Like Tree2Likes
Old 08-30-2006, 10:55 AM   #5161
High stress points - steel
Medium stress - Titanium
Low Stress - Alluminium
DA_cookie_monst is offline   Reply With Quote
Old 08-30-2006, 11:09 AM   #5162
JayBee's Avatar
Trader Rating: 31 (100%+)
Or you can forget all the MADNESS and use stainless steel throughout
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-30-2006, 11:27 AM   #5163
gibbous's Avatar
I used titanium on the shock tower mounts and aluminum where I could, guess what I saved?
0.6 of an ounce
Steel stayed at the shock end mounts and the bumper. And that screw for the servo. I probably have maybe 10-12 steel screws left. Everything else is aluminum or titanium.
Looks pretty, but that's all, really.
gibbous is offline   Reply With Quote
Old 08-30-2006, 11:53 AM   #5164
JayBee's Avatar
Or Titanium...
Old 08-30-2006, 12:31 PM   #5165
0.6 of an ounce
Are you refering to the whole car with ti screws you only saved .6 of an ounce of weight or just the shock towers ?
If that small savings, is it worth the money to invest into ti screws ?
Tks for all the respond.
kowkl2 is offline   Reply With Quote
Old 08-30-2006, 01:11 PM   #5166
gibbous's Avatar
My whole car has Ti AND aluminum. Ti at the shock tower and aluminum everywhere else.
I haven't tried Ti everywhere. I think it's a costly. If the "feel" of one Ti screw versus one steel screw in your hand is any indication, you wouldn't save very much weight anyway going all Ti. But you do have the convenience of hex screws. To me, that's the real benefit - less stripping! However, you can get this for less money with aluminum. I went with Ti at the shock towers because I've snapped aluminum screws using them at the same spot on other cars.
Well, that, and like I said, it's prettier.
Old 08-30-2006, 09:11 PM   #5167
2CARTEAM's Avatar
I'm running-
1 XC- FRT/FRT
1 XD- FRT/REAR
1 XA- REAR/FRT
1 B- REAR/REAR
The white springs are not actually white, they're the limited edition 'Milky blue' ones. And in front I'm running Blues & in the rear Yellows. I run on high-bite indoor asphalt & the car is hooked up big time
The pics doesn't show the changes I made in the rear but I have the alum. diff in now & 2mm spacers under the outer camber link; that really planted the rear end.
Jaybee
What is the total sweep in the front and the total sweep in the rear. I dont think i have these blocks and i'm trying to see what i can achieve with the blocks I have.The biggest problem i'm having with the car is the rear end breaking loose on power. let me know what you suggest.
Ko Propo America, Ulti tires,Vp Racing Fuel, Rc Target, Capricorn, ASM engines, Activ rc, Lion art prints,
2CARTEAM is offline   Reply With Quote
Old 08-30-2006, 10:16 PM   #5168
check your front droop. You should be able to lift the front of your car a least 3mm without the front tires leaving the ground. That should allow enough weight to transfer to the back tires and keep the rearend planted on power
DOTMAN is offline   Reply With Quote
Old 08-30-2006, 10:24 PM   #5169
Trader Rating: 23 (100%+)
You learned 3mm is what you tried?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-31-2006, 12:19 AM   #5170
maxepower's Avatar
Talking Loose on power condition!
Alex,
On the blocks, it's 1/2 degree for each size difference. For example, say on the rear your using A block f/r and C block r/r . So it is 1.5 degrees. same with the "X" blocks say your using XC in the f/r and XA r/r you still have 1.5 degrees, just the narrower your wheel base with the X blocks!
I know Christian is running mod and if you go on power the tires tend to want to break loose. But, you can increase the front droop to transfer the weight to the back when you go on power. Keep increasing the front droop until you keep the backend from breaking free. The downside is you'll loose some on power steering but you can shim the blocks to bring back the steering. The MR set-up or the Josh Numan set-up will show you what shims to lay under the blocks. They are both a little different but they will both have the same results but at different levels. I've also noticed that especially in the rear, the shocks need to be tweak free, i.e. perfectly equal as possible from left to right. Shock length, rebound and spring length, have to be as identical as possible. If not then the shocks react at different rate from each other and will cause the tires to grip the track unevenly and have the car feel like it's loose on power. Ask Timmy, how he sets up his shocks to keep them equal as possible. He should be at the Tamiya track on Sat. What can I say?
The Teacher has trained the pupil well!!!
P.S. Hey Mark D.
Can you p.m. me your set-up from the finals? Can you also give me your brush, spring combo and gearing? Inquireing minds want to know!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 08-31-2006, 12:34 AM   #5171
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by maxepower
Alex,
Max, Alex...
if you have A - C suspension blocks.. this will only give you 1 deg of toe in. (without adding the built in toe on your rear hubs).
A-B = 0.5
B-C = 0.5
the graphite rear hubs are 1deg... and the newer Tamiya GT1 cars come with 0deg hubs.
check TryHard's website for the Toe Block spreadsheet for reference.
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-31-2006, 10:03 AM   #5172
Yup, worked great. My car worked pretty well last Saturday on old B3s and an NSX body. When I put on Sorex and a Mazda6, it was even better
Old 08-31-2006, 11:27 AM   #5173
Looking at going indoor racing during the UK's winter months and looking at the TA05 and just thought i would ask a question or two.
Im not looking at spend much on the chassis as i want to keep it fairly standard as im just racing for fun, do you have any hints and tips for racing on carpet with CS22 tyres ?
What parts should i get as spares just incase i do manage to crash it fairly hard ?
What sort of size 64dp size spurs am i looking at for the car ?
Thanks in advance.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 08-31-2006, 11:41 AM   #5174
usual sort of suspension components for breakages.
Roll Bars, softer rear springs and glue the front outer sidewalls.
Old 08-31-2006, 12:31 PM   #5175
lbckevin's Avatar
Trader Rating: 91 (99%+)
Here is a link to Try Hards website.
http://www.thard.co.uk/excel.html
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is online now   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
