Like Tree2Likes
Old 08-01-2006, 08:03 PM   #4861
oh ok. nice ta05! im just gonna run mine with the tub and a few hop ups. im not into the graphite thing. what mounts can i use with a 46mm universals (im not using the LW susp.) and to obtain the same set up with the stock mounts?
Davel is offline   Reply With Quote
Old 08-01-2006, 08:18 PM   #4862
nexxus's Avatar
Trader Rating: 302 (100%+)
I run a second TA05 for Tamiya races, have only used Tamiya hop ups, and now am facing waiting on an answer if my clear blue bulkheads (Part 49390) are legal as the Australian distributor hasn't brought them in yet. (Strangely they say the M03M chassis is legal in Mini class, but they haven't brought that in yet either?!?!)
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 08-01-2006, 09:02 PM   #4863
dodo's Avatar
Send a message via Yahoo to dodo
hmm i have to check again on that, i forgot haha. but i think it's stated in the manual which mount can be bought to replace the original plastic mount.
dodo is offline   Reply With Quote
Old 08-02-2006, 01:31 AM   #4864
SpeedTech's Avatar
anybody?
I believe last year at the Tamiya track, 23T were geared down to around 5.76-5.9 area.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-02-2006, 02:18 AM   #4865
those clear blue bits aren't suppose to be very good, more for 'shelf queen' cars.
DA_cookie_monst is offline   Reply With Quote
Old 08-02-2006, 02:54 AM   #4866
nexxus's Avatar
I have run them on my hopped up TA05 and they seem ok, not really on load bearing parts anyway!
Old 08-02-2006, 04:18 AM   #4867
so what pinion can be used with a 70T spur to attain to these ratio?
Old 08-02-2006, 06:05 AM   #4868
rccardr's Avatar
Use A/A mounts front and rear. I have used a regular mount for the rear front (instead of a bridge mount) without problems.
70/27*2.25= 5.83; 70/28*2.25=5.63.
Lucky boy, you only need 2 pinions!
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 08-02-2006, 07:02 AM   #4869
nexxus's Avatar
How big is the track? When I run a Type S Stock motor, I use a 22 pinion, when using a sports tuned, a 24 pinion
Old 08-02-2006, 08:37 AM   #4870
hey,
I recently bought a second hand TA05...it's all good except that the centre pulley (for the front belt) is completely stripped of teeth and the front belt is a bit frayed...
so I've bought two new blue aramid belts and some new centre pulleys etc...but now I have the problem of a VERY tight drivetrain. I've already loosened the front belt so that the little dot on the bearing holder is right in the middle (thats two notches looser than the manual says to go) but it's still very tight....where could my problem be coming from?
I'm worried it may be that the pinion is meshing too tight with the spur gear but I'm not sure how tight it should be
help me please
thanks
-jimmy
thommo09 is offline   Reply With Quote
Old 08-02-2006, 09:37 AM   #4871
Best thing to do is pull the pinion off, if it is still tight, then it is the gear mesh between spur and pinion, there should be a small amount of backlash there.
Old 08-02-2006, 10:13 AM   #4872
hpipro321's Avatar
Originally Posted by thommo09
hey,
help me please
thanks
-jimmy
make sure the markings line up or the belts will stay tight,
they have to be the same for each dot on the markings
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 08-02-2006, 10:24 AM   #4873
lbckevin's Avatar
Trader Rating: 91 (99%+)
If the belt is too tight, back it off another notch. The blue belt needs constant adjustment.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-02-2006, 10:33 AM   #4874
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Really? I set mine 1 notch looser when they first came out 6 months ago and haven't touched them since. I haven't had a problem yet...
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 08-02-2006, 10:36 AM   #4875
lbckevin's Avatar
It states on the belt header card to adjust as necessary for humidity.
Meaning, if there is a temp change, you may need to adjust the belt, looser or tighter.
Kevin Smith
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
