Like Tree2Likes
Old 07-16-2006, 09:51 PM   #4741
shift's Avatar
Originally Posted by yellow15
hey, is that with 1300/1400 batteries? what body were you using when you weight the car? and any heatsink/capacitor?
It was with 1300 batteries and a ride accord body, no capacitor but it had a heatsink
shift is offline   Reply With Quote
Old 07-16-2006, 10:37 PM   #4742
racenut's Avatar
Trader Rating: 15 (100%+)
Cutting the chasis will make it lighter but it will be illegal in most tracks..pluss it will flex..
racenut is offline   Reply With Quote
Old 07-16-2006, 10:37 PM   #4743
racenut's Avatar
deleted:
Old 07-16-2006, 10:44 PM   #4744
lbckevin's Avatar
Trader Rating: 91 (99%+)
racenut,
Why would you post that ?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-17-2006, 10:22 AM   #4745
OCMike's Avatar
Trader Rating: 24 (100%+)
Default TAO5
I was looking for some feadback (good or bad) on the Tamiya Nissan Impul body have you run this on your TAO5. Handling wise !!!!!!!!!!!
OCMike is offline   Reply With Quote
Old 07-17-2006, 01:00 PM   #4746
It is not bad Mike usually a good all rounder. The NSX any of the later versions are usually good.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 07-17-2006, 01:32 PM   #4747
OCMike's Avatar
Default NSX
Thanks D... I just wanted something different that handled OK....There is going to be so many NSX body's out there it's going to look like SPEC TCS...haha
Old 07-17-2006, 02:10 PM   #4748
MikeR's Avatar
There's a reason you'll see so many NSX's, laptimes
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-17-2006, 10:37 PM   #4749
racenut's Avatar
Originally Posted by lbckevin
racenut,
Sorry it was a double post. I just edited the 2nd post..my mistake
Old 07-18-2006, 09:30 AM   #4750
hpipro321's Avatar
nsx or ferrari are good
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 07-18-2006, 10:28 AM   #4751
Scarab's Avatar
Exclamation Question???
I have just finished building my TA-05. I just put it on my setup board to set the ride height and with the TRF shock collars bottomed out, it still won't sit lower than 5.5 mm.
1st question: What do you set your ride height to?
2nd question: Do I need those shock spring holders that drop the springs by 1mm.
3rd question: Should I redo my shocks and put the black o-ring under the piston inside the shock to reduce the shock length.
Please help.
Scarab
Team Monkey Spankers (TMS)
Losi Ten-SCTE 2.0
Jammin SCRT 10
Mugen MBX5-T ProSpec - O.S. .28 XZ [b]FOR SALE![/b]
Traxxas Revo - O.S. .18 TM [b]FOR SALE![/b]
Scarab is offline   Reply With Quote
Old 07-18-2006, 10:33 AM   #4752
lbckevin's Avatar
Scarab,
I use the 1mm lower spring holder and the shocks go to 4mm ride height. What shock mount hole are you using ? I use the third down from the top and no problems. Also, make sure you screwed in the bottom ball cup and the shaft all the way in and equal on all four shocks.....and press the spring retainer all the way down onto the ball cup, sometimes it just sits on top and you have to press it all the way down.
Hope this helps...
Kevin Smith
Old 07-18-2006, 10:54 AM   #4753
Regional Moderator
Darkseid's Avatar
Please help.
Scarab
I'm going to take a guess and say that your using the yellow springs that came with the TRF shocks. The car will only go so low with those on.
Your options are:
1. Screw the ball cup in as far as possible and see what that leaves you with ride height wise.
2. Get the 1mm down spring retainers
3. Use Tamiya short springs instead. They have a slightly different stiffness rating, but its still close.
4. Don't worry about it. Thats right, stick with the height your at, and go out and try the car out. At first I had the same problem, but then I ran the car with the full length yellows on, and it ran so well, that I didn't care what the ride height was at. As long as the car kept running well.
TLR 22...Tamiya F104...
Old 07-18-2006, 10:56 AM   #4754
Scarab's Avatar
Thanks! I think I'm going to go with the short springs set. Anyone have a part number???
Scarab
Losi Ten-SCTE 2.0
Jammin SCRT 10
Old 07-18-2006, 11:05 AM   #4755
Regional Moderator
Darkseid's Avatar
Scarab
Heres the numbers:
-Full set of short springs (1 pair each color)- TAM53440 $14.25
-Short yellow springs (1 pair)-TAM53631 $3.99
Those prices are from this page at Speedtech RC
Speedtech RC TA05 shock parts page
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
