Like Tree2Likes
Old 04-29-2006, 10:14 PM   #4006
big al's Avatar
I was finally able to get a bit of track time with my ta05. I pretty much used the stock set-up with trinity 55wt all around, rear shocks in hole 3 on the tower and a front one-way. Does anybody have any suggestions to get the rear end to come around a little more. The car was good, just a little to much push coming out of the corner. I'm open to any suggestions..I do wanna keep it as stock as possible. The whole lightweight suspension thing doesn't sound all that appealing to me. thanks in advance--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 04-30-2006, 06:34 AM   #4007
BrainTeased's Avatar
hi guys!
im looking at getting a ta-05 soon i was wondering what hop ups were needed to get the car going as one semi-serious racer would like.
does it come with uni's all round?
cheers guys!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 04-30-2006, 06:36 AM   #4008
ttso's Avatar
Rise the real roll center, but be ware you might need to do lots adjustment on other place to correct the side effect.
ttso is offline   Reply With Quote
Old 04-30-2006, 09:04 AM   #4009
Tsquare's Avatar
Originally Posted by BrainTeased
hi guys!
cheers guys!
The car is heavy, so I would start with parts that lighten the car, Titanium Screw Set, I would also get the LW Suspension set, TRF Dampner set, Aluminum Ball Nuts, Titanium Turnbuckles, Graphite Dampner Towers Front and Rear, then depending on your driving style, Front and Center One-ways and/or Front Spool. That's a good list to start,I sure I have left a few items off. Good Luck!
Tsquare is offline   Reply With Quote
Old 04-30-2006, 09:20 AM   #4010
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Drive it stock, maybe if anything pick up the TRF dampers, then run it. Add small things as needed. As stated and proved before you don't NEED anything for this car to compete right out of the box!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-30-2006, 03:36 PM   #4011
rampal's Avatar
Send a message via MSN to rampal
hi guys!
cheers guys!
I ran the car first time fully stock but TRF shocks and swaybars... amazing, pretty much dialed with stock manual setting, only need to put some toe-out on the front for our track.... however, second time my front dogbone pops-off and that was very frustrating... so either buy front universals (not really needed on the back) or put another half of those read foams on each side of the front diff....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 04-30-2006, 04:53 PM   #4012
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Limit the front droop to about 1mm. this will give you less rear weight transfer. If you raise the rear roll center you will increase rear traction, not loose it. A rear swaybar will help also.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-30-2006, 08:22 PM   #4013
Trader Rating: 8 (83%+)
i just ordered a ta05 yesterday and it should be here wensday or thursday
any sugestions that i should do as i build it like tips and what kind of hop ups should i get first?
i730 is offline   Reply With Quote
Old 04-30-2006, 09:53 PM   #4014
big al's Avatar
Thanks slotmachine, that's what I was thinking--Al
Old 04-30-2006, 10:27 PM   #4015
JimmyMac's Avatar
Get some universals and a set of tuning springs. Maybe even a spool for asphalt and start from there.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is online now   Reply With Quote
Old 05-01-2006, 05:09 AM   #4016
thanks guys for the input
i was just wondering how much does the car weight complete stock ready to race minus transponder. (also please mention which cells was in the chassis)
but is there a problem with the front diff? for most of you guys to say get a oneway or a spool?
cheers once again
Old 05-01-2006, 05:21 AM   #4017
cannon's Avatar
Trader Rating: 35 (100%+)
James, you will get more turn in with the front one way on our outdoor tracks. Mine was way better with the front one way.
BTW it is not that light. You can get the weight but it costs
cannon is offline   Reply With Quote
Old 05-01-2006, 06:13 AM   #4018
Try these light weight parts
http://cgi.ebay.com/53895-TAMIYA-TA0...QQcmdZViewItem
http://cgi.ebay.com/TA05-Carbon-Rear...QQcmdZViewItem
http://cgi.ebay.com/TA05-Carbon-Fron...QQcmdZViewItem
http://cgi.ebay.com/53894-TAMIYA-TA0...QQcmdZViewItem
http://cgi.ebay.com/TAMIYA-1-10-RC-T...QQcmdZViewItem
http://cgi.ebay.com/TAMIYA-1-10-R-C-...QQcmdZViewItem
If you want to lighten the car further, GO HERE for aluminum fasteners. Just make sure you pre thread the carbon parts or you will strip out the heads of the screws.
Paul..............................................
Old 05-01-2006, 06:32 AM   #4019
yea i know but i think after the vics ill be running in 19T and those strong magnet cans dont help with us running one ways essepcially when the class is very tight, and our grip levels are really hopeless...
im only looking at options at the moment it seems like the evo 5 would be a wiser choice unless the ta-05 isnt too much heavier than the top of the line cars.
do you know much about the front diffs are they reliable greg?
Old 05-01-2006, 06:35 AM   #4020
The front diff is pleanty reliable..........It is plastic but I havent seen too many broken ones.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
