Like Tree2Likes
Old 04-23-2006, 05:44 PM   #3946
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
They are just easier to build consitent, need less rebuilds and are smooth as silk.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-23-2006, 07:36 PM   #3947
ttso's Avatar
Originally Posted by danjoy25
Try to replace the stock diff halves to the option ones like the 3 racing alloy version as this will be able to handle the increase power of the 4.5R.
For bashing I would stick to front diffs instead of one way so you still have 4 wheel braking
Guess is the a 4.5R will need 10:1+ ratio
I haven't use my stabilizers in my car for track racing so not sure if it any use for bashing other than blinging the car.
Stock diff halves can take 4.5R power... as long as you dont hard brake on it...
The gear ratio is on 10:1 mark. I run mine on 10:1 with profile3, smooth and fast. And yes the one-way is not needed. I found TA05 act kind strange with one-way (maybe it's setting, dont know).
ttso is offline   Reply With Quote
Old 04-23-2006, 07:49 PM   #3948
Slotmachine's Avatar
Send a message via MSN to Slotmachine
What do you mean , I am running double one ways on asphalt and its great.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-23-2006, 07:57 PM   #3949
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Either he forgot to mentioned during braking or his got his GTB set to auto braking which I don't recommend when running oneways.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-23-2006, 09:17 PM   #3950
Viat's Avatar
Trader Rating: 24 (100%+)
Cool
Guys,
Thanks for the info!
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
Old 04-23-2006, 11:39 PM   #3951
kidrobot's Avatar
ohok where can i find that diff halves can you give me a link? would the(#53841) TA05 Center One-way Set would make any difference if im using that motor and which is better to get for a swing shaft the 46mm or the 48mm? whats the difference between them why is the other longer?
sorry im a noob at this...used to own a tt-01
kidrobot is offline   Reply With Quote
Old 04-23-2006, 11:57 PM   #3952
danjoy25's Avatar
Here you go: http://www.rcmart.com/catalog/produc...ducts_id=17416
the difference in length in driveshafts comes down to what suspension to use.
Old 04-24-2006, 12:38 AM   #3953
kidrobot's Avatar
what about that center oneway thing do i need that?
Old 04-24-2006, 12:53 AM   #3954
danjoy25's Avatar
Do you want 4 wheel braking?
Old 04-24-2006, 01:08 AM   #3955
kidrobot's Avatar
do i need it wen i use the 4.5r???because im not really sure...i never had a belt drive before this is my first time getting this kind of car..i want to know all the things i need to get and know about this car before i get it...
Old 04-24-2006, 02:52 AM   #3956
ttso's Avatar
Maybe because I already get used to run front diff and front spool, I tend to brake-turn in corner entry. Put dual one-way on TA05 make the rear swing while I do brake-turn, very strange feeling. But I don't remember I got the same problem on TRF415. So I'm not sure what's the cause of swing rear.
And yes I do has drag-brake (20%) on GTB, but drag-brake isn't the reason cause I'm run fun with drag-brake only, the problem only accrue when I manually brake my car....
Old 04-24-2006, 03:07 AM   #3957
danjoy25's Avatar
Just run the car first as it is before buying any options is my suggestion. But if you are buying overseas and want to save shipping then buy all the options you want
Old 04-24-2006, 03:12 AM   #3958
ttso's Avatar
I think the Alum bulkhead is heavier than stock one, right?
I need to save every gram for my TA05 now since GTB+4.5R is quite heavy, plus heavy battery = 1600gram car.... DAMN...
Old 04-24-2006, 05:42 AM   #3959
RocketRacer's Avatar
i have read through this thread and learnt lots regarding setups for the TA05. i will be picking up my TA05 later today and will start building this evening. we have a TCS qualifier coming up this sunday and i will be running this in the SuperStock class. 23T RZ motor. Nosram International ESC. Hitec DCX FM Receiver and hitec 9965 Servo. Battery packs are limited to 2400mAh. so i will be rnning the sanyo sticks with deans plugs all around. i plan on running it box stock at this meeting and then working out from there what i will hop up. i will post pics....
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 04-24-2006, 06:47 AM   #3960
I think the Alum bulkhead is heavier than stock one, right?:
3 grams heavier, but they are stiffer than stock. The aluminum ones don't use the eccentric cam holding piece, they only use the round piece for setting the tension.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
