Like Tree2Likes
Old 04-22-2006, 08:21 AM   #3931
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by ttso
I'm not sure if this is TCS legal, but my TA05 is mod specially for low traction condition = flex chassis.
Stock chassis, front and rear brace cutoff, some reinforced rib milled out. Super flex chassis (maybe too flex... )
this won't be legal. i believe TCS rules prohibited removal or cutting out of chassis parts. well they didn't say it's to adjust flex but they can simply accuse you of doing it to lighten the chassis
dodo is offline   Reply With Quote
Old 04-22-2006, 08:40 AM   #3932
ttso's Avatar
Well, than I guess the only way to make stock chassis even more flex is removing 4 outer screws of brace. I did that before I cutoff the brace to make it lighter....
ttso is offline   Reply With Quote
Old 04-22-2006, 09:32 AM   #3933
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I would think just removing the screws would be ok?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-22-2006, 10:20 AM   #3934
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I don't see why they wouldn't let you omit screws.. just say you "forgot" to put them in.. heh.. it's not up to tech to say, "hey, you missed a screw here.. put one in..", since it would be your own fault if it fails on the track
I believe the 4-hole johnson (if a non-RC dude comes by and reads this, they'd think we're sickos ) also has 4 screw holes at the end.. I have one, and the vent holes near the endbell are almost half the size of the newer ones. I think the newer ones have 3 screw holes.. not sure what that third one is for, though
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 04-23-2006, 06:24 AM   #3935
Teehomo's Avatar
Trader Rating: 24 (100%+)
Hey guys, when using the Tamiya Carbon Fibre shock towers with the standard chasis and TRF shocks, is it necessary to use the C/F spacers as well? What do you lose by leaving them out?
Teehomo is offline   Reply With Quote
Old 04-23-2006, 07:24 AM   #3936
No, they are not needed.
Old 04-23-2006, 09:01 AM   #3937
dodo's Avatar
you can use either the c/f spacer on the shock tower mount or use the blue spacer that comes with the c/f shock tower on the shock mounting position.
Old 04-23-2006, 11:27 AM   #3938
kidrobot's Avatar
hi guys! Im thinking of getting this car. What are the things i need to mod or set up if im going to use a 4.5r brushless???so ill know what to get before i buy it....i wont be racing it anyways just have fun at the parking lot with alot of speed
thanks
kidrobot is offline   Reply With Quote
Old 04-23-2006, 11:39 AM   #3939
ttso's Avatar
thanks
If you are not going to race it, I don't think you need to take any mod on TA05 to run GTB+4.5R. GTB can fitin TA05 tub chassis without any mod/hopup.
Maybe steel CVD is the the only hopup you need, I don't know, never used stock dogbone before.
Old 04-23-2006, 01:11 PM   #3940
kidrobot's Avatar
ohok ummm what about the stablizer should i need it...and what gearing should i use? do i need the center one way??
Old 04-23-2006, 04:22 PM   #3941
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Try to replace the stock diff halves to the option ones like the 3 racing alloy version as this will be able to handle the increase power of the 4.5R.
For bashing I would stick to front diffs instead of one way so you still have 4 wheel braking
Guess is the a 4.5R will need 10:1+ ratio
I haven't use my stabilizers in my car for track racing so not sure if it any use for bashing other than blinging the car.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-23-2006, 04:59 PM   #3942
Viat's Avatar
How much is the difference between original Dampars and the "3Racing Alum Dampar set from Tamiya Car" or a simular set?
Viat is offline   Reply With Quote
Old 04-23-2006, 05:08 PM   #3943
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I boughta set of aftermarket dampers, it is hard to find springs that fit them right. Just go to eBay and get a Tamiya set.........
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
http://cgi.ebay.com/49355-TAMIYA-TRF...QQcmdZViewItem
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-23-2006, 05:13 PM   #3944
rayman's Avatar
Dont get other shocks. TRF shocks are one of the best. Non tamiya kits use them. too.
rayman is offline   Reply With Quote
Old 04-23-2006, 05:28 PM   #3945
Viat's Avatar
All right, but can you guys tell me how big is the difference in the car's performance?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
