Like Tree2Likes
Old 08-28-2006, 10:46 PM   #5146
big al's Avatar
Hey guys, I picked up the carbon batt.retainer today and found out that the blue standoffs are way to tall for side x side cells. Luckily,my buddy had a couple of corally giants o-rings that worked perfectly. What have you guys done to make this work properly.
On another note, I've come to the conclusion that this car loves the chassis roll. I've gone throuhg many set-up changes and shock oils (stock shocks) limiting chassis roll,but the car loves the roll. I was however, able to find a set-up that doesn't use sway bars,but still performs very well.
Anyone know the part # for the tamiya grey springs, or if they are even made anymore?? Thanks for the info guys--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 08-29-2006, 02:15 AM   #5147
vega_B's Avatar
care to share the setup al? i've been struggling to find the setup without using the swaybars.
does anyone knows how to mod the stock cva shocks? to make it perform better? i cant afford to buy the trf shocks. .
vega_B is offline   Reply With Quote
Old 08-29-2006, 02:55 AM   #5148
vege_B, go buy the TRF pistons, 3 hole and 2 hole is the simplest tuning mod, and then springs.
Carbon Battery Brace, not to sure, I know on the kit retainers, they sit on a plastice spacer, is that the same for the blue ones?
DA_cookie_monst is offline   Reply With Quote
Old 08-29-2006, 05:26 AM   #5149
vega_B's Avatar
DA_cookie_monst,
thanx for tips! how about the o-ring? i've found that the shocks are leaking, so any ideas? do i need 2 change the o-ring too? to rtf ones?
Old 08-29-2006, 05:58 AM   #5150
ntc3freak's Avatar
Originally Posted by vega_B
DA_cookie_monst,
LOL Azri,TRF o-rings la,not rtf
ntc3freak is offline   Reply With Quote
Old 08-29-2006, 08:34 AM   #5151
vega_B's Avatar
hahaha. .typo kiddo. .
Old 08-29-2006, 08:49 AM   #5152
You could try them, or even the better thing would be to see if the TRF piston guides would fit in the CVA shocks (they come with the seal kit).
Guys, I just sprayed up the Subaru 2.0 shell Tamiya do, and it comes with two wings, anyone know which give more rearend grip?
Old 08-29-2006, 09:57 AM   #5153
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
The wing on your left.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 08-29-2006, 10:45 AM   #5154
Trader Rating: 31 (100%+)
If you have the traction, run sway bars. It makes the car transition quicker and causes less wear on the tires.
A good non-sway bar setup is:
Ball Diff up front: Yellow Springs in Front, Blue in the Rear.
With One-Way: Blue Springs in the Front, Yellow in the Rear.
ittjv is offline   Reply With Quote
Old 08-29-2006, 12:19 PM   #5155
The tech @ Tamiya told me that the TRF piston is smaller than the CVA pistons and too much oil will pass thru and may not have good results in the CVA. The flourine shafts work, but expensive.
Fuse is offline   Reply With Quote
Old 08-29-2006, 12:53 PM   #5156
according to the TA05 guide book, it is 0.1mm bigger diameter but has much larger piston holes....
Old 08-29-2006, 05:03 PM   #5157
Well, I guess I will just try it and see for myself if it fits.
Old 08-30-2006, 06:00 AM   #5158
vega_B's Avatar
guys,
im getting a new set of spurs and pinions. i need 2 know what is the biggest and smallest 64-pitch spur n pinion combination that can fit tao5.
currently im using 48-pitch type. i know that if switch to the 64-pitch ones, it will not going to be the same. i have no experience using the 64-pitch type. tips and tricks are most welcome
cheers,
Old 08-30-2006, 07:37 AM   #5159
Default Titanium Screws
Hi Guys,
I would like to check what have you guys used as replacement for the screws that comes with the carbon shock tower ? The ones that hold the retainer for the shocks .
The other screw is for the servo retainer. The one that closer to the side where you have to screw from the bottom of the chasis.
My question is replace or remain ? If replace, with what kind of ti screw ?
Any help is much apprecaited.
Tks.
kowkl2 is offline   Reply With Quote
Old 08-30-2006, 10:29 AM   #5160
hpipro321's Avatar
Originally Posted by kowkl2
Hi Guys,
Tks.
rc screws are good cheap screws that serve there purpose. or alluminum screws are good, thats what i use
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
