Like Tree2Likes
Old 04-10-2006, 11:18 AM   #3751
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally Posted by Besercoe
That is an awesome looking piece of gear, would be good to see the carbon fibre completed with some of the carbon wing braces, i think 3 racing and square both make those. Well done looks awesome
i had the carbon wing brace but i fit not very well and i had to put a lot of spaces inorder to let it sit properly and some more the chassis will too stiff to put the carbon wing cause is 4mm if i not mistake
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-10-2006, 04:08 PM   #3752
big al's Avatar
Well, I'm just about finished with the ta05 build and so far I'm very pleased with the design. It seems Tamiya designed this chassis as a "sleeper", I'm looking forward to putting it to the test in a week or so. Funny enough, I just bought a FK04 (for $50 on ebay!!) and am now considering selling it and becoming a full fledged Tamiya junkie. Has anyone come across the stock arms and shock towers as fragile. I noticed quite a bit of flex when I installed the shock ball mounts?? Has anyone considered the potential of roll center mod as you could theoretically put shims under the susp. mounts?? Just throwing some ideas out there to spark our collective minds.--AL
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 04-10-2006, 06:01 PM   #3753
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
No, if anything the stock arms and towers are stronger than any aftermarket or option parts you can get...this thing is a tank!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-10-2006, 06:48 PM   #3754
POOKYT's Avatar
And How!!!!
My novice 8 year old son and his TA05
First race on carpet...........7 battery packs..........0 broken parts
Second race and first time on asphalt..........5 packs..........0 broken parts
So far with him running two races the score is 2 mangled bodies and 0 broken parts! Life is good!! Now I just need a body sponsor or he will break me!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-10-2006, 08:01 PM   #3755
big al's Avatar
Thanks Hudsong!!
Old 04-10-2006, 09:48 PM   #3756
big al's Avatar
I just weighed my ta05 and it's a bit chunky--1570 grams(with a body). What are you guys doing to knock off some of the weight and still keep it Tcs Legal??
Old 04-10-2006, 09:59 PM   #3757
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
1)Lightweight/reversible suspension
2) Ti or alloy turnbuckles
3) Carbon Components.
I got mine now 1509 grams race ready and will still drop when I get the 3 Carbon components parts this week.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-10-2006, 10:22 PM   #3758
big al's Avatar
Are Acer Racing bearing sets TCS legal?? That would be a significant decrease, wouldn't it??
Old 04-10-2006, 10:43 PM   #3759
Viat's Avatar
Trader Rating: 24 (100%+)
Does anybody has know how much 3000, 3300, 3600, 3700 and 3800 grams are?
Viat is offline   Reply With Quote
Old 04-11-2006, 12:43 AM   #3760
akuhon's Avatar
Default anti dive, anti squat and droop setting
Anyone set anti dive and anti squat for this TA05 chassis ?
Please tell me your setup and for what kind of track (asphalt or carpet).
Also tell me how you set the droop ....
Thanks for the info.
akuhon is offline   Reply With Quote
Old 04-11-2006, 02:22 AM   #3761
maxepower's Avatar
Talking RE: droop
LARGE ASPHALT TRACK- RUBBER TIRES
Front
Arms : lw
Toe : 0
Camber : 1.5
Shock Mounts : outside hole on shock tower and middle of the three holes on the arm
Shocks : 400 tamiya with 2 hole 1 red sponge
Blocks : 1X Front and 1XD Rear
Arm Spacing: front block/1mm/arm/the rest/rear block
Ackerman : front hole on the steering knuckle
Upper Link : middle hole 4mm up
Downtravel : 24.6mm measured from top of axles to setup board =(droop)
Springs : yellow
Swaybar : none
Ride Height: 5mm with TakeOff CS27
Rear
Arms : lw
Toe : 3 degrees
Camber : 1.5
Shock Mounts : in one hole on shock tower and inside of the two holes on the arm.
shocks : 300 tamiya with 2 hole 1 red sponge
Blocks : 1XC front and 1B rear
Arm Spacing: front block/the rest/arm/2mm/rear block
rear upright : 0 degree aluminum middle hole no spacer
Upper Link : middle hole on rear upright, middle hole on inside mount no spacer.
Downtravel : 25 mm measured from top of axle to setup board=(droop)
Springs : yellow
Swaybar : none
Notes:
CF shock towers front/rear. 5mm clamp-on wheel hex. 46mm swingshafts. Hop-up diffs front/rear setup with front tighter than rear. Dual Rate on radio 85%. Expo -15%. 0.7mm spacer epoxied on steering knuckle to decrease steering throw.
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 04-11-2006, 07:46 AM   #3762
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I`m trying it this weekend , I`ll let you know how it goes............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-11-2006, 09:32 AM   #3763
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Darkseid
Trying to figure out mm of belt push over the internet is....sketchy at best. Thats why I said just go with the stock(instruction) settings first. Its the only way to be sure that your starting from the same point as we all were.
Don't know what else to tell you...
Now you tell me I tried to help but should have left that one alone
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-11-2006, 09:34 AM   #3764
MikeR's Avatar
Yes legal. Not a big weight savings, no. Going from steel dogbones to alum. bones would save you more weight and be cheaper as an example.
Old 04-11-2006, 09:41 AM   #3765
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally Posted by tamiyarcracer
The 45th Shizuoka Hobby Show is May 16th - 21st. That would be my guess where it is.
madjack is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
