Like Tree2Likes
Old 04-15-2006, 11:29 PM   #3841
Viat's Avatar
Trader Rating: 24 (100%+)
Cool
Thanks Slotmachin for the link!
My front belt also loosened a little bit.
Chef88, let me to try one set of his "Take-off`s" on my TA-05.
Viat is offline   Reply With Quote
Old 04-15-2006, 11:38 PM   #3842
GreaseMonkey's Avatar
I just adjusted the belts on my car after about 4 or 5 runs. I had to do 4 clicks on the rear and 3 on the front to get it back to where it was initially. This is the first time I've adjusted the belts. I'm curious as to whether they will keep stretching or if there is an initial bed in period and then they stretch less. It's just that I only have 2 slots left on the rear and 3 on the front so after another 5 or so runs I'll be looking at replacing my belts. Seems an awfully short life for belts.
Oh, I'm running a 19 turn motor which is probably putting a bit of strain on it compared to a stock motor.
GreaseMonkey is offline   Reply With Quote
Old 04-15-2006, 11:51 PM   #3843
SpeedTech's Avatar
Originally Posted by johntrickle1
For the TCS Racers out there:
What sedan tires are available now...A, B, B2, B3. Last time I raced TCS, I could buy B's off the shelf and now I can't find them anywhere.
Any info on insert/ tire combos for outdoor asphalt in 75 to 85 deg temps would be appreciated.
thanks for any info.
As far as I know, the B are no longer available. I wouldn't recommend the B2, they seem to be a bit too hard. As are good for cold weather as Max have mentioned, and the B3 is the choice for warm-hot weather.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-16-2006, 06:02 AM   #3844
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
My stock and Aramid belts stretched slightly initially, then haven't done much after that.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-16-2006, 07:47 AM   #3845
Send a message via MSN to TAMIYAMANUK
any ideas on what to lube to use in the one ways and centre ones ive herd off people not to spray wd-40 in there. any ideas?
TAMIYAMANUK is offline   Reply With Quote
Old 04-16-2006, 08:36 AM   #3846
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
serpent makes a really good lube mad specifically for oneways... in fact, im not sure anyone else does! the part # is 1680...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-16-2006, 03:26 PM   #3847
would xray lube be any good?
Old 04-16-2006, 04:01 PM   #3848
Ah, well it didn't go so good after I adjusted them. Earlier in the week, the front belt had flipped around but at the time I just flipped it back over and didn't think much of it. I guess what happenend is the belt had worn into the gear on the spur and rubbed through some of the teeth so when I ran it today, ti lasted about a minute, jumped off, pushed the other belt across and then wore through the spur gear cover.
So now I need a new centre gear. I have a one way from a 415 lying around. Would I be able to put that in until I can get a new centre gear?
Old 04-16-2006, 04:15 PM   #3849
C_O_jones's Avatar
The Xray diff lube works great! Doesn't fling off and seems to last for many runs.
Fred
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 04-16-2006, 04:18 PM   #3850
Hob-E-Lube HL661
Dodgersfan is offline   Reply With Quote
Old 04-16-2006, 04:52 PM   #3851
sounds like they were too loose. I've never had mine jump off or flip over.
Pretty sure you can't use the 415 pulley, but I may be mistaken.
Old 04-16-2006, 05:36 PM   #3852
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I`ve never heard of anything like that happening before.........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-16-2006, 06:15 PM   #3853
Well, unfortunately it did.
Like I said, the belt flipped over during the week but when I noticed the car was only runnign in rwd it was a bit of a distance away so I just drove it back to me, I imagine that is when the belt damaged the gear enough that it would jump off and onto the other side of the gear.
I've seen a photo of a 415 running the TA05 centre gear (no idea why as it's plastic and the 415 is aluminium) so I might see what I can fandangle up although just looking at the two it looks very different.
Old 04-16-2006, 06:29 PM   #3854
I think they use the TA05 center shaft too...so not sure how it would work?
Old 04-16-2006, 06:48 PM   #3855
Now last night I did have all 3 screws come out of my front one way....... Now they are locktighted in!!!!!!!!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
