Like Tree2Likes
Old 06-02-2006, 08:08 AM   #4231
Redwings's Avatar
Originally Posted by GreaseMonkey
You can download an RC gear calculator from here which also might help
http://waits.net/public/rcgears/
Sorry grease monkey but I was unable to unzip the file. Is that any other solution?
Paul
Redwings is offline   Reply With Quote
Old 06-02-2006, 10:28 AM   #4232
ttso's Avatar
Just put on 3racing chassis kit.... much lighter...
As I run on asphalt, I need the chassis to be flex for low traction asphalt. By removing steering column and rear 2F column, it's much much flex than original design. It's about same flex as stock TRF415 now, hope it's flex enough.
Tamiya TA05 Touring Sedan-dsc02773s.jpg   Tamiya TA05 Touring Sedan-dsc02778s.jpg   Tamiya TA05 Touring Sedan-dsc02779s.jpg
ttso is offline   Reply With Quote
Old 06-02-2006, 10:41 AM   #4233
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Paul
Paul try THIS to make your own gear chart............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-02-2006, 02:26 PM   #4234
Send a message via AIM to A-Ko
Nice! ! !
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 06-02-2006, 06:31 PM   #4235
BlackKat's Avatar
Originally Posted by linger
Al, If I remember correctly, the kit setting has the steering tierod connected to the outer (back) hole of the steering knuckle. If you move it up to the front hole, you will get 2x the steering and it will free up you rear end.
Ling: Thanks a bunch for stopping by. Once I start running the car I'm going to start PMing you a bunch asking questions My dad and I think it's great that your back out racing again.
Al: I told myself I wasn't going to call in sick this season b/c I was on the verge of being promoted but now management wants anyone that gets promoted to be 18 or over.....I guarentee that if I graduate high school, turn 18 and I'm STILL working there...I'll shoot myself.....LOL
With the lack of racing in NorCal this June I'm thinking of going to down to Gilroy and rebuilding the track so I can get some track time with the '05
BlackKat is offline   Reply With Quote
Old 06-03-2006, 12:36 AM   #4236
Redwings's Avatar
Thanks Slotmachine, that works
Old 06-03-2006, 02:05 AM   #4237
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Default Tamiya Carbon Chassis
Does anyone know if the tamiya carbon chassis is conductive? I remember having to use tape on my Losi XXXS chassis so my ladder packs didn't short out, and was worried about the same happening with the Tamiya one.
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 06-03-2006, 05:40 AM   #4238
nexxus's Avatar
Trader Rating: 302 (100%+)
I don't believe they are Dan, but I am staying away from these Carbon reinforced bits for now, they don't have as much flex so the extra brittleness actually can make it more prone to breakage.
nexxus is offline   Reply With Quote
Old 06-03-2006, 09:05 AM   #4239
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I have not had any problems with electrical issues with my graphite chassis/parts. I also haven't noticed that the car is more brittle at all. They seem to be just as tough. I have left all the suspension parts stock though. I don't see any huge benefit from using the hard suspension.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-03-2006, 09:34 AM   #4240
ttso's Avatar
I run my 3racing chassis first time today. The biggest improvement is in corner. My car used to slide away from my driving line. Now the car stay on driving line perfectly. As my setting is largly the same, it must be benifited from weight saving. Also, the accelration is faster than before as well.
I didn't try graphite chassis nor other brand carbon fiber chassis, but from what I tell on my car, those weight saving worth the spending...
Old 06-03-2006, 10:40 AM   #4241
Trader Rating: 14 (100%+)
CIVIC91:
Hi,
how much weight did you save by going to all Carbon composite chassis parts????? also do you run foam/carpet??
I'm thinking about going to all composite parts and the LW suspension as the Ta05 seems a little flexy with the stock tub for foams/carpet and it is a little heavy
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 06-03-2006, 11:57 AM   #4242
I've run both carpet with foams and asphalt rubber. For carpet I ran all the graphite parts/chassis...but I stuck with the standard suspension. It is prefered for carpet. The lightweight suspension was designed with rubber tires in mind. You have to run some HPI hubs/carriers to have clearence for foams with the light suspension. With the stock suspension you just need to add 1mm spacers to your wheel hexes and there is plenty of clearence to run 28mm foams. Also the light suspension breaks easier.
As far as weight savings...I believe all the graphite/plastic chassis/pieces saved around 1.5 ounces. But I have never felt as though the car was heavy on the track. It never pushed off the race line. I think that is more setup than weight. It felt as responsive, if not more so than several other high end cars I've owned (FK05-T2-JRXS-RDX)
And despite the "so called too much flex" is concerned...don't worry, the car rocks on carpet. Just get the chassis...and you'll be set.
Old 06-03-2006, 06:04 PM   #4243
CIVIC91:
Hi,
Thanks for your input. all we race is carpet/foams. no real good asphalt tracks around where we live and when they do race asphalt it's foams also.
I didn''t know about the HPI hubs with the LW suspension. as this is my first onroad Tamiya (my first Tamiya anything raceable). so I have alot to learn.
Old 06-03-2006, 07:04 PM   #4244
414play's Avatar
Not sure about the ta05 carbon tub chassis but my old ta04r carbon tub would short ladder packs.
414play is offline   Reply With Quote
Old 06-03-2006, 07:08 PM   #4245
big al's Avatar
I got a chance to run mine today and had major glitching issues. The only thing that changed was that I installed the LW chassis and ran the 540silver can class. Does anyone have any suggestions as to where I should look for problems. I've used the same equiment on FK04 (except the 540 silver can) and never had a problem. Any suggestions would be greatly appreciated!!--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
