff to spool for me. Other hopup is not that necessary for me but might be for you. Hope this info helpful for some who is searching in Tamiya parts database trying to find out what to get and what number it's.
i have a NIB TRF Damper set and the 23T Motor i can sell you. just PM if you're interested. the 23T motor is the Tamiya TZ motor.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-07-2005, 01:23 PM   #513
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
You can probably add:
#53725 Tamiya EVO IV Carbon Body Mount Stay (as mentioned above)
#53837 Motor Heat Sink for Transverse Motors
#53849 TA05 High Precision Diff - at least one for the front diff if you're going 19T/mod carpet.
I don't think I'd get the aluminum steering, though.. the stock one is pretty solid as it is.. I've noticed quite a few parts are the same material as the chassis, the fibre-reinforced polyamide.
And, it includes 2-degree rear uprights. Not reinforced like the set you can buy, but still not bad at all.
Noticed also that the aluminum transponder stay doubles as a servo mount for one side. You'd still need an aluminum bit for the other side of the servo, although it's reinforced material as well, you may not need to.
And man, easy access to the diffs is an understatement! Pop 4 screws, two shock links and two ball cups, and you're set to go. I just had to do some shimming to keep the diffs centered, .3mm each side.
Went through a few 5mm's to shim the axles as well. Comes with some AW grease for the axles and diff thrust too, very useful stuff.
The tires actually have a bit of traction to them too, unlike the Enzo Ferrari radials.. might be okay for stock carpet racing with the right inserts, or at least rally
Heh.. an extra 23T and shocks, eh? Got the Champ-RC Combo? I just got the stuff individually (w/Ti screws - covered every 3mm screw I ever needed, with one left over )as well as a sport tuned motor, extra aramid belt and spur (I'm very prone to retard-moments), alu hubs, and blue turnbuckle wrench (a godsend!).. you never know if something goes, you'll have to wait a bit before it shows up in stores in North America..heh..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 07-07-2005, 01:28 PM   #514
Hebiki's Avatar
yah i have a ton of extra shocks. dont need another set and no one runs 23T here. so might as well sell it!
Hebiki Design Works
Old 07-07-2005, 02:33 PM   #515
over gear's Avatar
Trader Rating: 15 (100%+)
interesting parts from Techracing
http://diary5.cgiboy.com/3/techracin...i?y=2005&m=7#7
over gear is offline   Reply With Quote
Old 07-07-2005, 02:39 PM   #516
Ghostfit's Avatar
Originally Posted by Entropy
Monday!? I'm working man..
Originally Posted by alana07
take leave or go n keng 1 mc lah jake!!!
Alan, ....You're really HardCore to the bone !
Jake, ....no choice ! ...working full day - Sat and Sun then Off day on Monday ! (I paiseh also, go and play on BK's track when Its close)
Ghostfit is offline   Reply With Quote
Old 07-07-2005, 03:01 PM   #517
Ghostfit's Avatar
You guys ready for another installment of TA05 build Pics ?
Okay, I mention something about the easy access of the diff earlier, here's a pic showing the 4 screws to be removed:
Voila ! the diff/shock tower removed. Note the screw holes which are keyed.
Next is a view of the front Anti-roll bar assembly.
And this is a view of the rear Anti-roll bar assembly.
In this close up view of the Rear, you can see the 2 grub screws for eliminating any play in the roll bars housing.
Finally, I remember someone asking to see how the dogs sit in the outdrives. I'm sorry I dun have a pic of the original stock parts but here's my TA05 hopup with LW reversible Arms set, 46mm CVD shafts and local mod to reinforce the stock outdrives. Currently I have the stock plastic suspension blocks as the local distributor do not have stocks of what I want.
(Sorry for the overexposure but without the flash, you wun be able to see details of the outdrives.)
Cheers ! ......until the next, next instalment of TA05 Teaser !
Old 07-07-2005, 03:31 PM   #518
Hebiki's Avatar
sweet. the 48mm is not needed then?
Hebiki Design Works
Old 07-07-2005, 04:41 PM   #519
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Being new to Tamiya Tourers, I leaning towards getting the RC-champs TA-05 racing package. Need help on what other bits I need to get the car competitive. Would 2 pairs of universal drives (not sure what part number) and the alloy suspension mounts for the rear to adjust toe be enough (not sure what part number as well) and maybe a complete spring set to match the TRF shocks.
Why is everyone suggesting the reversible suspension arms? Are the stock 05 arms no good?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-07-2005, 04:42 PM   #520
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
wo, where did u get the turnbuckle? is that ti or aluminum?
vi3tishduy is offline   Reply With Quote
Old 07-07-2005, 04:42 PM   #521
vi3tishduy's Avatar
Over Here, those are nice TA05 hop-ups any ideas when that will release?
Old 07-07-2005, 05:00 PM   #522
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Alloy... Tamiya makes them
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-07-2005, 06:53 PM   #523
Ghostfit's Avatar
Yes, Chris ....the 48mm is not needed (unless you run D or E Susp blocks)
No ! the stock 04/05 arms are fine ! I'm running the LW arms because I'm more used to them ! ...My TA04 and TB02R are aredi thus equipped
Thanks Dude ! ....I need all the help I can get from those who aredi got da car (and knows Tamiya products) otherwise I'll be too busy answering queries to post anymore Pics
Old 07-07-2005, 07:01 PM   #524
Send a message via AIM to A-Ko
What kit did you use to hopup your TA04? Was it the 415/evoIV conversion?
Jeff
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 07-07-2005, 10:22 PM   #525
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
madjack is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
