Like Tree2Likes
Old 08-13-2006, 06:15 PM   #4966
akuhon's Avatar
Originally Posted by DA_cookie_monst
78 safe, 79 is risking it
But I'm using 82 and it's just fine.. so far..
akuhon is offline   Reply With Quote
Old 08-14-2006, 02:46 AM   #4967
ntc3freak's Avatar
hey guys,how many of u is racing modified with the TA-05???how does it cope against the 415s,T2s,etc.Btw,why does most people complain about the lack of space for electronics???i saw my friend's car n he's running LRP Sprinter ESC,normal servo,and a big receiver.yeah,the receiver stands,but with my helios' receiver,it should be able to sit.Btw,where are the pics of ur cars???wanna see some TA-05s.Love seeing them
ntc3freak is offline   Reply With Quote
Old 08-14-2006, 02:42 PM   #4968
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I guess some items do have a problem fitting right in the TA05.. I first had a LRP Runner and F1.. no dice... sold those, got a Rapida Pro, it fits perfectly.. so did the GTX.
Plus, the 3-channel Airtronics receiver had to be mounted on the servo until I found a used 2-channel micro.. 92826.. fits like right in there like a charm, has just one extra plug for the PT.. all I need
Picked up the Hitec HFS-03MM for my 12th scale, but it also fits flat in the TA05.
The KO fits fine, and there's a new Airtronics receiver coming out, looks like the same small footprint as the KO.
A logical place for the PT would have been on top of the servo, but I was getting mad glitching all the time.. took me a couple races and a few rams into the wall to figure out the problem, velcroed the PT to a piece of lexan bolted right on top of the front shock tower, faaar away from the servo and receiver, saturday was my most successful (and damage-free) race in months..
This is a quickie pic with my cell-phone cam.. gotta clean that right side of the lens..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-14-2006, 02:50 PM   #4969
Hebiki's Avatar
Trader Rating: 26 (100%+)
jam.. why not just put it on top of the bumper brace? thats where i have mine. just in case its a race to the finish line.. your transponder will cross the line first.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-14-2006, 04:05 PM   #4970
I just got the 3Racing chassis, and although the original chassis was a tad tight for the ESC, a little ingenuity cleared that problem, now I just got to get my 3Racing chassis finished, then I can lease some space for electrics for T2 owners.
I got to admit, although I was dubios at first about ordering the chassis, now I got it, it is a nice peice of kit, only thing that needs doing it to open up around the back of where the pinion is, on the topdeck to improve access a little. And I still can't understan the need for the two peice deck either.
DA_cookie_monst is offline   Reply With Quote
Old 08-14-2006, 04:20 PM   #4971
Send a message via MSN to TAMIYAMANUK
will get a pic of mine up but is in middle of a rebuild after a broke the stock tub chassis just a good excuse to get the CF one
TAMIYAMANUK is offline   Reply With Quote
Old 08-14-2006, 04:30 PM   #4972
here is mine, mid build, just waiting for some new suspension to come through.
Old 08-14-2006, 07:35 PM   #4973
dodo's Avatar
Send a message via Yahoo to dodo
yeah, happened to me before. i was racing neck to neck all the way, and i crossed the finish line first. but alas! the result said different and after i checked it, i realized that the other guy had the transponder mounted at the nose of the car
dodo is offline   Reply With Quote
Old 08-14-2006, 10:34 PM   #4974
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
Default Belts
I put my car together and haven't ran it yet but I did notice the belts are a bit loose. How hard is it to tighten the belts? What tooth do you have your belts on? Good thing I look in the manual on what to do. Just would like some info from u guys.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 08-14-2006, 10:45 PM   #4975
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Well I have to admit I strayed for 2 weeks with a Corally............I am back to my TA05 now.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-15-2006, 12:07 AM   #4976
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Has anyone tried running the Orion Lipo pack on the chassis. Does it fit well without any mods?
YR4Dude is offline   Reply With Quote
Old 08-15-2006, 03:36 AM   #4977
On the kit belts, I run the rear kit and the front one notch looser, on the blue aramid and 3Racing chassis, I run both one looser than stock.
One thing, once you got the transmission built, stick a motor in there and run it at 3 or 5v for half our or so, this helps settle the belts down a little.
Old 08-15-2006, 10:00 AM   #4978
hpipro321's Avatar
this is a must for the armid belts, or just check em every run to make sure they are intact, those belts are fragile
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 08-15-2006, 10:30 AM   #4979
Hebiki's Avatar
4800 "brick" lipo sits up higher than a traditional side by side pack. the new 3200 lipo fits much better and sits lower. i was able to test fit it when Rick Hohwart (sp?) came out to the tamiya track.
Hebiki Design Works
Old 08-15-2006, 10:36 AM   #4980
YR4Dude's Avatar
....the new 3200 lipo fits much better and sits lower. i was able to test fit it when Rick Hohwart (sp?) came out to the tamiya track.
True dat, but will the new lipo pack be out in time for all of us (self sponsored grunts) to have before the KO race?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
