Like Tree2Likes
Old 05-30-2006, 08:12 PM   #4186
rayman's Avatar
Originally Posted by racenut
I mesh my gears properly, im not that dumb I will put a silver can motor at my tao5, it will be my basis as starting point on gearings.
Nothing about being dumb. Just trying to isolate the problem.
gearing- questionable at 6.5
Motor new brushes, comm - ok
drivetrain free - ok
meshing correct - ok
So what's left? radio, esc and batts. But definitely there is something wrong if two TT01 with sport tuned motors were faster with a TAO5 with a 23turns. Try a different motor this saturday.
rayman is offline   Reply With Quote
Old 05-30-2006, 08:31 PM   #4187
Kevin CBR's Avatar
Does the Tao4's alluminum steering assembly will fit in my Toa5??? Also the CV axles of Tao4??
No and No. On the universals, TA04 is 39mm and TA05 regular suspension is 42mm. If you are refering to just the axles only, the TA04 and the "Kit" TA05 are the same axle.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 05-30-2006, 09:16 PM   #4188
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Hey kevin, the standard TA05 is 46mm universals 48mm if you use lightweight
tamiyarcracer is offline   Reply With Quote
Old 05-30-2006, 10:19 PM   #4189
racenut's Avatar
Trader Rating: 15 (100%+)
It was my gears bro, (overgear). I will use silver can motor this saturday with the same spur and pinion. err......FASTER??
racenut is offline   Reply With Quote
Old 05-30-2006, 10:21 PM   #4190
racenut's Avatar
Thanks Kev
Old 05-31-2006, 07:56 AM   #4191
Regional Moderator
Darkseid's Avatar
I think one thing thats being overlooked in this gearing issue is the motors themselves. Just because one C2 can be run at 6.0 doesn't mean another one can. Just because one C2 runs great at 7.2 doesn't mean another one will do as well there. And thats with the same motors from the same company. When you start throwing in aftermarket "tuned" versions of those same motors, then the differences between one C2 and another C2 can become even more pronounced. And its the same for all motors mod, stock, or 19t.
I think its fine to have a decent starting point for the gear ratio, but after that, it just becomes one more thing for us to obsess over, like how many grams we are over weight.
I once asked one of our fastest local racers what he was geared at. He looked at me and said "I don't know...I just gear it till I notice that the speed isn't increasing anymore...and I'm still making 5mins...after that I don't worry about the exact numbers."
It took me a few years to let go of my habit induced obsession over why this person is geared at this...while I'm geared at that...and so on. But I no longer worry about it. I just watch the motor temp, and how it performs on the track. After that, the only time I really worry about the "numbers" is when someone else asked me about it, or when I'm taking down info on a set up sheet.
Besides...running with a motor guru like CIVIC91 will drive you nuts(and get you beat badly) if you try to gear at the exact same ratio as he does.
TLR 22...Tamiya F104...
Old 05-31-2006, 09:15 AM   #4192
Speed Demon's Avatar
Default TA05 internal ratio change???
Guys,
I found this while browsing ebay. Seems that this guy has a lot of aftermarket option parts for the TA-05.
http://cgi.ebay.com/TTA180-Tech-Raci...QQcmdZViewItem
This particular thingy has 18T on the center pulley. Using this item it changes the TA-05 internal ratio from 2.25 to 2.00.
The question is, what will the effect gonna be??
Will it be good or bad??
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 05-31-2006, 09:16 AM   #4193
BlackKat's Avatar
Comtemplating running TCS with my TA05....what should I gear my silver can at?
BlackKat is offline   Reply With Quote
Old 05-31-2006, 09:55 AM   #4194
Trader Rating: 18 (100%+)
~5.0 +/-
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-31-2006, 02:08 PM   #4195
Send a message via AIM to A-Ko
Originally Posted by Speed Demon
Guys,
It should make you faster.
If you were running Mabuchi motors it might be awesome! ! !
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 05-31-2006, 05:17 PM   #4196
racenut's Avatar
Guys,
Not accepted in sanction racing such as Tamiya Cup
Old 05-31-2006, 06:48 PM   #4197
Redwings's Avatar
Sorry Guy but I have a dumb question. I have noticed that you all are talking about gearing but what in the heak do you mean when you say 5.0 -/+.
Is this a type of gear ratio ? If so could some on provide me with the specs for the gearing for a TA05 and how it works.
Paul
Redwings is offline   Reply With Quote
Old 05-31-2006, 07:00 PM   #4198
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Diff pulley divided by the center pulley (internal drive ratio) = 2.25
Then divide your spur gear by your pinion: example 104/30 = 3.46
Now multiply these together and thats the final drive ratio...7.785
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 05-31-2006, 07:06 PM   #4199
Redwings's Avatar
Thanks you very much for the info.
Old 05-31-2006, 07:13 PM   #4200
GreaseMonkey's Avatar
You can download an RC gear calculator from here which also might help
http://waits.net/public/rcgears/
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
