Like Tree2Likes
Old 06-19-2006, 04:30 AM   #4366
rampal's Avatar
Send a message via MSN to rampal
check your belts and diffs, take the motor off and push the car.... if it noises, disconnect front belt, if it still noises, take out front dogbones....this way you can isolate the origin. It happened to me once, but was motor bearings... (i have a brushless).
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 06-19-2006, 06:23 AM   #4367
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by TAMIYAMANUK
like a squeking noise buts its very loud as well really strange as well it doesnt effect the performance in anyway but man the noise its killing its that loud
Lube the one way.
I noticed a noise in the front drive train of my 05, and it was the one way.
tamiyarcracer is offline   Reply With Quote
Old 06-19-2006, 04:17 PM   #4368
Default center pulley C-clip
Is there any easy way to remove the C-clips on the center pulley? I was trying to remove mine last night... and gave up after 20 mins and a few fingers cut!!
It seems like impossible but i'm sure there must be an easy way.. anyone can help please...
yellow15 is offline   Reply With Quote
Old 06-19-2006, 04:25 PM   #4369
Slotmachine's Avatar
Send a message via MSN to Slotmachine
It seems like impossible but I'm sure there must be an easy way.. anyone can help please...
Try a tooth pic, insert it through one of the little holes slowly and the natural taper of the tooth pic will squeeze it off. If you have a metal tapered pic that will work better, just don't poke your fingers.
Paul.................................
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-19-2006, 04:32 PM   #4370
Redwings's Avatar
Originally Posted by Slotmachine
Paul try THIS to make your own gear chart............
Hey Guys Can anyone explain why I am converting gearing ratios that I'm getting readings like 0.87 for a 70/27 for Canadian TCS legal specs is 5.7 for GT2 I have used the chart and inputed the information for a TA05 thats what I get.
What am I doing wrong there
Paul
Redwings is offline   Reply With Quote
Old 06-19-2006, 04:51 PM   #4371
Hebiki's Avatar
Trader Rating: 26 (100%+)
Paul
70 / 27 = 2.59259
2.59259 x 2.25 = 5.83333
(Spur gear divded by Pinion) multiplied by internal ratio = Final Drive Ratio
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-19-2006, 04:52 PM   #4372
JimmyMac's Avatar
I can do it with ease just using small needlenose pliers. Just push on the ends of the c-clip with the ends of the needlenose pliers. It'll just slide/pop off. Just be sure to aim it down and onto a pit towel or something so you don't loose it.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-19-2006, 05:13 PM   #4373
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Heads up on anyone wanting a bling machine.
http://rctech.net/forum/showthread.php?t=118462
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-20-2006, 11:08 AM   #4374
Has anyone else noticed these?
http://www.tamiyausa.com/product/ite...uct-id=2520022
I found out from Tamiya that they are Ti. Plus they would be TCS legal.
-Jason
juggalorc is offline   Reply With Quote
Old 06-20-2006, 11:42 AM   #4375
-Jason
Thats cheap Jason, go for it!
Old 06-20-2006, 11:52 AM   #4376
-Jason
Those are just normal steel ones that you can find in TT-01 Turnbuckle Tie Rod Set.
trf_racer is offline   Reply With Quote
Old 06-20-2006, 12:34 PM   #4377
Send a message via MSN to TAMIYAMANUK
i think i might of found the problem with the loud noise i had i have seen the bearings shield bent in and is scraping the insides of the bearing so i will replace it and see
just another quick question i know it sound stupid but has any one treid the 05 in the wet? i know you shouldnt but was thinking of givin it a go just kit it out with some water proof stuff and have a go?
ash
TAMIYAMANUK is offline   Reply With Quote
Old 06-20-2006, 03:44 PM   #4378
pic of bearing
Old 06-20-2006, 05:14 PM   #4379
OKie thanks, i tried a toothpic but the gap between the clip and the pulley simply isn't big enough for me to do anything then i tried the plier and after a while i finally got it to came off. Anyway thanks for all your suggestions!
Old 06-20-2006, 10:01 PM   #4380
Send a message via AIM to A-Ko
I have been leaving them off.... mainly for the very reason that you are running into. Seems to work fine.
Jeff
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
