Like Tree2Likes
Old 07-13-2006, 05:40 AM   #4681
shift's Avatar
A guy here in auckland uses a ta05 in mod and he is coming about 2nd so theres no dout that a ta05 will be competive in mod
shift is offline   Reply With Quote
Old 07-13-2006, 05:43 AM   #4682
what hopups is he running??
surely it's not stock components..
el
elusiver is offline   Reply With Quote
Old 07-13-2006, 05:46 AM   #4683
cannon's Avatar
Trader Rating: 35 (100%+)
Besercoe in Australia is running a TA05 with a brushless system. He is running all TA05 hopups. The car doesn't seem too bad.
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-13-2006, 05:52 AM   #4684
shift's Avatar
its almost stock standard the only hop ups are universals, front one way, and armid belts. he had a ta05 with full carbon fibre chassis and aliminum parts but he sold that and just uses the almost stock standard car
Old 07-13-2006, 07:54 AM   #4685
warren_s's Avatar
Send a message via MSN to warren_s
Smile
Thats good news.
I have all the hopup for the TA05 except the one-ways. Looking forward to Wednesday night.
Waz
All gods creatures have a place alongside my chips and gravy
T2'007 - resting / TRF 501x x 2 RIP / Durango DEX410 - All I can say MFG "WEAPON"
TC12L4 - why? / TC5R - Love that car /M05 Pro little bit on fun
MBX5R - noisy bugger / SC10 / T4 x2
warren_s is offline   Reply With Quote
Old 07-13-2006, 09:48 AM   #4686
Regional Moderator
Darkseid's Avatar
Originally Posted by MK_Arbiter
My TA05 had perfect grip on my hardwood floors with the 45 shore tires... So why would it slide so much on asphault?
Well if your convinced that the 45 shore tires are not the problem, then theres probably not much help that we can offer.
Traction comes from two places, tires and set up. Looking at the original set up you posted, it didn't seem bad at all. So if its not the set up, then....
TLR 22...Tamiya F104...
Old 07-13-2006, 09:59 AM   #4687
Regional Moderator
Darkseid's Avatar
Originally Posted by racenut
Do you guys have any special mods made in your tao5???
By special mods, do you mean like other than bolting on premade hop ups?
I don't think too many people are making special mods to their TA05 cause it would make them illegal for TCS. I've modded my carbon graphite chassis slightly to get my Platinum LiPo to fit. But even that mod wont be neccesary in about a month when Orion releases their new version.
So other than that, it doesn't seem that there is much to mod. It seems that unlike some cars (cough...cough...JRXS) Tamiya got things right with the car from the get go. So hand fitting and modding aren't needed.
Old 07-13-2006, 10:04 AM   #4688
MK_Arbiter's Avatar
Would the shock angles have anything to do with it?
MK_Arbiter is offline   Reply With Quote
Old 07-13-2006, 11:10 AM   #4689
Regional Moderator
Darkseid's Avatar
Where do you have your shocks mounted at? Are you using the stock towers or the graphite towers? With either one, the stock locations are a good place to start. But I've always used shock positioning as a fine adjustment, not to solve a drastic traction problem.
Old 07-13-2006, 11:23 AM   #4690
Scarab's Avatar
Can someone posts their successful TA-05 setup for running the indoor asphalt @ Fredrick's Coliseum? I'd like a baseline good setup to start with so that I can tweak it to my tastes.
Thanks,
Scarab
Team Monkey Spankers (TMS)
Losi Ten-SCTE 2.0
Jammin SCRT 10
Mugen MBX5-T ProSpec - O.S. .28 XZ [b]FOR SALE![/b]
Traxxas Revo - O.S. .18 TM [b]FOR SALE![/b]
Scarab is offline   Reply With Quote
Old 07-13-2006, 11:27 AM   #4691
MK_Arbiter's Avatar
I'm using the stock shock towers and the front is on the third position. on the end. the rear is on the third position too.
Old 07-13-2006, 11:34 AM   #4692
Regional Moderator
Darkseid's Avatar
That sounds like you have them in the stock positions. So I can't imagine that its causing added traction problems.
Just try the lighter oil first and see what happens.
Old 07-13-2006, 11:56 AM   #4693
MK_Arbiter's Avatar
will 25 weight be too light because that's all i have... unless you can mix oils for different viscosities.
Old 07-13-2006, 12:04 PM   #4694
Regional Moderator
Darkseid's Avatar
Yeah, I think 25wt would be quite a bit too light most likely.
It may be time for a trip to the hobbyshop. I think I saw you say you were a novice racer, but eventually we all have to bite the bullet and start building up our racing supplies.
Some 40wt or 45wt oil and a set of pre-mounted Take-Offs CS27 might be a good place to start.
Or if you don't have the money right now, the oil that came with the kit I believe was around the 40wt range. So give that a try.
Old 07-13-2006, 12:11 PM   #4695
MK_Arbiter's Avatar
Well... Might as well get the stock shocks out. cause i don't think i have enough stock oil. Is there a way to just screw around a bit and try to make a lighter oil by mixing or will it just get thicker?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
