Like Tree2Likes
Old 06-14-2006, 09:51 AM   #4351
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by juggalorc
So with the stock shocks I should be OK. What about with the TRF Fluorine Coated Dampers # 53571? or would those have the same problem? And are they the threaded bodies?
I'm planing on starting with a 104/35 when I race next week. Hopefully this should be in the ball park with a 19 turn.
I'm just trying to get all my basic tuning options lined up before I get to the track.
-Jason
try a 104x33 first...................
Florine coated is the way to go with the short mini springs. Almost all of the guys at my track are running them.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-14-2006, 10:47 AM   #4352
Just picked up my stabilizer set. Can't wait to get this car on the track.
I'm prob. going to pick up those shocks in about 2 weeks. Unless someone has an extra set that they are willing to part with .
Any advice on a good starting point for carpet rubber tire?
-Jason
juggalorc is offline   Reply With Quote
Old 06-14-2006, 12:06 PM   #4353
Send a message via AIM to Bane
Any suggestions for gearing for Laurel Md TCS race (outdoor). I was told to run 48p outdoors and 64p indoors but cant find the part numbers for either. Only hopups will be cvds up front, precision diff joints, & precision center bushing. Also, what pinion would be best? running GT3 Silvercan class. Have to stick with stock everywhere else due to my moving at the end of the month so not much time to get it ready or order parts.
Bane is offline   Reply With Quote
Old 06-14-2006, 01:35 PM   #4354
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Just pick up any 64p spur gear up to 105T, for both indoor and outdoor.. saves you having to buy the extra pinions.. I've never had a problem running outside.
For a silver can, gear at 5.0 to 5.5:1 to start with, so with a 88T spur, try a 39 pinion for larger tracks, down to a 36 for smaller, tighter ones.
Any other motor will gear fine with a 105T spur and all its available, but the silver can is an exception.. I'm not sure if you could fit a 47T pinion..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 06-14-2006, 06:01 PM   #4355
racenut's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ntc3freak
guys,if i have around 200USD to upgrade my ta05,what would it be???i already have trf shocks,arb set,shock spring set.thanks
I wish that was my problem.. Lucky guy..
racenut is offline   Reply With Quote
Old 06-15-2006, 12:47 AM   #4356
ntc3freak's Avatar
lol got some money for my birthday
ntc3freak is offline   Reply With Quote
Old 06-15-2006, 01:26 AM   #4357
racenut's Avatar
this june 18 is my birthday .. Where can i get that money???
ok quick question here... I have tamiya type s motor mounted on my tao5. Im going to run it in medium grip and medium size track...What 64p spur and pinion can i use???
Old 06-15-2006, 06:41 AM   #4358
Hello everyone... after 20 years I decided to get back into RC racing. I've forgotten alot in that time, and boy have things changed!
I have some newbie questions I hope you TA05 gurus can give me some suggestions on. I've read the first 70 pages of this thread, there's some great information in here!! I run my TA05 on a tight indoor carpet track, on sauced rubber tires. Stock 27t Revenge of Monster motor. IB3600s.
1. Does anyone have any tight carpet track setup tips? Car is all stock except I do have the swaybar kit (none on the car as I get used to stock settings). The manual doesn't really have much to say about this.
2. Gearing reccomendations? I am running 19/70 and it flies but man does it get hot. It isn't much cooler than the stock 22/70 although it does accelerate better. Drop some more teeth on the pinion? Or is this normal for these crazy batteries and motors (remember my last experience with electric was in the 80s!!)
3. What is a good place to start with respect to gearing and this motor if I go to a large outdoor track?
4. Question on belt tightness: with the stock 2-clicks from center setting on the adjuster, the belts wander around on the pullies. Is this normal? I don't get any slippage except a few clicks on full out braking (this is normal on my Losi XXX4, so I assume this is also normal on this car).
5. How tight do I want to run my diffs for a tight indoor, or larger outdoor track? I have never run 4wd onroad before, so tuning the diffs is new to me.
Thanks in advance!
ducati is offline   Reply With Quote
Old 06-15-2006, 10:36 AM   #4359
MK_Arbiter's Avatar
There are some good setups on page 142
MK_Arbiter is offline   Reply With Quote
Old 06-15-2006, 10:17 PM   #4360
racenut's Avatar
Ducati
wellcome back to rcworld... keep on reading... there are lots of carpet set-up tips here, just keep on browsing...
Old 06-16-2006, 10:49 AM   #4361
Thanks MK_arbiter, thanks Racenut. Guess I should have kept reading the thread
Old 06-16-2006, 08:05 PM   #4362
Redwings's Avatar
Good luck, keep reading, LOL
Redwings is offline   Reply With Quote
Old 06-17-2006, 02:46 PM   #4363
Send a message via MSN to TAMIYAMANUK
hiya guys
just need some help i am gettin some really loud noise from the front end of the car, ive completely stripped all the car down rebuilt the car oiled all the bearings, oiled the front one way bearing etc rebuilt the uv joints at the front at the noise is not normal i mean its really loud? any help please?????
ash
TAMIYAMANUK is offline   Reply With Quote
Old 06-17-2006, 03:10 PM   #4364
Speed Demon's Avatar
what kind of noise???
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 06-19-2006, 04:24 AM   #4365
like a squeking noise buts its very loud as well really strange as well it doesnt effect the performance in anyway but man the noise its killing its that loud
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
