Like Tree2Likes
Old 09-04-2006, 09:12 AM   #5206
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Exactly, except i mount my personal on my servo.
Originally Posted by westerdude42
Better yet don't use it. You can mount a personal on the front bumper, and if you have the house style put a long body clip under the ones that set your front body height. It will stay secure there and not change the side to side weight of the car.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-04-2006, 10:43 PM   #5207
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
Well I mounted the transponder up front and it worked fine. Now I just gotta stop crashing. I took 6th in the B main last night. The Lexus shell handles very well.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 09-04-2006, 11:58 PM   #5208
big al's Avatar
Hey Minijosh, what kind of surface are you running...and what is your set-up?? I like the pics of your car.--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 09-05-2006, 07:41 AM   #5209
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Has anyone tried the super hard and ultra hard springs on carpet yet?
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-05-2006, 01:55 PM   #5210
Talking
Indoor carpet is what we run on. Only carpet dragons and c-27 tires are allowed. No additives. Stock pinion with p2k2 pro motor. I might go up one or 2 for more speed. I have 415 shocks on it. Traded my trf's for them. Blue is better. LRP pro sport digital esc and 75 fm gives me light. I've been using my old 3300's but I got some 4300's I have to test out now. Silver springs in back and blue up front. I hope this helps.
Joshua T
Old 09-07-2006, 03:23 PM   #5211
P956LH's Avatar
more off-power steering
I run my TA05 on tight a parking lot track, and I can't seem to get it to have enough off-power steering. I'm running std suspension (4deg caster blocks), the stock front knuckle setting (whichever one gave the higher axle height, and "back" ackermann position), and TRF dampers-2 hole piston-40wt oil, AE gold spring front and AE blue on the back. Front downtravel is "5" on the AE droop gauge, and rear downtravel is "4" on the AE droop gauge. Roll center positions and wheelbase are as per the kit setup.
Which one will make a greater increase in steering: switching the front knuckles round (lower front axle height) or moving the outer (front knuckle) ackermann position forward? Or is there something really wrong with my setup and/or I should try and change something else before changing these?
TL-01, TB-02R, RS4 Pro 3, TA05R, Desert Truck.
P956LH is offline   Reply With Quote
Old 09-07-2006, 04:03 PM   #5212
I'd try more droop in the rear, and maybe try 1 step softer springs in the front.
Old 09-07-2006, 05:03 PM   #5213
Take away front droop
Old 09-07-2006, 06:16 PM   #5214
Off power steering won't be affected by less droop in the front. On power yes, as it keeps the weight transfer to the rear down. But off power going into the turn you want the weight transfered to the front, hence more rear droop and a stiffer rear spring. These changes will transfer more weight quicker to the front resulting in more steering. I would start with the droop first...I'd bet it'll be enough.
Now if you want more on and off power steering, then yes also take away some front droop...but be careful that it doesn't make the car loose on power as with less front droop there will be less weight transfered to the rear and then less traction.
Old 09-08-2006, 01:15 AM   #5215
P956LH's Avatar
OK gotcha. Thanks a lot.
Old 09-08-2006, 01:48 AM   #5216
maxepower's Avatar
Red face SPRING-TIME!
I see what your proablem is, your running AE springs instead of Tamiya springs.
It's like running Ford parts on a chevy! It just won't work!
Seriously, unless your running carpet or indoor asphalt with very hight traction, the AE springs have way too much pressure.
The most spring pressure I ran on asphalt is the white but this was high grip track,usually run yellow or blue with medium to low traction These are Tamiya springs!
Not sure about the blue? Aren't the AE golds in the 20 lb. range?
Lighter springs will probably solve your problem!
Just my2$
(Tamiya spring pressures):
Purple 22.72
Gray 20.91
White Short 17.54
Silver 16.13
Blue Short 15.69
White 15.27
Blue 14.08
Yellow Short 13.99
Yellow 13.33
Red Short 12.35
Red 11.86
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-08-2006, 08:31 AM   #5217
Default questions
hi all,
i'm actually looking for aluminum bulkhead for ta05. i understand there are different brands such as xenon, square and 3racing producting them. are there more besides these 3 companies? i intend to get the 3racing type as it looks pretty decent and the price is much lower compared to xenon and squre, but it seems like 3racing is not producing it anymore as it was labeled as unavaliavle all the time.
is there a chance to purchase it any where? if not, are there any brands producing it besides the 3 i've mentioned? thank u very much
doodoo is offline   Reply With Quote
Old 09-08-2006, 08:58 AM   #5218
Default ..
i've done lots of hop ups and mod to my ta05.
1. xenon graphite chasis
2. full titanium screws
3. aluminum motor mount
4. aluminum side motor brace
5. aluminum racing steering
6. center 1 way
7. trf shocks
8. front aluminum suspenion mount
8. rear aluminum suspenion mount
10. front carbon damper stay
11. rear carbon damper stay
12. carbon center plate
13. high precision diff
14.
and the list goes on and on. i've already hopped to the stage that i can even build out another ta05 from my spares. i've spent lots of time and effort and the amount of $ spent together is definately more den buying a 415msx. but after so much, it still seems a grade lower den trf415msx in the eyes of others. quite sad but i really like my car. i juz some how felt that if i fully hop it up, it has the potential to out run the 415.
actually sometimes i'll ask myself y don't i juz get a 415msx instead as it cost lesser, but i like the structure of the ta05. i believe its weight distribution and handling can win 415. its all my own views though. but something to be sure of is, its definately a unqiue car
pls don't flame me i juz wanna share how i felt bout the whole ta05 thing.can u all share your views too? pls correct me if i'm wrong in any point. thanks
Old 09-08-2006, 10:29 AM   #5219
chappi's Avatar
Trader Rating: 17 (95%+)
just wondering... when will be TA05-R release..hehehhe
chappi is offline   Reply With Quote
Old 09-08-2006, 10:38 AM   #5220
JayBee's Avatar
Trader Rating: 31 (100%+)
Flame you!? What idiot would do such a thing? The TA05 IS AN AWESOME CAR!!! There's a fella (Jeff Kuney) at my local track *SIR* that's cleaning house with the thing. Two weeks ago we had a GT3 Series ending at our track with Triple A's and he and myself went one & two against a fully bad ass class of Silver can racers. We both were running TA05's (mine is fully hopped to Tamiya specs & his is not so hopped up AND he's got the stock plastic chassis on it still!!) Two weeks before then a bunch of our locals went to TCS Nats and he got 3rd or 4th in the A (GT-2).
And in the past week, he's beaten up on all of our MRE's (there's 14 of us who have them ), Yokes and X-Ray's. Even the BEST driver at our track (Tamiya sponsered Dan Garber) has felt the wrath of the TA05 I do have to admit though that it is Dan's set-up on the car that makes it work so good but Jeff is driving the hell out of the car.
So to anyone that is saying that the car isn't competitive against the top end cars- I BEG TO DIFFER
BTW if anyone is looking for a KILLER set-up to try, give me a holla. Dan's set-up is the SHiZniT...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
