Like Tree2Likes
Old 06-12-2006, 06:42 AM   #4336
Speed Demon's Avatar
Originally Posted by KilRuf
I use 48mm up front and 46mm in the rear...
Thanks KilRuf.. I got it right.. my LW set just arrived today!
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 06-12-2006, 09:09 AM   #4337
Send a message via AIM to Bane
I was wondering if someone could provide me a list of the bearings sizes for the TA-05? I want to upgrade the bearings before the build with Avids but cannot find all the sizes and quantities needed. I would totally appreciate any help as I am trying to get this build started for the TCS on July 9th in Laurel, MD. Thanks for your help.
Bane is offline   Reply With Quote
Old 06-12-2006, 09:40 AM   #4338
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
# - IDxOD
8 - 5x8mm - 4 for Steering Rack, 2 inside each diff
4 - 10x15mm - 2 outside each Diff
2 - 4x8mm - Spur Shaft
Then,
8 - 5x11mm - Regular Suspension Axles
or
8 - 5x9mm - LW Suspension Axles
That should be it!
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 06-12-2006, 11:51 AM   #4339
Thanks alot. Ill get to ordering now. I really appreciate your taking the time to get me the info.. THANKS
Old 06-12-2006, 09:23 PM   #4340
big al's Avatar
Minicooper..Are your friends running gt3? Tht's what I'm entered in. I also entered gt2 for some extra track time. I've never run tamiya tires before (b3) and figure I could try little differences in set-up during the gt2 qualifiers.
Could anyone here comment on which type of tire the b3's are similar to...36r's,cs-27's or whatever. Thanks--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 06-12-2006, 10:13 PM   #4341
TXR2Racer's Avatar
I've just recently finished my hopped up ta05 project... I was wondering if anyone has tips and setup for carpet racing.... both for running stock and modified class... I'm installing a futaba digital servo, lrp sphere cometition, running either the novak 4300 for stock and neo 1 - 4 star for modified... I run mostly stock but would like to play around mod once in a while..
I think I went a little over board with the hop ups... the only thing I used from the brand new kit are very little of the plastic parts, belts, screws, center pully assembly, dog bones and diff pulley..and oh yah the foam bumber, which I will be replacing to... hehehehehe .. upgrade parts are mostly 3racing, Yeah racing and Top Cad...
Please help....
thanks,,,,
Tamiya TA05 Touring Sedan-img_4883.jpg   Tamiya TA05 Touring Sedan-img_4884.jpg   Tamiya TA05 Touring Sedan-img_4896.jpg   Tamiya TA05 Touring Sedan-img_4895.jpg   Tamiya TA05 Touring Sedan-img_4889.jpg
TXR2Racer is offline   Reply With Quote
Old 06-13-2006, 08:55 AM   #4342
Trader Rating: 14 (100%+)
TRX2Racer:
Hi,
Civic91 posted a carpet set up back on page 142. I suggest you try that as a starting place.
Sweet looking TA-05. all that graphite......all the blue.....
almost to pretty.
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 06-13-2006, 11:25 AM   #4343
I've got a couple quick questions after reading all 145 pages of this thread.
1. Are the #53440 Hard Spring set the short ones?
2. Does anyone have a good starting point for carpet, 19 turn with CS-27's?
Thanks,
Jason
juggalorc is offline   Reply With Quote
Old 06-13-2006, 10:56 PM   #4344
Hi everyone, im hoping someone can help me out with a setup for outdoor asphult with FOAM tyres, very large track.
I posted my setup back a few pages ago with not much replies.
Thanks in advance.
Dean
enricopalazzo is offline   Reply With Quote
Old 06-14-2006, 01:15 AM   #4345
rampal's Avatar
Send a message via MSN to rampal
Thanks,
Jason
Hi Jason:
These are the ones I'm using on my TRF shocks..... I think they're the short ones....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 06-14-2006, 02:07 AM   #4346
racenut's Avatar
Trader Rating: 15 (100%+)
Please help....
thanks,,,,
Lots of eye candy.... i sure wish my tao5 look like yours....
racenut is offline   Reply With Quote
Old 06-14-2006, 07:30 AM   #4347
ntc3freak's Avatar
guys,if i have around 200USD to upgrade my ta05,what would it be???i already have trf shocks,arb set,shock spring set.thanks
ntc3freak is offline   Reply With Quote
Old 06-14-2006, 07:33 AM   #4348
rampal's Avatar
buy a brushless and/or a lipo!!!! hehehe. The car is very good pretty much stock. buy also some aramids and when tamiya release it, the blue aluminum motor mount.....
Old 06-14-2006, 07:41 AM   #4349
Jam-ehz's Avatar
Thanks,
Jason
They're not the shortest you can get.. I've found that with those and the TRF Special Blue dampers, you can't get the front end any lower than 6mm..
You need to get the TRF Short springs, in the usual colours.. they're mostly what I use for my 05 and mini, and let you set the height anywhere..
On Road Short Spring Set
Soft (Red): 53630
Medium (Yellow): 53631
Hard (Blue): 53632
Extra Hard (White): 53633
Super Hard (Dk. Grey): 53635
Ultra Hard (Maroon): 53636
I also have this set, great for the mini and low traction areas. They're fluorescent Blue, Yellow and Red, softer than the short ones above.
Touring Car Tuned Spring - (Short): 53333
Old 06-14-2006, 09:07 AM   #4350
So with the stock shocks I should be OK. What about with the TRF Fluorine Coated Dampers # 53571? or would those have the same problem? And are they the threaded bodies?
I'm planing on starting with a 104/35 when I race next week. Hopefully this should be in the ball park with a 19 turn.
I'm just trying to get all my basic tuning options lined up before I get to the track.
-Jason
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
