Like Tree2Likes
Old 04-24-2006, 11:45 AM   #3961
Send a message via MSN to TAMIYAMANUK
did anyone find the soultion for stiff diffs that a few guys were having problems with?
TAMIYAMANUK is offline   Reply With Quote
Old 04-24-2006, 04:31 PM   #3962
rayman's Avatar
Originally Posted by danjoy25
Just run the car first as it is before buying any options is my suggestion. But if you are buying overseas and want to save shipping then buy all the options you want
Love all those blue stuff. Are they all tamiya brand made for tao5 or adapted from 415 stuff? Suspenstion mounts, diff joints,turnbuckles are blue. Nice man.
rayman is offline   Reply With Quote
Old 04-24-2006, 04:58 PM   #3963
Tsquare's Avatar
I have recently built a TA05 with stock chassis. Compared to my graphite cars, this chassis seems tweeked, (i.e. does not lie flat on set-up board) I checked everthing on the car, all seems fine, it has never been run, so I do not believe anything can be bent. The plastic chassis just seems molded that way. Has anyone else noticed the same condition with their chassis?
The carbon chassis seems to be more along the lines of a TC4 or Yokomo molded tub, is this true? And if so, is it worth getting the carbon chassis. I will be racing stock and 19t, asphalt. Thanks in advance for any recommendations.
Tsquare is offline   Reply With Quote
Old 04-24-2006, 05:55 PM   #3964
big al's Avatar
Mine has a bit of a tweak as well and I haven't run it either. it's just the nature of the plastic. In general, I think people sweat a slight tweak way too much.
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 04-24-2006, 07:05 PM   #3965
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by Tsquare
I have recently built a TA05 with stock chassis. Compared to my graphite cars, this chassis seems tweaked, (i.e. does not lie flat on set-up board) I checked everything on the car, all seems fine, it has never been run, so I do not believe anything can be bent. The plastic chassis just seems molded that way. Has anyone else noticed the same condition with their chassis?
Every ta05 I have checked out on my scales has a weight balance issue. When you put the car on 4 scales you get the rear wheels to balance the same, but the fronts are about 40 grams different. Trust me it does not seem to effect the car that much. My car is running right up with the T2 X-Rays and Corrallys.........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-24-2006, 11:49 PM   #3966
kidrobot's Avatar
sup guys whats another good website other than rcmart is good to get ta-05 hopups at a good price and good quality???? thanks
kidrobot is offline   Reply With Quote
Old 04-25-2006, 12:30 AM   #3967
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
www.precisionrc.com
www.speedtechrc.com
www.rc-mushroom.com
www.shopping.rcmodel.hk
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-25-2006, 08:27 AM   #3968
rampal's Avatar
Send a message via MSN to rampal
today I run the car and my front left dogbone pop out from the wheel side.... is this normal? I had just tightened my diff... I think only one of those red foams is not enough.... has anyone of you had the same problem before? Should I buy the CVDs???
that was very frustrating!....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 04-25-2006, 08:45 AM   #3969
Originally Posted by rampal
today I run the car and my front left dog bone pop out from the wheel side.... is this normal? I had just tightened my diff... I think only one of those red foams is not enough.... has anyone of you had the same problem before? Should I buy the CVDs???
Yes buy the CVD`s for the front. They are also more efficient.
Old 04-25-2006, 08:57 AM   #3970
rampal's Avatar
Is #53847, universal assembly, right? I don't have and do not plan to have lightweight suspension for now....
thanks and cheers,
Old 04-25-2006, 09:02 AM   #3971
Tsquare's Avatar
RC Champ Advisors in Japan has great service and great prices.
Old 04-25-2006, 09:08 AM   #3972
cheehtae's Avatar
Trader Rating: 15 (100%+)
I know this is a bit off topic, but alot of guys have been looking for a thrust bearing , I ordered 2 packs which I would only need one pack(comes in two), so whoever is interested can PM me or e-mail me, also if any body has a cross joint( the one that go inside the CVD's , I'm willing to make a trade. $9.00 plus $3.00 shipping, paypal is Ok but not credit card funded. TNX and happy racing to all.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 04-25-2006, 01:32 PM   #3973
Send a message via AIM to Bane
Should I use anything thicker than Associated Stealth lube on my ball diffs on my TA05 or will this do the job. How much of whatever grease should I use?
Bane is offline   Reply With Quote
Old 04-25-2006, 02:01 PM   #3974
Yes that lube is fine
Put your balls in a plastic baggie.........
Put a small amount of diff lube in the bag with them
Squish them around in the lube and pull them out 1 at a time and put them in the diff gear....................
Watch out ....those balls get slippery .............
Old 04-25-2006, 06:49 PM   #3975
Viat's Avatar
Trader Rating: 24 (100%+)
Guys, what is the difference between:
RC TA05 Stabilizer Set (F&R)Item #53842
Tamiya Stabilizer Set Front/Rear TB-02?
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSF4&P=Z
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
